POV-Ray : Newsgroups : povray.newusers : Import of measurement data (ASCII format) in animation Server Time
23 Mar 2026 08:56:20 EDT (-0400)
  Import of measurement data (ASCII format) in animation (Message 31 to 34 of 34)
Subject: Re: Import of measurement data (ASCII format) in animation
Date: 6 Mar 2016 01:20:04
Message: <web.56db1a00a405651b5e7df57c0@news.povray.org>
I just spent a lot of time getting all the array loops to work without error,
and now POV complains
Parse Error: Expected 'RValue to declare', End of File found instead
or if I comment out the #end where it chokes, then I get "end of file reached,
but #end expected.
As far as I can see, all my #locals have a ; and all my #fors have an #end
Hoping someone can help me spot where in the chain it's all going wrong.
I'll keep hunting backward
(This is fourth time I'm posting this - seems to be a problem getting it to
"take" via the web interface in p.b.scene files)
#version 3.7;
global_settings { assumed_gamma 1.0 }
// SDL for making a Bezier spline - given 4 data points, compute control points
p1 and p2
// Bill Walker - 2016
// Adapted code to POV-Ray from :
// https://www.particleincell.com/2012/bezier-splines/
// https://www.particleincell.com/wp-content/uploads/2012/06/circles.svg
// replace var with #declare or #local, function with #macro, edit #for() #end
syntax, array[] syntax
#include "debug.inc"
 Set_Debug (true)
#include "math.inc"
light_source { <0, 50, -50>  color rgb <1, 1, 1>}
#declare Camera_Front =
location  <0, 90, -1>
 //right    x*image_width/image_height
look_at   <0, 0, 0>}
camera {Camera_Front}
// bezier-spline.js
// computes cubic bezier coefficients to generate a smooth
// line through specified points. couples with SVG graphics
// for interactive processing.
// For more info see:
// http://www.particleincell.com/2012/bezier-splines/
// Lubos Brieda, Particle In Cell Consulting LLC, 2012
// you may freely use this algorithm in your codes however where feasible
// please include a link/reference to the source article
//#declare svg=document.documentElement //svg object
#declare S = array[4];     //splines
#declare V = array[4];     //vertices
//#declare C       //current object
//#declare x0,y0     //svg offset
#declare K = array[4];
#macro init()
//saves elements as global variables
 //create splines
 //#declare S[0] = createPath("blue");
 //#declare S[1] = createPath("red");
 //#declare S[2] = createPath("green");
 //#declare S[3] = createPath("brown");
 //create control points
 #declare V[0] = <60,60,0>;
 createKnot(V[0])
 #declare V[1] = <220,300,0>;
 createKnot(V[1])
 #declare V[2] = <420,300,0>;
 createKnot(V[2])
 #declare V[3] = <700,240,0>;
 createKnot(V[3])
 updateSplines()
#end // end macro init
#macro createPath(Color, Width)
//creates and adds an SVG path without defining the nodes
 //width = (typeof width == 'undefined' ? "8" : width);
 //#declare P=document.createElementNS("http://www.w3.org/2000/svg","path")
 //P.setAttributeNS(null,"fill","none")
 //P.setAttributeNS(null,"stroke",color)
 //P.setAttributeNS(null,"stroke-width",width)
 //svg.appendChild(P)
 //return P
#macro createKnot(V)
//creates and adds an SVG circle to represent knots
sphere { V 22 pigment {Yellow}}
  //#declare C=document.createElementNS("http://www.w3.org/2000/svg","circle")
  //C.setAttributeNS(null,"r",22)
  //C.setAttributeNS(null,"cx",x)
  //C.setAttributeNS(null,"cy",y)
  //C.setAttributeNS(null,"fill","gold")
  //C.setAttributeNS(null,"stroke","black")
  //C.setAttributeNS(null,"stroke-width","6")
  //C.setAttributeNS(null,"onmousedown","startMove(evt)")
  //svg.appendChild(C)
  //return C
#end // end macro createKnot
// Maybe set up java mouse movement as clock-linked animation
//from http://www.w3.org/Graphics/SVG/IG/resources/svgprimer.html
/* #macro startMove(evt)
  SVG positions are relative to the element but mouse positions are relative to
the window, get offset
  x0 = getOffset(svg).left;
  y0 = getOffset(svg).top;
  C=evt.target
  svg.setAttribute("onmousemove","move(evt)")
  svg.setAttribute("onmouseup","drop()")
 #end // end macro startMove
 //called on mouse move, updates dragged circle and recomputes splines
 #macro move(evt)
  x = evt.clientX-x0;
  y = evt.clientY-y0;
  move the current handle
  updateSplines();
 #end // end macro move
 //called on mouse up event
 #macro drop()
  svg  = document.getElementsByTagName('svg')[0];
  svg.setAttributeNS(null, "onmousemove",null)
 #end // end macro drop
#macro updateSplines()
//computes spline control points
 //grab (x,y) coordinates of the control points
 #local X = array[4];
 #local Y = array[4];
 #for (i, 0, 3)     //for (i=0;i<4;i++)
  //use parseInt to convert string to int
  #local X[i] = V[i];   //parseInt(V[i].getAttributeNS(null,"cx"))
  #local Y[i] = V[i];   //parseInt(V[i].getAttributeNS(null,"cy"))
 //computes control points p1 and p2 for x and y direction
 #local px = computeControlPoints(X);
 #local py = computeControlPoints(Y);
 //updates path settings, the browser will draw the new spline
 #for (i, 0, 2)     //for (i=0;i<3;i++)
  //S[i].setAttributeNS(null,"d",
path(x[i],y[i],px.p1[i],py.p1[i],px.p2[i],py.p2[i],x[i+1],y[i+1]));
  //#debug concat( "(Draw SVG path subroutine)   i = ", str(i, 3, 1), "\n")
#end // end macro updateSplines           ^^^^ call path macro
#macro path(x1,y1,px1,py1,px2,py2,x2,y2)
//creates formated path string for SVG cubic path element
 //return "M "+x1+" "+y1+" C "+px1+" "+py1+" "+px2+" "+py2+" "+x2+" "+y2;
#end // end macro paths
#macro computeControlPoints(K)
//computes control points given knots K, this is the brain of the operation
 #local p1 = array[4];
 #local p2 = array[4];
 #local n = dimension_size (K, 1) - 1;  //K.length-1;
  //rhs vector
  #local a = array[n];
  #local b = array[n];
  #local c = array[n];
  #local r = array[n];
  //left most segment
  #local a[0] = 0;
  #local b[0] = 2;
  #local c[0] = 1;
  #local r[0] = K[0] + 2 * K[1];
  //internal segments
  #for (i, 0, n-2)     //(i = 1; i < n - 1; i++)
   #local a[i] = 1;
   #local b[i] = 4;
   #local c[i] = 1;
   #local r[i] = 4 * K[i] + 2 * K[i+1];
  //right segment
  #local a[n-1] = 2;
  #local b[n-1] = 7;
  #local c[n-1] = 0;
  #local r[n-1] = 8 * K[n-1] + K[n];
  //solves Ax=b with the Thomas algorithm (from Wikipedia)
  #for (i, 1, n-1)     //#for (i = 1; i < n; i++)
   #local m = a[i]/b[i-1];
   #local b[i] = b[i] - m * c[i - 1];
   #local r[i] = r[i] - m*r[i-1];
  #local p1[n-1] = r[n-1]/b[n-1]; //#local p1[n-1] = r[n-1]/b[n-1];
  // {Be sure to include debug.inc file!}
  //#debug concat( "Defining p1.   n-1 = ", str((n-1), 3, 1), "\n")
  #for (i, n-2, 0, -1)     //#for (i = n - 2; i >= 0; --i)
   #local p1[i] = (r[i] - c[i] * p1[i+1]) / b[i];
   //#debug concat( "Defining p1.   i = ", str(i, 3, 1), "  Defining p1.   i+1 =
", str((i+1), 3, 1),"\n")
  //we have p1, now compute p2
  #for (i, 0, n-2)     //#for (i=0;i<n-1;i++)
   //#debug concat( "Defining p2   i = ", str(i, 3, 1), "  i+1 = ", str((i+1),
3, 1),"\n")
   #local p2[i] = 2 * K[i+1] - p1[i+1];
  #local p2[n-1] = 0.5 * (K[n] + p1[n-1]);
  //return {p1:p1, p2:p2};
#end // end macro computeControlPoints
//code from
http://stackoverflow.com/questions/442404/dynamically-retrieve-html-element-x-y-position-with-javascript
//#macro getOffset( el )
//    #declare _x = 0;
//   #declare _y = 0;
//    while( el && !isNaN( el.offsetLeft ) && !isNaN( el.offsetTop ) ) {
//        _x += el.offsetLeft - el.scrollLeft;
//        _y += el.offsetTop - el.scrollTop;
//        el = el.offsetParent;
//    return { top: _y, left: _x };
//call macros
init ()
Message: <web.56db1fb6a405651b5e7df57c0@news.povray.org>
but #end expected.
(This is fifth time I'm posting this - seems to be a problem getting it to
"take" via the web interface in p.b.scene files, and here as well)
I reworked the file into a "linear" scene description, and it works fine as long
as the macro is not called by saying
If I just call the macro with computeControlPoints(X), the SDL renders 4 spheres
and doesn't choke.   I'm mystified.
#version 3.7;
p1 and p2
 Set_Debug (true)
#include "math.inc"
look_at   <0, 0, 0>}
// bezier-spline.js
#macro init()
 //create splines
 createKnot(V[0])
 createKnot(V[1])
 createKnot(V[2])
 createKnot(V[3])
 updateSplines()
 //return P
  //return C
  C=evt.target
 #macro move(evt)
  x = evt.clientX-x0;
  y = evt.clientY-y0;
  updateSplines();
 #macro drop()
  //rhs vector
  //left most segment
  #local a[0] = 0;
  #local b[0] = 2;
  #local c[0] = 1;
  //internal segments
   #local a[i] = 1;
   #local b[i] = 4;
   #local c[i] = 1;
  //right segment
  #local a[n-1] = 2;
  #local b[n-1] = 7;
  #local c[n-1] = 0;
3, 1),"\n")
//code from
//    #declare _x = 0;
//   #declare _y = 0;
//call macros
init ()
Date: 6 Mar 2016 03:12:49
Message: <56dbe681$1@news.povray.org>
Am 05.03.2016 um 19:04 schrieb Bald Eagle:
> but #end expected.
Just for info, and before anyone complains:
The newsgroup server had some hiccups, and failed to show new postings.
Not really surprising that someone would double-post (or in this case
fivefold-post).
Date: 6 Mar 2016 11:10:01
Message: <web.56dc552ea405651b5e7df57c0@news.povray.org>
> fivefold-post).
Yes, I realized that, after nothing went through, and I didn't see any posts for
13+ hours.
That's OK - I worked through the code again and again and came to the same
conclusion.  I guess it's just seems so foreign to have an array name just
sitting there all alone on an empty, otherwise blank line.
No #declare, no "return", no =, no ;
It was hard to see what WASN'T in the macro, but then past experience, and
seeing what folks have done with self-recursive macros made a neuron fire.
I also figures out the rest of the output of the algorithm, what it ACTUALLY
does (not what I thought it did / wanted it to do), and basically, it was a
long, tiring, but educational and productive night that gave me a both a
headache and sense of accomplishment.
Sorry for the quintuple-post  :O
