POV-Ray : Newsgroups : povray.newusers : Stacking stones without overlapping Server Time
25 Mar 2026 23:27:25 EDT (-0400)
  Stacking stones without overlapping (Message 11 to 20 of 64)
Subject: Re: Stacking stones without overlapping
Date: 16 Jun 2017 03:35:41
Message: <59438a4d$1@news.povray.org>
On 6/16/2017 7:57 AM, Ari wrote:
> By the way, the thread URL is
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4d97bab0dc7be259e5cacc00%40news.povray.org%3E/?mtop=360023
I read the thread and if I understood it*. Sam used an external program,
he developed himself, to calculate the positions of the grains.
So, in my opinion, unless using a third party program like bullet
physics or Blender is acceptable. Then it would be very difficult to get
the quality of Sam's image. But since you are a first year engineering
student. It might be acceptable to use tools in addition to PovRay.
I am no mathematician.
It raises an interesting philosophical question.
Were you given that image and told to reproduce it or did you pick it
yourself?
Does the person who gave you the problem have a solution?
And in an engineering frame. What tolerances do you need to work to?
I said that I was no mathematician and that is two questions. ;-)
Regards
Date: 16 Jun 2017 05:20:01
Message: <web.5943a27bd8d105e99c5d6c810@news.povray.org>
023
A wizard for sure, as are many others. I missed so much all those years ago but
already had seen plenty being done by Samuel.
I guess if I were to attempt my own "stacking stones" it would probably be
something like I had used for object interactions with simplistic 'sphere of
influence' for mass and gravity when I was doing rudimentary space simulations
in Basic programming (circa 1980's).
Not ideal for this, even if I could get it right in POV-Ray.
Date: 16 Jun 2017 06:26:38
Message: <5943b25e$1@news.povray.org>
> 023
Yes a wizard. I wonder when he will reappear to drop off another gem.
Ah! basic. Now you are talking. :)
I managed to get a lander program working on a Casio calculator, in basic.
I can see it working on rectangular stones as in a dry stone dyke. You
would not have to be too concerned about gaps between rounded stones, I
think.
Regards
Date: 16 Jun 2017 08:05:01
Message: <web.5943c899d8d105e9c437ac910@news.povray.org>
3
Aha.
That was a good read, and I'd say that some excellent info is contained therein
- especially the scene code and that last post.
Up to this point, I'd say that the focus has been on using a random placement as
the fundamental method by which to build the pile, however, a stepwise #while
loop that built the pile up in strata would be a different approach - with
different advantages and challenges.
I'd say that there's a whole world of interesting algorithmic material out there
that could be applied to this, and certainly the Graphics Gems series and some
of those Numerical Recipes type code examples might help.
You might want to take a look at things like Appolonian Gaskets, Steiner circles
and spheres, canal and channel surfaces, fractals, closest packing schemes and
crystallography, and Voronoi diagrams and Delaunay triangulations.
http://paulbourke.net/fractals/apollony/
The key at this point though, is to keep it simple and fast enough to get the
job done.  Don't "let the perfect be the enemy of the good." ;)
Date: 16 Jun 2017 13:15:01
Message: <web.5944111dd8d105e9c437ac910@news.povray.org>
> .... Sam used an external program,
I'd say that he probably used Voroi++
http://math.lbl.gov/voro++/examples/
which from the download page, says that the output can be used in POV-Ray
http://math.lbl.gov/voro++/download/
What would be nice would be a way to shell out to Voroi++ to generate the data
for a scene and then render it.
I just don't know how to do that ([like many things] yet).
Date: 16 Jun 2017 15:00:08
Message: <59442ab8$1@news.povray.org>
It is not really that difficult. At least it wasn't in Ver 3.5. When I
last used the function. You write a text file in PovRay with the
variables you need and get the 3rd party software to export the results
of the calculations to a text file that PovRay can read.
Yes this would be an animation even if it is only two frames or a frame
per layer.
I ask myself if something this complex is appropriate for a first year
engineering course.  But then my first year at university detailed
thermionic valves and ne'er a mention of semiconductors. :) So things
might have changed.
Regards
Date: 16 Jun 2017 16:30:01
Message: <web.59443ebfd8d105e9c437ac910@news.povray.org>
> per layer.
I guess my question was whether or not Voro++ is set up to accept comman-line
parameters and return a file for immediate processing by POV-Ray.
If so, then it would be of great interest to those who have a continuing
interest in having direct access to the set of coordinates used for the crackle
pattern - by supplanting crackle with a Voro++ data file, that would be a great
workaround.
> might have changed.
It ought to be perfectly fine.
I remember the engineers on my floor constantly being immersed in Statics:
http://ruina.tam.cornell.edu/Book/RuinaPratap8-21-10.pdf
Date: 17 Jun 2017 02:12:46
Message: <5944c85e$1@news.povray.org>
Am 2017-06-16 03:35, also sprach Stephen:
I, too, use a Java program to position grains. I found SDL to be
hideously slow when doing a 1600 x 1600 loop. ;)
http://www.buckosoft.com/tteoac/video/frames/ttfo0177.png
I love Sam's idea; pick a position and then alter the blob's shape and
size to fit the position.
dik
Date: 17 Jun 2017 04:05:00
Message: <web.5944e215d8d105e99d2528170@news.povray.org>
Omg, Guys!
I just cannot believe how generous and warm this community is.
I am sorry that I just completely immersed myself in this software (I only got 2
months to learn this technique :( And it is making me anxious now) therefore I
cannot check this thread frequently. Thanks again for the big help! Even though
I cannot reply the messages one by one, I swear I would read all the useful
information I have received. Again, I just cannot how generous this community
could be at the first glance. A big shoutout to all of you :D.
Date: 17 Jun 2017 04:13:21
Message: <5944e4a1@news.povray.org>
On 6/17/2017 9:02 AM, Ari wrote:
> Omg, Guys!
Oh! you have not received the invoice, yet. :)
Regards
