POV-Ray : Newsgroups : povray.newusers : passing values Server Time
15 Jan 2026 22:17:05 EST (-0500)
  passing values (Message 1 to 3 of 3)
Subject: passing values
Date: 7 Nov 2018 19:45:01
Message: <web.5be38644fb00a658749dac470@news.povray.org>
I am working on a scene involving the inside of a cabin. Each room is in a
separate INC file. I use IF statements to make certain walls invisible so the
inside of the room can be seen. Normally I do this by adjusting a #declared
value in the individual INC file. Is there a way to pass a value from the main
POV file to the INC file so I can do it in one location?
Subject: Re: passing values
Date: 7 Nov 2018 20:05:39
Message: <5be38be3@news.povray.org>
Am 08.11.2018 um 01:41 schrieb David Kraics:
Any variable you declare in the main file is available in any file it
subsequently includes.
E.g.:
     // main file
     #declare Foo = 42;
     #include "whatever.inc"
     // whatever.inc
     #debug concat("Foo is ", str(Foo,0,0), "\n")
This even works with files declared using `#local` in the main file.
Date: 8 Nov 2018 02:27:38
Message: <5be3e56a$1@news.povray.org>
>> in a
>> so the
>> #declared
>> the main
> E.g.:
>      // main file
>      #declare Foo = 42;
>      // whatever.inc
Maybe it could also be achieved if each room were embedded in a separate
macro?
