POV-Ray : Newsgroups : povray.newusers : Emitting objects masked by trasnparent ones. Server Time
27 Jul 2024 14:30:18 EDT (-0400)
  Emitting objects masked by trasnparent ones. (Message 1 to 5 of 5)
Subject: Emitting objects masked by trasnparent ones.
Date: 16 May 2016 12:25:00
Message: <web.5739f353c23a6d9cb2407280@news.povray.org>
I'm having a problem rendering emitting objects, where transparent objects seem
to be blocking the light from others behind.
It can be seen in the minimal code (part of a larger scene) below and in this
render https://www.dropbox.com/s/fki0av19wjwnbvu/minimal_bug_example.png?dl=0
The left hand cylinder seems to obscure the right hand one, and I can't work out
why. Can anyone help?
Thanks!
  location <15,0,40>
  look_at <5,0,0>
  angle 45
//background
background { color Black }
#declare thick = 1.5;
union {
  #for (ii, 8, 9)
    cylinder{
      (ii*thick*x), (((ii+1)*thick*x)-0.000001), 1
      pigment { Clear }
      hollow
      interior {
        media {
          emission White * 0.03
    scale <1,12.4,12.4>
Subject: Re: Emitting objects masked by trasnparent ones.
Date: 16 May 2016 12:55:00
Message: <web.5739fa8f352152539c083ab80@news.povray.org>
"EdR" <nomail@nomail> wrote:
> Hi,
> Thanks!
> camera {
>   location <15,0,40>
>   look_at <5,0,0>
>   angle 45
> //background
> union {
>   #for (ii, 8, 9)
>     cylinder{
>       pigment { Clear }
>       hollow
>       interior {
>         media {
>     scale <1,12.4,12.4>
>   #end
maybe not related, but did you realize -0.000001 is -0.000001*<1,1,1> ?
Date: 17 May 2016 06:51:39
Message: <573af7bb$1@news.povray.org>
> Hi,
Seems to be a coincident surface/numeric accuracy issue, try changing
your 0.0000001 offset to 0.001 instead, that fixed it for me. And as
already mentioned, you probably meant 0.001*x
Date: 17 May 2016 07:17:33
Message: <573afdcd$1@news.povray.org>
On 05/16/2016 12:22 PM, EdR wrote:
> Hi,
> Thanks!
> camera {
>    location <15,0,40>
>    look_at <5,0,0>
>    angle 45
> //background
> union {
>    #for (ii, 8, 9)
>      cylinder{
>        pigment { Clear }
>        hollow
>        interior {
>          media {
>      scale <1,12.4,12.4>
>    #end
I believe you are running into an internal a numerical cut off in the
media sampling code(1). If you increase the overlap between cylinders,
things work in my tests.
In addition, it would be more normal to use a merge (which eliminates
internal boundaries) when using media or transparency vs a union - but
maybe you want some different effect. The pigment and hollow can also be
applied to the entire merge/union instead of each cylinder when they are
identical.
My version of your code following some of the advice above :
   merge {
   //cylinder{ (1.5*x), ((3.0*x)-0.000001), 1 pigment { Red } }
   //cylinder{ (3.0*x), ((4.5*x)-0.000001), 1 pigment { Green } }
   //cylinder{ (1.5*x), ((3.0*x)-0.00001), 1 pigment { Clear } } // Fail
   //cylinder{ (3.0*x), ((4.5*x)-0.00001), 1 pigment { Clear } }
     cylinder{ (1.5*x), ((3.0*x)-0.0001), 1 pigment { Clear } } // OK
     cylinder{ (3.0*x), ((4.5*x)-0.0001), 1 pigment { Clear } }
     hollow
     interior {
       media {
   //scale <1,12.4,12.4>
Bill P.
(1) - How individual rays move through the shapes likely will also
affect where this accuracy / cut off issue is seen. As would, I expect,
changing the media sampling criteria.
Date: 17 May 2016 08:05:01
Message: <web.573b087f35215253cb2407280@news.povray.org>
> > Hi,
> > Thanks!
> > camera {
> >    location <15,0,40>
> >    look_at <5,0,0>
> >    angle 45
> > //background
> > union {
> >    #for (ii, 8, 9)
> >      cylinder{
> >        pigment { Clear }
> >        hollow
> >        interior {
> >          media {
> >      scale <1,12.4,12.4>
> >    #end
> identical.
>    merge {
>      hollow
>      interior {
>        media {
> Bill P.
Thanks to you all. I did, indeed mean to have 0.000001 inside the bracket, but
the main issue was that 0.000001 was too small. It works fine with 0.001 as
suggested.
Thanks for all your help,
Ed
