POV-Ray : Newsgroups : povray.newusers : Making a plane transparent Server Time
2 Jun 2024 00:14:56 EDT (-0400)
  Making a plane transparent (Message 1 to 7 of 7)
Subject: Making a plane transparent
Date: 29 Mar 2021 08:45:00
Message: <web.6061cacbc5d043ade47f5359fc7796ae@news.povray.org>
An easy problem here, I want this plane to be somewhat transparent to see the
sphere behind it. I thought 'rgbf' or 'rgbt' should do it but I cannot make it
work.
I use Povray 3.7 for Mac. My Code
background { colour Black }
#declare phi = (1/2)*(1+sqrt(5));
plane {
 <0,phi,1>, 0
        square color rgbt<0.5,0,0,0.5> color rgbt<0,0.5,0,0.5>  color
       finish { diffuse 0.9 phong 0.5}
 clipped_by { box {<-2.5,-2.5,-2.5>,<2.5,2.5,2.5>} }
sphere {
 <0,-1,-1>,1
 pigment { Blue }
   //orthographic
   location  <0, 0, 5>
   up        <0.0, 1.0,  0.0>
   right     <4/3, 0.0,  0.0>
   look_at   <0, 0,  0>
   rotate <0,0,0>
light_source { <200,500,-100> White
    spotlight
    radius  100
    falloff 200
    point_at <0,0,0>
Download 'plane.png' (95 KB)
Preview of image 'plane.png'
Subject: Re: Making a plane transparent
Date: 29 Mar 2021 09:30:00
Message: <web.6061d6357121601079819d986cde94f1@news.povray.org>
hi,
> work.
I replaced the colours with 'color rgbft <>' (inserting a zeros as values (in
3rd pos)), seems to do the trick.
regards, jr.
Download 'schoeni.png' (91 KB)
Preview of image 'schoeni.png'
Date: 29 Mar 2021 10:15:00
Message: <web.6061e0ac71216010e47f5359fc7796ae@news.povray.org>
Thanks for the fast reply! Unfortunately, I still cannot make it work. I have
now
square color rgbft <0.5,0,0,0,0.5> color rgbft <0,0.5,0,0,0.5>  color rgbft
 and I still see now blue sphere. Also changing values in the f or t position of
rgbft didn't help.
May I ask what exact setting you used?
Cheers,
Oliver
Date: 29 Mar 2021 10:40:00
Message: <web.6061e6527121601079819d986cde94f1@news.povray.org>
hi,
> > I replaced the colours with 'color rgbft <>' ...
> now
no idea, have attached the scene used.
uh, from memory:
  $ povray schoeni.pov +am2 +a0.1 -j +q9
hth.
regards, jr.
Download 'schoeni.txt' (1 KB)
Date: 29 Mar 2021 11:34:30
Message: <6061f386$1@news.povray.org>
> now
> rgbft didn't help.
> Cheers,
> Oliver
Hi Oliver,
Your original color encoding should work OK too - and does for me with
v3.7 and v3.8 versions of POV-Ray on Ubuntu linux.
(jr, does his original scene not work for you?)
One thing happening here is I believe the sphere is partly, or wholly,
lit through the plane. You could try adding finish { emission 0.3 },
say, to the sphere to make the transparency more obvious.
If still no sphere visible, try explicitly deleting the plane.png file
ahead of running the next render to be sure you are really creating a
new output file and not looking at an older one perhaps created with Red
and Green out of colors.inc.
Oh, and I don't know how the mac version saves ahead of each render. I
understand some versions have user interfaces with editors? I guess I'm
saying, be sure your updates are being saved ahead of new renders.
Bill P.
Date: 29 Mar 2021 12:10:00
Message: <web.6061fad77121601079819d986cde94f1@news.povray.org>
hi,
tja..  </scratch-back-of-neck>  did not even try.  and yes, it works here too
(v3.7 on a Debian vm).  (sorry Oliver for potentially leading you on a merry
chase)
regards, jr.
Date: 30 Mar 2021 12:16:12
Message: <60634ecc$1@news.povray.org>
> work.
Just change your code to :
#declare tr = 0.95;
plane {
   <0,phi,1>, 0
     square
       color rgbt <0.50, 0.00, 0.00, tr>
       color rgbt <0.00, 0.50, 0.00, tr>
   finish {
     diffuse 0.9
     phong 0.5
   clipped_by {
     box {
... and play with <tr> value from 0 to 1
Kurtz le pirate
Compagnie de la Banquise
