POV-Ray : Newsgroups : povray.newusers : Bright harsh shadow lines using attenuation Server Time
1 Jun 2024 20:00:36 EDT (-0400)
  Bright harsh shadow lines using attenuation (Message 1 to 2 of 2)
Subject: Bright harsh shadow lines using attenuation
Date: 20 May 2016 17:40:00
Message: <web.573f83afc23a6d9245ff35e0@news.povray.org>
Can someone explain (or point me to an explanation) of why bright lines appear
in the shadows when you move the light off axis? The bright lines are not
present if the boxes are solid, it only happens with attenuation. Is there a way
around this result? Code below.
Thanks,
Stuart
#version 3.7; #include "colors.inc" global_settings {ambient_light <0,0,0>
assumed_gamma 1}
camera {angle 35 location  <500, 0 , 0> look_at <0 , 0 , 0>}
# declare boxcolor = texture{pigment{rgbt 1} finish { reflection 0.0 ambient 0.0
diffuse 0.0 phong 0.0 roughness 0.0 irid {0.0}}}
# declare boxinterior =  interior{fade_power 10000 fade_distance 9}
//light_source{<1000, 0 , 0> rgb <2,2,2>}
light_source{<1000, -10 , -10> rgb <2,2,2>}
plane { <1,0,0>,0 texture{pigment{rgb 1}}}
box {<700, 0, 0> <717.5, 20, 20> hollow texture{boxcolor} interior{boxinterior}}
box {<700, 0, 0> <735, -20, 20> hollow texture{boxcolor} interior{boxinterior}}
box {<700, 0, 0> <752.5, 20, -20> hollow texture{boxcolor}
box {<700, 0, 0> <770, -20, -20> hollow texture{boxcolor} interior{boxinterior}}
Subject: Re: Bright harsh shadow lines using attenuation
Date: 20 May 2016 18:13:57
Message: <573f8c25$1@news.povray.org>
Am 20.05.2016 um 23:38 schrieb Stuart:
Coincident surfaces. They can cause weird artifacts.
Make sure your boxes overlap a tiny bit, and you'll see the lines disappear.
