POV-Ray : Newsgroups : povray.newusers : Box blob object? Server Time
27 Jul 2024 14:16:09 EDT (-0400)
  Box blob object? (Message 1 to 10 of 12)
Subject: Box blob object?
Date: 9 Aug 2017 16:55:00
Message: <web.598b75a15c2f84e3638427fa0@news.povray.org>
Hi, blender has a box type blob object besides standard capsule (cylinder)
ellipsoid and sphere. Does any povray version allow the same?  If not, or
without a workaround, this is a feature request. :-)
Subject: Re: Box blob object?
Date: 9 Aug 2017 18:52:21
Message: <598b9225$1@news.povray.org>
Am 09.08.2017 um 22:50 schrieb Mr:
Then a feature request it is ;)
Date: 9 Aug 2017 20:30:00
Message: <web.598ba83cba742d5fe2d509f80@news.povray.org>
I'm intrigued about this. Could you provide some more information? Any links? I
would like to see how far I am from being able to write a macro for this
purpose. Thank you.
B. Gimeno
Date: 10 Aug 2017 05:35:01
Message: <web.598c27c5ba742d5fe10e80840@news.povray.org>
> purpose. Thank you.
> B. Gimeno
hi,
In Blender, you add new objects to a scene by hitting SHIFT+A in the 3d view and
choose metaball (Blender's blob equivalent) in the submenu pick Cube (Blender's
"box" equivalent)
Date: 10 Aug 2017 09:15:27
Message: <598c5c6f$1@news.povray.org>
Well, at the moment I can't see any exit to the limits that the syntax
of blob in pov-ray imposes. I have not achieved anything acceptable,
except a certain resentment against those sticky forms.
Regards.
B. Gimeno
Date: 10 Aug 2017 16:14:07
Message: <598cbe8f$1@news.povray.org>
Am 10.08.2017 um 15:15 schrieb bgimeno:
POV-Ray's blobs are indeed currently too limited to do that job. You'd
need to resort to isosurfaces for that purpose.
Date: 15 Aug 2017 19:20:01
Message: <web.59938080ba742d5f61ea16670@news.povray.org>
Except an isosurface cube probably won't merge with a blob yet, will it?
Date: 16 Aug 2017 07:50:01
Message: <web.599430d4ba742d5fc437ac910@news.povray.org>
I think he means the way to blob-together isosurface functions as described in
the docs  (2.3.3.3.6 Combining isosurface functions):
Apart from basic CSG you can also obtain smooth transits between the different
surfaces, for instance the blob object:
  #declare Blob_Threshold=0.01;
  isosurface {
    function {
      (1+Blob_Threshold)
      -pow(Blob_Threshold, fn_A(x,y,z))
      -pow(Blob_Threshold, fn_B(x,y,z))
    max_gradient 4
    contained_by { box { -2, 2 } }
The Blob_Threshold value influences the smoothness of the transit between the
shapes. A lower value leads to sharper edges, and it's function looks like:
function{fn_A(x,y,z) + pow(Blob_Threshold,(fn_B(x,y,z) + Strength))}
Date: 18 Aug 2017 13:58:14
Message: <59972ab6$1@news.povray.org>
Am 16.08.2017 um 01:15 schrieb Mr:
No, but the other way round is now possible: A blob can be turned into a
`potential` pattern, a pattern can be turned into a function, and a
function can be combined with other isosurface functions such as that of
a "blob box" isosurface.
Date: 20 Aug 2017 10:10:01
Message: <web.599997f8ba742d5f61ea16670@news.povray.org>
Every blob converted to a function... Why not have povray do it all the time
under the hood so that these two types of entities get compatible with
eachother?
