POV-Ray : Newsgroups : povray.newusers : "Fade away" overlay for existing objects Server Time
26 Mar 2026 01:15:01 EDT (-0400)
  "Fade away" overlay for existing objects (Message 1 to 10 of 10)
Subject: "Fade away" overlay for existing objects
Date: 23 Jun 2015 14:45:00
Message: <web.5589a875d9d19c39f3d9f53f0@news.povray.org>
I have a finished scene made out of different objects.
Now I want to focus on the middle of this scene, for this I would like to have a
particular area (such as a simple circle) sharp and unperturbed and with
increasing radius I want the rest of the scene to gently fade away into the
blank white background. The fading should look like this just in a circular
manner
starting from the center of the image:
https://www.flickr.com/photos/portier/3969225787
I tried to put a torus around the part of the scene that I want to focus on
and make it transparent or White but it does not
really work and the "White" of the torus is also not really mixing with the
white
background, this is probably due to some shadow effects. I'm sure there must be
a simple solution for this... Thanks for your help!
Subject: Re: "Fade away" overlay for existing objects
Date: 23 Jun 2015 16:15:00
Message: <web.5589be2c7840cf75f3d9f53f0@news.povray.org>
In the meantime i stumbled upon the fog feature. It does exactly what I want
except that I can only define a plane but not really another geometry:
 fog{ fog_type 2
      distance  3
      color     White
      fog_offset -5.5
      fog_alt    2.0
      turbulence 1.8
      up <-0.5,1,0>
This would be great if I could somehow define a center point where the fog
then starts expanding like a sphere, obscuring everything.
Date: 23 Jun 2015 17:05:40
Message: <5589ca24@news.povray.org>
>   fog{ fog_type 2
>        distance  3
>        color     White
>        fog_offset -5.5
>        fog_alt    2.0
>        turbulence 1.8
>        up <-0.5,1,0>
If you want sometning circular, the disk may be what you need:
disk{<0,0,0>, <0,0,-1>, 1 pigment{spherical colour_map{[0 rgb
background_colour][clock background_colour filter 1] } scale Some_Scale
translate Somewhere hollow}
If your scene use any media or fog, the hollow is needed it you want the
media or fog to act predictably. A disk have an interior that is the
same as that of a plane and it's not limited to the visible part.
You may also use a plane similarly.
This, in an animation, will start with a totaly transparent disk that
will become increasingly opaque in a circular gradient. The center will
stay transparent. Using the background's colour and manipulating the
filter component ensure that the mix will be concistent.
Another way would be with some media. The density of a media can be
exactly controled by a pigment of any function. The spherical pattern
start with a value of zero at the origin and drop to zero at a radius of
1. This can be changed by using a colour_map and an alternate wave type
for the way it changes, and by scaling to adjust it to your needs.
Date: 23 Jun 2015 17:19:43
Message: <5589cd6f$1@news.povray.org>
Am 23.06.2015 um 22:14 schrieb severedo:
>   fog{ fog_type 2
>        distance  3
>        color     White
>        fog_offset -5.5
>        fog_alt    2.0
>        turbulence 1.8
>        up <-0.5,1,0>
Have you looked at media yet?
Date: 23 Jun 2015 22:25:43
Message: <558a1527@news.povray.org>
>   fog{ fog_type 2
>        distance  3
>        color     White
>        fog_offset -5.5
>        fog_alt    2.0
>        turbulence 1.8
>        up <-0.5,1,0>
In addition to what has been suggested a couple other possible methods
come to mind.
1) I've never done it, but with fog you are not limited to one use in a
scene meaning you could declare a base fog and then instantiate several
copies of it, rotating each variously around your "axis of clarity." Not
sure what happens with the fog where the regions of fog overlap.
2) You could try the aoi pattern with a plane in front of the camera. I
tried this myself just now with the code below. Simple tuning is
possible by playing with the color map in the example, more complex
foggy looks can be achieved by using the aoi pattern with more complex
pigments/textures in a map. Whether enough to get the effect you really
want not sure.
Good hunting.
Bill P.
//-------------------- fadeFromCenter.pov -----------------------
#version 3.7;
global_settings {
     assumed_gamma 1
     ambient_light srgb <1,1,1>
#declare Grey50 = srgbft <0.5,0.5,0.5,0,0>;
background { color Grey50 }
#declare CameraLocation = <4.50,4.50,-4.501>;
#declare CameraLookAt = <0.0,0.0,0.0>;
#declare Camera00 = camera {
     perspective
     location CameraLocation
     sky <0,1,0>
     angle 35
     right x*(image_width/image_height)
     look_at CameraLookAt
#declare White = srgbft <1,1,1,0,0>;
#declare Light00 = light_source { <50,150,-250>, White }
#declare Brown_Bramble = srgbft <0.349,0.1569,0.01569,0,0>;
#declare PlaneY = plane { <0,1,0>, 0
     pigment { color Brown_Bramble }
#include "transforms.inc"
#declare TransformToCam = transform {
     Reorient_Trans(<0.0,-1.0,0.0>,CameraLookAt-CameraLocation)
     translate CameraLocation
#declare PlaneCamera = plane { <0,1,0>, -1
     transform TransformToCam
#declare Red = srgbft <1,0,0,0,0>;
#declare CylinderX = cylinder {
     <-10,0,0>, <10,0,0>, 0.01
     pigment { color Red }
#declare Green = srgbft <0,1,0,0,0>;
#declare CylinderY = cylinder {
     <0,-10,0>, <0,10,0>, 0.01
     pigment { color Green }
#declare Blue = srgbft <0,0,1,0,0>;
#declare CylinderZ = cylinder {
     <0,0,-10>, <0,0,10>, 0.01
     pigment { color Blue }
#declare ColorImageCenter = srgbft <1,1,1,0,1>;
#declare ColorImageEdge = srgbft <1,1,1,0,0>;
#declare ColorMap_AOIfade = color_map {
     [ 0 ColorImageEdge ]
     [ 0.75 ColorImageEdge ]
     [ 0.975 ColorImageCenter ]
     [ 1 ColorImageCenter ]
#declare Pigment_AOIfade = pigment { aoi color_map { ColorMap_AOIfade }}
#declare Texture_AOIfade = texture { pigment { Pigment_AOIfade } }
#declare ObjCameraPlane = object {
     object { PlaneCamera }
     texture { Texture_AOIfade }
     hollow no_shadow
camera { Camera00 }
light_source { Light00 }
object { CylinderX }
object { CylinderY }
object { CylinderZ }
object { PlaneY }
object { ObjCameraPlane }
Date: 24 Jun 2015 05:04:07
Message: <558a7287$1@news.povray.org>
>      hollow no_shadow
Woke up with the thought the plane in front of the camera should also
have :
     no_reflection
     no_radiosity
to not cause side effects for scenes with reflection/radiosity.
Bill P.
Date: 24 Jun 2015 06:46:38
Message: <558a8a8e$1@news.povray.org>
> have :
You Know That You Have Been Raytracing To Long, when... :-P
Regards
Date: 24 Jun 2015 12:28:46
Message: <558adabe@news.povray.org>
>> I want
>>   fog{ fog_type 2
>>        distance  3
>>        color     White
>>        fog_offset -5.5
>>        fog_alt    2.0
>>        turbulence 1.8
>>        up <-0.5,1,0>
>> fog
> come to mind.
When several fog overlap, their effects are added.
Date: 27 Jun 2015 12:05:01
Message: <web.558ec8e97840cf7550cbefc00@news.povray.org>
> manner
> white
This sounds like media with a radial density map to me. Adding a little
turbulence will finish it off nicely.
-Nekar Xenos-
Date: 17 Jul 2015 13:45:57
Message: <55a93f55@news.povray.org>
Sorry for the very late reply. I haven't been here in awhile.
You probably already figure out what to use on this project.
But I have something that might help on other projects.
Why not use post production techniques with POV?
Use picture as an image_map pigment then use that pigment in a
pigment_map with other pigments. You could use any pattern to put them
together as you like!
I've already made a system for animating fades for POV animations.
You can download it Here
http://leroywhetstone.s5.com/Pages/PovFiles.html#Tools
