POV-Ray : Newsgroups : povray.newusers : declaring a new texture with a macro Server Time
8 Jun 2024 16:41:05 EDT (-0400)
  declaring a new texture with a macro (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: declaring a new texture with a macro
Date: 30 Nov 2015 16:54:28
Message: <565cc594$1@news.povray.org>
One thing that I would try:
First, #declare your object.
Next, find it's bounding box using min_extent() and max_extent().
Average the returned values.
Use that averaged value as the look_at for the camera.
If you still get nothing:
Maybe the object is to small or large or to distant.
Try moving the camera toward the object or the object toward the camera.
Try scalling the object up or down. Start using factors of 10.
Maybe it's to dark.
Try any of the following:
Use a white background.
Use only ambient and temporarily set the colour to some light shade,
like rgb<1,0,1>.
Date: 30 Nov 2015 16:59:19
Message: <565cc6b7$1@news.povray.org>
> "Warren" <nomail@nomail> wrote:
>> Hi,
>> Here's my problem:
>> I have a macro in an include file ("textures_JeuM_v3.inc") defined like this:
>> [snip]
>> And in the main scene file/pov file , I have this code:
>> [snip]
> You have given us insufficient information to test the scene.  What are the
> values of C_marronA1, etc.?  What is the value of tps?  What do the height field
> source images look like?
relatively dark and warm.
So, the various C_marronxx are variations of that brown.
Date: 1 Dec 2015 04:05:00
Message: <web.565d623a4f56292ca73f5e290@news.povray.org>
I've modified my project files to keep the essential and it still doesn't work.
I've uploaded the files (pov, inc and png of heightfield) to a server in a zip
archive. The files are quite small.
Here is the path to download the zip file:
www.ant01.fr/fichiersAnt01/povray/pov_help_macro.zip
Date: 1 Dec 2015 04:44:16
Message: <565d6bf0@news.povray.org>
> (* Note that you're welcome to simplify your scene and trim it down to
> the portion that gives you problems; that, too, helps us help you.
Often just performing this task will identify the problem.
Date: 1 Dec 2015 04:47:39
Message: <565d6cbb@news.povray.org>
Seems to work here - I get a pink coloured background with a beige wave
going across this middle. Is this what you expected?
Date: 1 Dec 2015 10:40:00
Message: <web.565dbe1c4f56292ca73f5e290@news.povray.org>
I post the content of the files
File #1 : CouleursPersoAnt.inc
#declare C_marronA1=rgb<113/256, 65/256, 52/256>;
#declare C_marronA2=rgb<117/256, 69/256, 56/256>;
niveau 1 des sols marrons
#declare C_marronB1=rgb<138/256, 89/256, 73/256>;
#declare C_marronB2=rgb<130/256, 85/256, 69/256>;
#declare C_marronB3=rgb<125/256, 77/256, 65/256>;
#declare C_marronB4=C_marronA1;
#declare C_marronB5=C_marronA3;
#declare C_marronC1=C_marronB1*1.15;
#declare C_marronC2=C_marronB2*1.15;
#declare C_marronC3=C_marronB3*1.15;
#declare C_marronC4=C_marronB4*1.15;
#declare C_marronC5=C_marronB5*1.15;
//End of file
File #2 : textures_JeuM_v3.inc
//Nouveau fichier pour les textures
#include "CouleursPersoAnt.inc"
//Textures des differents sols pour Mercenaires
#macro
T_var_Wrinkles(multiplicateur,Cmarron1,Cmarron2,Cmarron3,Cmarron4,Cmarron5,ValAmbient,ValDiffuse)
    texture{pigment{wrinkles color_map{
                                       [0.0 Cmarron3*multiplicateur]
                                       [0.125 Cmarron2*multiplicateur]
                                       [0.25 Cmarron1*multiplicateur]
                                       [0.375 Cmarron2*multiplicateur]
                                       [0.5 Cmarron3*multiplicateur]
                                       [0.675 Cmarron4*multiplicateur]
                                       [0.75 Cmarron5*multiplicateur]
                                       [0.875 Cmarron4*multiplicateur]
                                       [1.0 Cmarron3*multiplicateur]
                    scale 0.005
            finish { ambient ValAmbient diffuse ValDiffuse}
//Definitions des sols marron avec les macros
#declare
T_marron_MacroNiv1=T_var_Wrinkles(<1,1,1>,C_marronA1,C_marronA2,C_marronA3,C_marronA4,C_marronA5,1,0)
#declare
T_marron_MacroNiv2=T_var_Wrinkles(<1.12,1.1,1.1>,C_marronA1,C_marronA2,C_marronA3,C_marronA4,C_marronA5,1,0)
#declare
T_marron_MacroNiv3=T_var_Wrinkles(<1.32,1.3,1.3>,C_marronA1,C_marronA2,C_marronA3,C_marronA4,C_marronA5,1,0)
#declare
T_marron_MacroNiv4=T_var_Wrinkles(<1.52,1.5,1.5>,C_marronA1,C_marronA2,C_marronA3,C_marronA4,C_marronA5,1,0)
//Texture de la roche des pentes avec sols marrons
#declare T_rocheGriseA=T_var_Wrinkles(<1.3, 1.15,
1>,Gray80,Gray70,Gray60,Gray50,Gray40, 1,0)
#declare T_rocheGriseA2=texture{T_rocheGriseA finish{specular 0.2 diffuse 0.4
ambient 0.24} normal{granite 0.6 scale 0.1}}
File #3 : pentes_v3_x128.pov
#version 3.7;
global_settings{assumed_gamma 1.0}
#declare Anim_Serie=true;
#declare xN=128;
#declare HeightField=true;
#declare Mesh=false;
#declare Photo=true;
#include "textures_JeuM_v3.inc"
#declare T_transition1_2 = texture{gradient y texture_map{[0.0
T_marron_MacroNiv1][0.1 T_rocheGriseA2][0.9 T_rocheGriseA2][1.0
T_marron_MacroNiv2]}};
#declare T_transition2_3 = texture{gradient y texture_map{[0.0
T_marron_MacroNiv2][0.1 T_rocheGriseA2][0.9 T_rocheGriseA2][1.0
T_marron_MacroNiv3]}};
#declare T_transition3_4 = texture{gradient y texture_map{[0.0
T_marron_MacroNiv3][0.1 T_rocheGriseA2][0.9 T_rocheGriseA2][1.0
T_marron_MacroNiv4]}};
#declare tps=clock;
#if (Photo =true)
camera{
       orthographic
       location <0.000001,20,0>
       look_at <0,0,0>
       direction -y
       sky z
  up 2*z
  right 2*x
#else
camera{location <2.5,4,2.5> look_at <0,1,0>}
light_source{<10,20,10>*100 color rgb 1}
height_field{jpg
             #if (Anim_Serie=true)
                     #if (tps>=0 & tps<4)
                        "HF_x128_lineaire1"
                     #if (tps>=4 & tps<8)
                        "HF_x128_lineaire2"
                     #if (tps>=8 & tps<12)
                        "HF_x128_coin1"//Orniere
                     #if (tps>=12 & tps<16)
             smooth
             translate <-0.5,0,-0.5>
             rotate 90*tps*y
             scale <2,1,2>
             texture{T_transition1_2}
             scale <1,4,1>
             no_shadow
And the ini file for an auto renderer
-w128
-h128
+a0.3
+KFI0
+KFF15
+KI0
+KF15
+Ipentes_v3_x128.pov
+Ooutput/rr12_x128_.png
+Q9
Date: 1 Dec 2015 12:00:01
Message: <web.565dd1914f56292ca73f5e290@news.povray.org>
I got what I expected in windows 10 with the files mentioned above and the
images you told about but once in Linux Ubuntu (with my laptop, with the desktop
pc I get the expected pictures )I get a pack of 16 totally black pictures.
Lately I tried to tweak the admin rights in folders, removing non ASCII
characters, but it still doesn't work.
I will copy the file of Ubuntu desktop to the Ubuntu laptop. But don't worry
about that , it works on my desktop computer, it's just that I' d like to solve
the problem :(.
Date: 1 Dec 2015 13:16:07
Message: <565de3e7$1@news.povray.org>
Am 01.12.2015 um 17:57 schrieb Warren:
> the problem :(.
It's quite apparent to me at this point that /something/ is fishy about
the POV-Ray binary you're using on your laptop.
This immediately raises the following questions:
- Do any of the sample scenes render properly on your laptop?
- What does "povray --version" output on the two Ubuntu computers?
- What versions of Ubuntu are you using on the two machines?
My current best bet is that you're using a different version of POV-Ray
on the laptop machine, and that there's some bug in that version. If
that is the case, I'd really like to get down to the bottom of it.
Date: 1 Dec 2015 14:05:01
Message: <web.565dee2e4f56292ca73f5e290@news.povray.org>
On the desktop PC in the terminal after a "povray --version" I get :
antoine@PCMapex:~$ povray --version
POV-Ray 3.7.0.unofficial
This is an unofficial version compiled by:
 Antoine FAURE (that's me :) )
 The POV-Ray Team is not responsible for supporting this version.
Copyright 1991-2013 Persistence of Vision Raytracer Pty. Ltd.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Built-in features:
  I/O restrictions:          enabled
  X Window display:          enabled (using SDL)
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
  Unsupported image formats: openexr
Compilation settings:
  Build architecture:  x86_64-unknown-linux-gnu
  Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
  Compiler vendor:     gnu
  Compiler version:    g++ 4.8
  Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread
whereas on the laptop it gives :
antoine@antoine-Presario-V6000:~$ povray --version
 Felix Geyer <deb### [at] ubuntucom> for Debian <www.debian.org>
Built-in features:
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff openexr
  Unsupported image formats: -
  Build architecture:  x86_64-pc-linux-gnu
  Built/Optimized for: x86_64-pc-linux-gnu
-fno-enforce-eh-specs -g -O2 -fstack-protector --param=ssp-buffer-size=4
-Wformat -Werror=format-security -O3 -pthread
And yes, on the laptop I installed povray via the depots "trusty backports"
whereas on the desktop PC I compiled the sources I download on www.povray.org.
Date: 2 Dec 2015 10:55:00
Message: <web.565f13ff4f56292ca73f5e290@news.povray.org>
Hi , everybody
I have good news. :)
I removed povray I get from the depots "trusty backports" and installed povray
with the source code from www.povray.org > github and the code I posted in the
post above works fine now. I tested the render example after compiling the new
povray and that was good too.
I want to thank all those who were willing to help me. :)
Antoine.
