POV-Ray : Newsgroups : povray.newusers : Chipboard texture Server Time
14 Sep 2025 12:22:33 EDT (-0400)
  Chipboard texture (Message 1 to 4 of 4)
Subject: Chipboard texture
Date: 29 Jan 2018 08:30:00
Message: <web.5a6f217fe33edc0fc437ac910@news.povray.org>
This is one of those things that ought to be simple, but I've never wuite been
able to get it to work out right.
I wanted to design a texture resembling chipboard / particle board / OSB.
I figured that it would be as simple as using some randomly rotated wood
textures with a crackle pattern - but for whatever reason it looked like hell
the last 2 times I've tried it.
Anybody care to take a stab at it?
Subject: Re: Chipboard texture
Date: 29 Jan 2018 09:36:32
Message: <5a6f3170$1@news.povray.org>
How about Cork or Cork bumps from the insert menu?
dik
Rendered 920576 of 921600 pixels (99%)
Date: 29 Jan 2018 12:10:06
Message: <web.5a6f547d210f7801b414b8600@news.povray.org>
I'ts not that simple to make it perfect,
but with some magic drink ...
http://news.povray.org/povray.binaries.images/message/%3Cweb.5a6f4f23eeb2419db414b8600%40news.povray.org%3E/#%3Cweb.5a6
hope you like it.
Date: 29 Jan 2018 18:48:50
Message: <5a6fb2e2@news.povray.org>
If you have something like:
[0 wood rotate 0*x][1 Wood rotate 90*x]
Then, for all values between 0  and 1, you get a mix of the two
extremes. It probably don't look good.
You probably want something like (with "Wood" declared as some wood like
texture):
[0.1 Wood]
#local Rot = <rand(R),rand(R),rand(R)>*360;
[0.1 Wood rotate Rot][0.2 Wood rotate Rot]
[0.2 Wood rotate Rot][0.3 Wood rotate Rot]
[0.3 Wood rotate Rot][0.4 Wood rotate Rot]
[0.4 Wood rotate Rot][0.5 Wood rotate Rot]
[0.5 Wood rotate Rot][0.6 Wood rotate Rot]
[0.6 Wood rotate Rot][0.7 Wood rotate Rot]
[0.7 Wood rotate Rot][0.8 Wood rotate Rot]
[0.8 Wood rotate Rot][0.9 Wood rotate Rot]
That way, you get 10 ranges that have some uniform but random rotations.
You may want to have some tint variations. For that, declare two
textures that are the exact same EXCEPT that they use different
colour_map, like one light and one dark.
This gives this:
[0 WoodLight][0.1 WoodDark]
[0.1 WoodLight rotate Rot][0.2 WoodDark rotate Rot]
[0.2 WoodLight rotate Rot][0.3 WoodDark rotate Rot]
[0.3 WoodLight rotate Rot][0.4 WoodDark rotate Rot]
[0.4 WoodLight rotate Rot][0.5 WoodDark rotate Rot]
[0.5 WoodLight rotate Rot][0.6 WoodDark rotate Rot]
[0.6 WoodLight rotate Rot][0.7 WoodDark rotate Rot]
[0.7 WoodLight rotate Rot][0.8 WoodDark rotate Rot]
[0.8 WoodLight rotate Rot][0.9 WoodDark rotate Rot]
[0.9 WoodLight rotate Rot][1 WoodDark rotate Rot]
