POV-Ray : Newsgroups : povray.newusers : Looking for Full RGB color spectrum for my media density file. Server Time
14 Dec 2025 16:53:34 EST (-0500)
  Looking for Full RGB color spectrum for my media density file. (Message 1 to 6 of 6)
Subject: Looking for Full RGB color spectrum for my media density file.
Date: 21 Dec 2015 17:05:02
Message: <web.5678775673f2438d25a5dca20@news.povray.org>
I am looking for color map that maps the deepest red at 0 value of my density
file and then works to green at .5 value and then works to deepest blue at the 1
value of my density file.
The kind of color map that you would use for a rain weather map.  I have worked
enough with colors to know that what I am looking for sounds easy, but might not
be easy at all.  RGB colors are kind of tricky.
The pov code below is an example of my format, but does not have the right color
map.
density {
         density_file df3 filename1
         interpolate 1
        color_map {
 [0.01 rgb <0,0,0>]
        [0.03 rgb <0,0,1>]
 [0.05 rgb <0,0,0>]
        [0.07 rgb <0,1,0>]
 [0.09 rgb <0,0,0>]
        [0.11 rgb <1,0,0>]
 [0.13 rgb <0,0,0>]
        [0.15 rgb <0,0,1>]
 [0.17 rgb <0,0,0>]
        [0.19 rgb <0,1,0>]
 [0.21 rgb <0,0,0>]
        [0.23 rgb <1,0,0>]
 [0.25 rgb <0,0,0>]
        [0.27 rgb <0,0,1>]
 [0.29 rgb <0,0,0>]
        [0.31 rgb <0,1,0>]
 [0.33 rgb <0,0,0>]
        [0.35 rgb <1,0,0>]
 [0.37 rgb <0,0,0>]
        [0.39 rgb <0,0,1>]
        [0.41 rgb <0,0,0>]
        [0.43 rgb <0,1,0>]
 [0.45 rgb <0,0,0>]
        [0.47 rgb <1,0,0>]
 [0.49 rgb <0,0,0>]
        [0.51 rgb <0,0,1>]
 [0.53 rgb <0,0,0>]
        [0.55 rgb <0,1,0>]
 [0.57 rgb <0,0,0>]
        [0.59 rgb <1,0,0>]
 [0.61 rgb <0,0,0>]
        [0.63 rgb <0,0,1>]
 [0.65 rgb <0,0,0>]
        [0.67 rgb <0,1,0>]
 [0.69 rgb <0,0,0>]
        [0.71 rgb <1,0,0>]
 [0.73 rgb <0,0,0>]
        [0.75 rgb <0,0,1>]
 [0.77 rgb <0,0,0>]
        [0.79 rgb <0,1,0>]
        [0.81 rgb <0,0,0>]
        [0.83 rgb <1,0,0>]
 [0.85 rgb <0,0,0>]
        [0.87 rgb <0,0,1>]
 [0.89 rgb <0,0,0>]
        [0.91 rgb <0,1,0>]
 [0.93 rgb <0,0,0>]
        [0.95 rgb <1,0,0>]
 [0.97 rgb <0,0,0>]
        [1.00 rgb <1,1,1>]
Subject: Re: Looking for Full RGB color spectrum for my media density file.
Date: 21 Dec 2015 20:13:09
Message: <5678a3a5$1@news.povray.org>
> map.
Why is your color_map so complexe? Why do you think that you need those
black stripes? Why do you repeat the sequence
black-blue-black-green-black-red 8 times?
Why don't you keep it simple?
How about this?
color_map{
  [0.00   rgb<0,0,1>]
  [0.97/2 rgb<0,1,0>]
  [0.97   rgb<1,0,0>]
  [1.00   rgb 1]
Or
color_map{
  [0.0      rgb<0,0,1>]
  [0.97/4   rgb<0,1,1>]
  [0.97/2   rgb<0,1,0>]
  [0.97*3/4 rgb<1,1,0>]
  [0.97     rgb<1,0,0>]
  [1.0      rgb 1]
You may also try substituting srgb in place of rgb to use the sRGB
colour space instead of the linear colour space used with plain RGB values.
Date: 21 Dec 2015 21:33:04
Message: <5678b660$1@news.povray.org>
Am 21.12.2015 um 23:04 schrieb sirzerp:
Make sure to use assumed_gamma 1.0 in the global settings; that'll give
you good colour transitions without drops in the brightness for the
in-between colours.
You'll probably want to start at rgb <R,0,0> for the red, then rgb
<Y,Y,0> if you want to go via yellow, then rgb <0,G,0>, and finally rgb
<0,0,B> for blue. I'd start with R=Y=G=B=1.0, and tweak from there.
Date: 22 Dec 2015 08:05:01
Message: <web.567949ef1d62f6e7566b73360@news.povray.org>
srgb won't make any difference if all of the anchor values are either 1 or 0.
The srgb keyword controls only the initial color, not the transitions between
colors.
Date: 23 Dec 2015 15:15:18
Message: <web.567b001f1d62f6e725a5dca20@news.povray.org>
Thank for your answer, I will try it.  The reason that the first color scheme is
so complex is that I plot out equal potential contours of EM fields.
Continuous volumes of the same color have the save value in the density file.
Here's an example done with pov-ray.
https://youtu.be/nUsZniD6alA
> > map.
> How about this?
> color_map{
>   [0.00   rgb<0,0,1>]
>   [0.97/2 rgb<0,1,0>]
>   [0.97   rgb<1,0,0>]
>   [1.00   rgb 1]
> Or
> color_map{
>   [0.0      rgb<0,0,1>]
>   [0.97/4   rgb<0,1,1>]
>   [0.97/2   rgb<0,1,0>]
>   [0.97     rgb<1,0,0>]
>   [1.0      rgb 1]
> Alain
Date: 24 Dec 2015 00:53:14
Message: <MPG.30e55240c889273e989693@news.povray.org>
In article <web.567b001f1d62f6e725a5dca20@news.povray.org>,
sir### [at] gmailcom says...
That's slick.
