POV-Ray : Newsgroups : povray.newusers : Trouble defining a visible light source Server Time
1 Jun 2024 22:36:06 EDT (-0400)
  Trouble defining a visible light source (Message 1 to 7 of 7)
Subject: Trouble defining a visible light source
Date: 25 Nov 2021 17:20:00
Message: <web.61a00b1491a3b12e4f1a67df8bf7213@news.povray.org>
I'm using Povray 3.7.0.8 (which is the version coming straight from the Ubuntu
21.10 archives) and I'm trying to define a visible light source. I found this in
the docs for povray 3.6 here:
http://www.povray.org/documentation/view/3.6.2/137/
So, just for a test I copy/pasted this into my scene:
light_source
{ <0,0,0> color 1
  looks_like
  { sphere
    { <0,0,0>,0.1
      color { rgb 1 }
      finish { ambient 1 }
  translate <10,20,30>
But I get this error:
File '/home/trm/light.pov' line 91: Parse Error: No matching } in 'sphere', {
found instead Fatal error in parser: Cannot parse input.
Line 91 is the "color { rgb 1 }" one ...
Did something change in the syntax in version 3.7 or is the example incorrect
(or am I missing something basic)?
Thanks for any tips
Subject: Re: Trouble defining a visible light source
Date: 25 Nov 2021 17:51:41
Message: <874k7zsvbc.fsf@hajtower>
TheRealMorris writes:
> light_source
> { <0,0,0> color 1
>   looks_like
>   { sphere
>     { <0,0,0>,0.1
>       color { rgb 1 }
The syntax of POV-Ray apparently has changed, 'color' is no longer
permitted outside a texture or pigment.  Replace
    color { rgb 1 }
with
    pigment { color rgb 1 }
and the scene should render.
Cheers,
haj
Date: 25 Nov 2021 18:05:00
Message: <web.61a0164cd163838f4f1a67df8bf7213@news.povray.org>
> > light_source
> > { <0,0,0> color 1
> >   looks_like
> >   { sphere
> >     { <0,0,0>,0.1
> >       color { rgb 1 }
>     color { rgb 1 }
> with
> Cheers,
> haj
Thank you, that solves the issue.
Date: 26 Nov 2021 02:29:56
Message: <61a08cf4$1@news.povray.org>
Op 26/11/2021 om 00:03 schreef TheRealMorris:
Tip: When using the POV-Ray documentation, always use the wiki version
as that is the most up-to-date. Your document page can now be found here:
https://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_1
Personally, I most often start with:
https://wiki.povray.org/content/Reference:Keywords
Date: 26 Nov 2021 13:09:44
Message: <61a122e8@news.povray.org>
Le 2021-11-25 à 17:16, TheRealMorris a écrit :
> Hi,
> light_source
> { <0,0,0> color 1
>    looks_like
>    { sphere
>      { <0,0,0>,0.1
>        color { rgb 1 }
> Thanks for any tips
Replace «color» with «pigment».
Note : The keyword «color»/«colour» is no longer needed. It's a leftover
from previous versions. Pre version 3.3.
Use this instead :
light_source
{ <10,20,30> rgb 1
   looks_like
   { sphere
     { <0,0,0>,0.1
       pigment { rgb 1 }
The coordinate of the looks_like is always relative to the light_source
location.
Date: 28 Nov 2021 07:45:00
Message: <web.61a37931d163838fffb1c8fe8bf7213@news.povray.org>
> Thomas
Thank you, that's a useful tip. The problem is that the wiki isn't usually what
comes up first when you do a google search but ok, I can work around that.
Date: 29 Nov 2021 02:14:40
Message: <61a47de0$1@news.povray.org>
Op 28/11/2021 om 13:42 schreef TheRealMorris:
Bookmark the address? ;-)
