POV-Ray : Newsgroups : povray.newusers : Import of measurement data (ASCII format) in animation Server Time
12 Jul 2025 23:06:20 EDT (-0400)
  Import of measurement data (ASCII format) in animation (Message 25 to 34 of 34)
Subject: Re: Import of measurement data (ASCII format) in animation
Date: 4 Mar 2016 12:25:00
Message: <web.56d9c427a405651b5e7df57c0@news.povray.org>
OK, so due to the extreme difficulty of employing bicubic_patch objects for
this,
{issues I've run into are
- the sometimes extreme disparity between control points and patch surface
coordinates,
- Somehow trace does not hit the edge of the patch when a ray is shot straight
down at the patch in the y direction from far above a control point
- inability to get accurate min and max extent
- extremely difficult to determine control points from data points on the curve
I've reimagined this whole thing, and of course the first stumbling block I got
to was:
If I read all the data in from the file, then render the first frame,
what will happen is that upon rendering the 2nd frame, the data gets read in
AGAIN, over and over and over.
Any ideas for fixes for this?
This looks like the ole' Persistence of Data across frames problem.
"POV needs POD!"
Date: 4 Mar 2016 13:09:51
Message: <56d9cf6f$1@news.povray.org>
Am 04.03.2016 um 18:21 schrieb Bald Eagle:
> "POV needs POD!"
UberPOV has an experimental feature to carry over data from one frame to
the next (or, actually more to the point, from one render to the next,
regardless of whether those are two frames in an animation or entirely
independent renders), using "#persistent" instead of "#declare".
Date: 4 Mar 2016 13:44:51
Message: <56d9d7a3$1@news.povray.org>
> this,
> coordinates,
One of the problems might be that we do not have calibration data for
the sensors.
I rendered it as triangles in a mesh. The points are not planer. You
could use a statistical formula to make them sit on a plane.
> to was:
> "POV needs POD!"
You step through the data using the clock or frame_number variables.
Talking about the data. I don't understand the time stamp. Five second
intervals, that's quite slow, is it not? And what are the units of the
sensors?
The long time interval makes me think that using splines is not the way
to go.
Regards
Date: 4 Mar 2016 16:25:00
Message: <web.56d9fc6ba405651b5e7df57c0@news.povray.org>
> the sensors.
I think it's just a matter of displaying the data that's available.
I think it's all Y data - the X and z coordinates I derived from the diagram
that was provided.  I just connected the perimeter points to get a few
triangles, and it looks _OK_ - it would be better with smooth triangles, but I'm
unsure exactly how to calculate the corner normals.
I used frame number - worked fine
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.56d9fbdd155fef445e7df57c0%40news.povray.org%3E/
> sensors?
Maybe it's a geologic plate ...  ;)
Could be they meant milliseconds or something.
> to go.
Just normalize the time stamp to the interval 0-1 by dividing them all by 490,
although I don't think the spline is limited by the numbers.
Date: 4 Mar 2016 18:32:48
Message: <56da1b20@news.povray.org>
>> the sensors.
>> sensors?
The units used can be totaly arbitrary. They can be in thousanth of an
inch, micrometer, dust grains, mili-picas,... They only need to be self
concistent. All we meed to have, is the possibility to assume that the
data are linear.
That would be my guess also. Mili- or microsecond.
>> to go.
Splines are not limited to any range of values. Those can be negative or
positive and range in the millions if wanted or needed.
In this case, you can multiply clock by 490, or whatever, to get the
same result.
Date: 4 Mar 2016 20:45:01
Message: <web.56da38fca405651b5e7df57c0@news.povray.org>
> Is there a way to calculate where the control point needs to be given the
> surface coordinate?
Not sure if this gets us anywhere...
https://etd.ohiolink.edu/rws_etd/document/get/wright1190032099/inline
From Page 67:
% determine the size scalar fo
u2size = size(u2,1);
v2size = size(v2,1);
% generate the matrices U and V for the ps
U2 = [u2.^3 u2.^2 u2
V2 = [v2.^3 v2.^2 v2
% control point matrix indices
cmri = j1*4;
cmci = i1*4;
%%%%%%% psuedo-inverse transform
Pxc(cmri-3:cmri,cmci-3
((inv(B)*pinv(U))*Px*(pinv(V)'*inv(B)
Pyc(cmri-3:cmri,cmci-3:cmci) =
((inv(B)*pinv(U))*Py*(pinv(V)'*inv(B)'));
Pzc(cmri-3:cmr
((inv(B)*pinv(U))*Pz*(pinv(V)'*i
Date: 6 Mar 2016 01:20:04
Message: <web.56db1a00a405651b5e7df57c0@news.povray.org>
I just spent a lot of time getting all the array loops to work without error,
and now POV complains
Parse Error: Expected 'RValue to declare', End of File found instead
or if I comment out the #end where it chokes, then I get "end of file reached,
but #end expected.
As far as I can see, all my #locals have a ; and all my #fors have an #end
Hoping someone can help me spot where in the chain it's all going wrong.
I'll keep hunting backward
(This is fourth time I'm posting this - seems to be a problem getting it to
"take" via the web interface in p.b.scene files)
#version 3.7;
global_settings { assumed_gamma 1.0 }
// SDL for making a Bezier spline - given 4 data points, compute control points
p1 and p2
// Bill Walker - 2016
// Adapted code to POV-Ray from :
// https://www.particleincell.com/2012/bezier-splines/
// https://www.particleincell.com/wp-content/uploads/2012/06/circles.svg
// replace var with #declare or #local, function with #macro, edit #for() #end
syntax, array[] syntax
#include "debug.inc"
 Set_Debug (true)
#include "math.inc"
light_source { <0, 50, -50>  color rgb <1, 1, 1>}
#declare Camera_Front =
location  <0, 90, -1>
 //right    x*image_width/image_height
look_at   <0, 0, 0>}
camera {Camera_Front}
// bezier-spline.js
// computes cubic bezier coefficients to generate a smooth
// line through specified points. couples with SVG graphics
// for interactive processing.
// For more info see:
// http://www.particleincell.com/2012/bezier-splines/
// Lubos Brieda, Particle In Cell Consulting LLC, 2012
// you may freely use this algorithm in your codes however where feasible
// please include a link/reference to the source article
//#declare svg=document.documentElement //svg object
#declare S = array[4];     //splines
#declare V = array[4];     //vertices
//#declare C       //current object
//#declare x0,y0     //svg offset
#declare K = array[4];
#macro init()
//saves elements as global variables
 //create splines
 //#declare S[0] = createPath("blue");
 //#declare S[1] = createPath("red");
 //#declare S[2] = createPath("green");
 //#declare S[3] = createPath("brown");
 //create control points
 #declare V[0] = <60,60,0>;
 createKnot(V[0])
 #declare V[1] = <220,300,0>;
 createKnot(V[1])
 #declare V[2] = <420,300,0>;
 createKnot(V[2])
 #declare V[3] = <700,240,0>;
 createKnot(V[3])
 updateSplines()
#end // end macro init
#macro createPath(Color, Width)
//creates and adds an SVG path without defining the nodes
 //width = (typeof width == 'undefined' ? "8" : width);
 //#declare P=document.createElementNS("http://www.w3.org/2000/svg","path")
 //P.setAttributeNS(null,"fill","none")
 //P.setAttributeNS(null,"stroke",color)
 //P.setAttributeNS(null,"stroke-width",width)
 //svg.appendChild(P)
 //return P
#macro createKnot(V)
//creates and adds an SVG circle to represent knots
sphere { V 22 pigment {Yellow}}
  //#declare C=document.createElementNS("http://www.w3.org/2000/svg","circle")
  //C.setAttributeNS(null,"r",22)
  //C.setAttributeNS(null,"cx",x)
  //C.setAttributeNS(null,"cy",y)
  //C.setAttributeNS(null,"fill","gold")
  //C.setAttributeNS(null,"stroke","black")
  //C.setAttributeNS(null,"stroke-width","6")
  //C.setAttributeNS(null,"onmousedown","startMove(evt)")
  //svg.appendChild(C)
  //return C
#end // end macro createKnot
// Maybe set up java mouse movement as clock-linked animation
//from http://www.w3.org/Graphics/SVG/IG/resources/svgprimer.html
/* #macro startMove(evt)
  SVG positions are relative to the element but mouse positions are relative to
the window, get offset
  x0 = getOffset(svg).left;
  y0 = getOffset(svg).top;
  C=evt.target
  svg.setAttribute("onmousemove","move(evt)")
  svg.setAttribute("onmouseup","drop()")
 #end // end macro startMove
 //called on mouse move, updates dragged circle and recomputes splines
 #macro move(evt)
  x = evt.clientX-x0;
  y = evt.clientY-y0;
  move the current handle
  updateSplines();
 #end // end macro move
 //called on mouse up event
 #macro drop()
  svg  = document.getElementsByTagName('svg')[0];
  svg.setAttributeNS(null, "onmousemove",null)
 #end // end macro drop
#macro updateSplines()
//computes spline control points
 //grab (x,y) coordinates of the control points
 #local X = array[4];
 #local Y = array[4];
 #for (i, 0, 3)     //for (i=0;i<4;i++)
  //use parseInt to convert string to int
  #local X[i] = V[i];   //parseInt(V[i].getAttributeNS(null,"cx"))
  #local Y[i] = V[i];   //parseInt(V[i].getAttributeNS(null,"cy"))
 //computes control points p1 and p2 for x and y direction
 #local px = computeControlPoints(X);
 #local py = computeControlPoints(Y);
 //updates path settings, the browser will draw the new spline
 #for (i, 0, 2)     //for (i=0;i<3;i++)
  //S[i].setAttributeNS(null,"d",
path(x[i],y[i],px.p1[i],py.p1[i],px.p2[i],py.p2[i],x[i+1],y[i+1]));
  //#debug concat( "(Draw SVG path subroutine)   i = ", str(i, 3, 1), "\n")
#end // end macro updateSplines           ^^^^ call path macro
#macro path(x1,y1,px1,py1,px2,py2,x2,y2)
//creates formated path string for SVG cubic path element
 //return "M "+x1+" "+y1+" C "+px1+" "+py1+" "+px2+" "+py2+" "+x2+" "+y2;
#end // end macro paths
#macro computeControlPoints(K)
//computes control points given knots K, this is the brain of the operation
 #local p1 = array[4];
 #local p2 = array[4];
 #local n = dimension_size (K, 1) - 1;  //K.length-1;
  //rhs vector
  #local a = array[n];
  #local b = array[n];
  #local c = array[n];
  #local r = array[n];
  //left most segment
  #local a[0] = 0;
  #local b[0] = 2;
  #local c[0] = 1;
  #local r[0] = K[0] + 2 * K[1];
  //internal segments
  #for (i, 0, n-2)     //(i = 1; i < n - 1; i++)
   #local a[i] = 1;
   #local b[i] = 4;
   #local c[i] = 1;
   #local r[i] = 4 * K[i] + 2 * K[i+1];
  //right segment
  #local a[n-1] = 2;
  #local b[n-1] = 7;
  #local c[n-1] = 0;
  #local r[n-1] = 8 * K[n-1] + K[n];
  //solves Ax=b with the Thomas algorithm (from Wikipedia)
  #for (i, 1, n-1)     //#for (i = 1; i < n; i++)
   #local m = a[i]/b[i-1];
   #local b[i] = b[i] - m * c[i - 1];
   #local r[i] = r[i] - m*r[i-1];
  #local p1[n-1] = r[n-1]/b[n-1]; //#local p1[n-1] = r[n-1]/b[n-1];
  // {Be sure to include debug.inc file!}
  //#debug concat( "Defining p1.   n-1 = ", str((n-1), 3, 1), "\n")
  #for (i, n-2, 0, -1)     //#for (i = n - 2; i >= 0; --i)
   #local p1[i] = (r[i] - c[i] * p1[i+1]) / b[i];
   //#debug concat( "Defining p1.   i = ", str(i, 3, 1), "  Defining p1.   i+1 =
", str((i+1), 3, 1),"\n")
  //we have p1, now compute p2
  #for (i, 0, n-2)     //#for (i=0;i<n-1;i++)
   //#debug concat( "Defining p2   i = ", str(i, 3, 1), "  i+1 = ", str((i+1),
3, 1),"\n")
   #local p2[i] = 2 * K[i+1] - p1[i+1];
  #local p2[n-1] = 0.5 * (K[n] + p1[n-1]);
  //return {p1:p1, p2:p2};
#end // end macro computeControlPoints
//code from
http://stackoverflow.com/questions/442404/dynamically-retrieve-html-element-x-y-position-with-javascript
//#macro getOffset( el )
//    #declare _x = 0;
//   #declare _y = 0;
//    while( el && !isNaN( el.offsetLeft ) && !isNaN( el.offsetTop ) ) {
//        _x += el.offsetLeft - el.scrollLeft;
//        _y += el.offsetTop - el.scrollTop;
//        el = el.offsetParent;
//    return { top: _y, left: _x };
//call macros
init ()
Message: <web.56db1fb6a405651b5e7df57c0@news.povray.org>
but #end expected.
(This is fifth time I'm posting this - seems to be a problem getting it to
"take" via the web interface in p.b.scene files, and here as well)
I reworked the file into a "linear" scene description, and it works fine as long
as the macro is not called by saying
If I just call the macro with computeControlPoints(X), the SDL renders 4 spheres
and doesn't choke.   I'm mystified.
#version 3.7;
p1 and p2
 Set_Debug (true)
#include "math.inc"
look_at   <0, 0, 0>}
// bezier-spline.js
#macro init()
 //create splines
 createKnot(V[0])
 createKnot(V[1])
 createKnot(V[2])
 createKnot(V[3])
 updateSplines()
 //return P
  //return C
  C=evt.target
 #macro move(evt)
  x = evt.clientX-x0;
  y = evt.clientY-y0;
  updateSplines();
 #macro drop()
  //rhs vector
  //left most segment
  #local a[0] = 0;
  #local b[0] = 2;
  #local c[0] = 1;
  //internal segments
   #local a[i] = 1;
   #local b[i] = 4;
   #local c[i] = 1;
  //right segment
  #local a[n-1] = 2;
  #local b[n-1] = 7;
  #local c[n-1] = 0;
3, 1),"\n")
//code from
//    #declare _x = 0;
//   #declare _y = 0;
//call macros
init ()
Date: 6 Mar 2016 03:12:49
Message: <56dbe681$1@news.povray.org>
Am 05.03.2016 um 19:04 schrieb Bald Eagle:
> but #end expected.
Just for info, and before anyone complains:
The newsgroup server had some hiccups, and failed to show new postings.
Not really surprising that someone would double-post (or in this case
fivefold-post).
Date: 6 Mar 2016 11:10:01
Message: <web.56dc552ea405651b5e7df57c0@news.povray.org>
> fivefold-post).
Yes, I realized that, after nothing went through, and I didn't see any posts for
13+ hours.
That's OK - I worked through the code again and again and came to the same
conclusion.  I guess it's just seems so foreign to have an array name just
sitting there all alone on an empty, otherwise blank line.
No #declare, no "return", no =, no ;
It was hard to see what WASN'T in the macro, but then past experience, and
seeing what folks have done with self-recursive macros made a neuron fire.
I also figures out the rest of the output of the algorithm, what it ACTUALLY
does (not what I thought it did / wanted it to do), and basically, it was a
long, tiring, but educational and productive night that gave me a both a
headache and sense of accomplishment.
Sorry for the quintuple-post  :O
