![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I use POV-RAY as it is supports rending of 3D model done on ZW3D 2014. I have
been using it and I could render the 3D models without any problem. But of late,
I do not know why, when ever I try to render using POV ray, an error message
appears stating"Possible Parse Error: Cannot find file
'C:\Users\Admin\AppData\Roaming\ZW3D 2014 Eng (x64)\MAP003.bmp', even after
trying to append file type extension.
Possible Parse Error: Cannot find image file. ". I have reinstalled POV ray, I
reinstalled ZW3D, but to no avail.
Please let me know, how to rectify this problem.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
First thing jumping to my eyes: space in directory path.
Second thing: parenthesis in directoty path.
And then colon in pathname.
Did you add successfully with -L option that directory in the path to
search ?
Look at the message tab at the start of the rendering, it lists the
library paths.
And what is the current setting of script I/O restriction (in Option
sub-menu, it is both about script and I/O, not I/O of scripts) ?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Have you checked whether this file actually exists?
Possibly there is a mixup of accounts, e.g. if data for ZW3D
was installed for different user than Admin.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
To tell you the truth. I do not know anything about coding. There is a button in
ZZW3D called render, when I press that, POVray would open and a rendered image
would be created.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No it has been installed in the correct account. some parts still get rendered.
But some parts don't
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No, apparently MAP003.bmp doesn't exist.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 03.10.2015 um 12:55 schrieb Madhav Shenoy:
That would indicate a problem on the ZW3D side: It generates a scene
file that tells POV-Ray to load a file named MAP003.bmp (presumably a
texture image of sorts), but fails to provide that MAP003.bmp.
So given that ZW3D is a commercial product, and the problem seems to be
on the ZW3D side, I definitely recommend contacting their customer
support on this issue.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
