Am 2017-06-23 06:09, also sprach Stephen:
> I've spent two days making rocks and trying to lay them in a single
> layer. I'm really struggling with it.
I thought about it a little. I can easily do this in an animation,
because of the constant recursive adjustments and tweaking of positions.
Building a single static image with everyone in the right place, not
so much.
dik
Thomas de Groot <tho### [at] degrootorg> wrote:
> > I will just say that there apparently has been much work done on exactly this.
Whoops - by "this", I meant the original objective.
I suppose that's the old / whole problem with pronouns, and I didn't want to
just hand out the links I was perusing - just yet. ;)
I figured we'd see how Ari was coming along on this.
I'll sit back and watch :-)
http://www.afhalifax.ca/magazine/wp-content/sciences/EmpilementDeDisques/ProducingPacking/Initialization.pdf
and
https://arxiv.org/pdf/1005.0011.pdf
"For generally
shaped particles, finding the densest packings is notoriously difficult. This
salient point is
we
cannot guess or even closely approximate the answer, let alone prove it, and it
is difficult to
develop even a qualitative understanding of the effects of grain shape on
Until recently, very little was known about the densest packings of polyhedral
particles. The
difficulty in obtaining dense packings of polyhedra is related to their complex
rotational
degrees of freedom and to the non-smooth nature of their shapes [28, 29]."
Amidst the chaos of RL, (I moved over the weekend) I managed to work out a
reliable placement of a sphere tangent to all 4 faces of any irregular
tetrahedron.
I worked out some macros to generate the determinant of a 4x4 matrix, based on
the Laplace expansion, or expansion by minors, but for whatever reason that
didn't play nicely with my tetrahedra.
I might have to shovel a lot of output to the debug stream and work out a smaple
problem by hand to see if there's a bug somewhere.
I modified some code from John Burkardt, and that seemed to work, so ...
It's immediately apparent that there will be large gaps between such spheres in
a random tetrahedral "mesh", and these guys have done some work on that next
step:
certainly one can see how the Delaunay-optimized triangles make the incircles
pack much more nicely, so that's a fairly important first-step to filling space
by this method.
Wondering how Ari's doing.... :D
> tetrahedron.
> step:
> by this method.
Hi, guys! Haven't been here for a while because I am trying to find a way which
I could 'understand'.(I have found a lot of research papers on this topic but
none of them are comprehensible for me) Therefore, I ended up finish my project
*in a very simple way*. Just make random spheres and test with distance
equation. And that's it. :(
http://i.imgur.com/xH64ud9.jpg
*Dawn it! I hope I can find a way to improve the code so that they won't float*
> equation. And that's it.:(
> float*
Good of you to come back. :)
I said at the beginning that it was not trivial. I wonder what your
lecturer's solution would be?
Your image looks a good solution but you are an Engineer. What were your
tolerances?
Now you know your way here. Don't be a stranger. :)
Regards
*** Yet *** ;)
> > float*
Excellent. It's important to stick with it and DO _something_, even if it's not
ideal. Never let the perfect be the enemy of the good.
I like your results.
Now you know more about how "the devil is in the DETAILS", and it's NEVER _just_
"All you have to do is..."
As a computer graphics trick, why don't you try increasing the size of all those
rocks by 10, and then take the whole thing and scale it by 1/10.
The apparent size of the rocks might stay the same, while the spaces between
them that make them look like they're floating (because they are) might be
reduced by 9/10.
If that works, try doing the same with 100 or 1000 instead of 10.
If it's an engineering class, he might not have one - it might be an open-ended
exercise to see what people come up with.
Indeed, there's always more fun to be had, and so very many things to learn.
Check out:
https://malbertsinvention.wordpress.com/2013/08/15/realistic-dry-stone-wall-physics-test/
https://www.google.com/search?q=rocksolver
https://www.google.com/search?q=robot+arm+stack+stones
There is no solution :( The professor just wanted to let us try something *new*
and see if we are interested in this software. Overall, I think this software is
pretty fun. I think I will come back after attending more math class in the
University :D.
> tolerances?
Same as the above. We don't have any 'standard' or 'marking scheme'. My
professor just found out that amazing grains picture and he told us it could be
a great example for us to begin with and imitate. So, I need to figure out how
to render a similar scene :D.
Ayyyyy, thank you Stephen B-).
That's true! Trying to be *perfect* is actually the culprit of my anxiety. After
I changed from *perfect mode* to *good mode*, I started to appreciate this
software. What a great invention :D.
> reduced by 9/10.
That's cute :P. I think I will try it later.
Yes, it is. :D
> Check out:
They are some interesting examples, especially the robot one. The Rocksolver is
great, too! Thank you so much B-).
