POV-Ray : Newsgroups : povray.newusers : Loops and strings Server Time
10 Oct 2025 12:56:31 EDT (-0400)
  Loops and strings (Message 1 to 4 of 4)
Subject: Loops and strings
Date: 21 Mar 2016 16:25:00
Message: <web.56f05768dab79262d18e5a860@news.povray.org>
Hello,
I have got a question about using strings and loops in povray.
I have got about 60 objects with the same attributes but they all have got
different meshes that come from STL-files.
Like this:
object{ somemesh_xx
"somemesh_xx" is a string and I want to generate 60 different objects from 60
different STL-files by using a loop with the variable "xx".
So I would like avoid writing somemesh_01 , somemesh_02 , ... , somemesh_60
and to be able to change the attribute of all by only changing one variable.
I would be glad if you could help me.
Subject: Re: Loops and strings
Date: 21 Mar 2016 16:37:04
Message: <56f05b70$1@news.povray.org>
there is a Parse_String macro in strings.inc that should work for you.
Date: 21 Mar 2016 17:36:03
Message: <56f06943$1@news.povray.org>
You might want to think of using concat in a loop. Below is code to
include a file "Chain02G2Y_XX.pov" where XX depends on the frame number.
#include
concat("f:\\Graphics\\Data\\Chain02G2Y_",str(mod(frame_number,89),-4,0),".pov")
Regards
Date: 21 Mar 2016 18:54:40
Message: <56f07bb0@news.povray.org>
> Hello,
> Like this:
> object{ somemesh_xx
Why not use an array of meshes?
 From the documentation, ANY item that can be declared as an identifier
can be declared in an array.
As you can do this:
#declare MyMesh = mesh{....}
you can do:
#declare MyMeshArray = array[60]
Then, in a loop, read your STL files for the various mesh elements.
Instead of having somemesh_01, you have somemesh[1].
