POV-Ray : Newsgroups : povray.newusers : backlight on object Server Time
14 Dec 2025 16:53:43 EST (-0500)
  backlight on object (Message 1 to 3 of 3)
Subject: backlight on object
Date: 13 Aug 2015 02:55:00
Message: <web.55cc3ecb671d36b35e6001040@news.povray.org>
Hi, I try to put a light source in the back of a LEGO creation with transparent
pieces to create backlight pass through its pieces.You have a setting of light
that could accomplish this?
Subject: Re: backlight on object
Date: 13 Aug 2015 14:50:01
Message: <web.55cce6622825befd37e11ae60@news.povray.org>
So far as I understand your question, every lightsource behind the lego block
shedding light on the block will work. A spotlight pointing in an other
direction wan't work. May be it is more important in your case that the lego
block has the proper material (transparency, ior). If you are going for caustics
you should study the tutorial within the docs first.
Diffuse backside illumination as demonstrated by Christoph Lipka (a.k.a. clipka)
within the POV sample files (diffuse_back.pov) is another issue.
Best regards,
Michael
Date: 16 Aug 2015 13:30:18
Message: <55d0c8aa$1@news.povray.org>
Any normal light will work.
The backside illumination only work for single surfaces. So, you need a
workaround:
 From fastest to slowest.
1) You can add interior_texture with  pigment{rgbt 1}. That way, the
visible surface "see" right through the other surface.
2) You can use radiosity with at least 2 bounces. If you have any
interior structures, you'll probably need recursion_limit 4 or more, and
it get real slow.
3) You can use the new SSLT mechanism where you define a translucency
for your material along with an ior around 1.5. When the translucency
value become larger than the thickness of the object, you start to see
whatever is behind the object. In the global_settings section, set
mm_per_unit according to the scene scale. The default (10) is for a
scene where 1 unit = 1 cm = 10 mm. Set to about 25 for a scene in inches.
For the transparent pieces, you need an interior block defining:
fade_colour
fade_distance
fade_power 1 or fade_power 1001
ior 1.5 (or close to that)
optionaly, some scattering or absorbing media matching the colour of the
blocks.
The pigment for those should be something like rgbf 0.95 or rgbt 0.95 as
the colour comes from the material itself and not the surface.
