POV-Ray : Newsgroups : povray.newusers : UV texture scale center Server Time
14 Dec 2025 16:53:30 EST (-0500)
  UV texture scale center (Message 1 to 10 of 19)
Subject: UV texture scale center
Date: 22 Jan 2015 09:10:00
Message: <web.54c103967eea5e3a6ee70590@news.povray.org>
Hello, I am meeting a problem with the scale keyword used for texture, it seems
that the POV scale factor and repetition factor in Blender do not use the same
center. I would guess that Blender seems to scale the texture from the zero of
the UV space, like in this picture, it is scaled by half (repeat factor of 2)
http://www.pasteall.org/pic/show.php?id=82692
while POV maybe from the 1, I don't know can someone tell me?
it's result, with a scale of 0.5 is this:
http://www.pasteall.org/pic/show.php?id=82693
My goal is to have both pictures always the same whatever the blender interface
parameters for texture scale are.
I don't know if this has always been the case, it seems that some images
rendered
with early 3.7 betas did not behave this way and were more consistent with
Blender renders, but I may be wrong.
Subject: Re: UV texture scale center
Date: 22 Jan 2015 10:10:38
Message: <54c112ee$1@news.povray.org>
Am 22.01.2015 um 15:06 schrieb Mr:
> rendered
In POV-Ray, if you scale any texture, the origin of scaling is at
<0,0,0>. For UV-mapped textures, UV-mapping is applied after scaling
(you're UV-mapping the scaled texture).
At least that's what should happen. If closer investigation shows it
doesn't, please let us know.
Date: 22 Jan 2015 14:28:08
Message: <54c14f48@news.povray.org>
> rendered
Apart from the lighting and highlights, those two images are prety
similar. The details are prety much in the same locations.
Remember that in POV-Ray, ALL transforms are always relative to the
origin : <0,0,0>
Date: 24 Jan 2015 05:30:00
Message: <web.54c374131bfbdbf6c31ce6010@news.povray.org>
> > rendered
So instead of this exemple:
 #declare MAT_MaterialTex =
texture{
    pigment_pattern {
        uv_mapping image_map{
"F:\BlenDivers\Scenes\blenderpovrayTestScenes\TexturesTest\textures\SpecularTest.png"
map_type 0  interpolate 2 }
        translate <-0,0,0> scale <1,1,1>
    texture_map {
        [0
                pigment_pattern {
"F:\BlenDivers\Scenes\blenderpovrayTestScenes\TexturesTest\textures\AlphaTest.png"
map_type 0  interpolate 2 } translate <-0,-0,0> scale <1,1,1>}
                pigment_map {
                    [0 color rgbft<0,0,0,1,1>]
                    [1 uv_mapping image_map {
"F:\BlenDivers\Scenes\blenderpovrayTestScenes\TexturesTest\textures\DiffuseTest.png"
map_type 0  interpolate 2 } translate <0.25,0,-1> scale <1.5,1,1>]
            finish {shader_MaterialTex0}
            normal {uv_mapping bump_map {
"F:\BlenDivers\Scenes\blenderpovrayTestScenes\TexturesTest\textures\BumpTest.png"
map_type 0  interpolate 2   bump_size 10 } translate <-0,-0,0> scale <1,1,1>}
        [1
            pigment {pigment_pattern {uv_mapping image_map{
map_type 0  interpolate 2 }translate <-0,-0,0> scale <1,1,1>}
                pigment_map {
map_type 0  interpolate 2 } translate <0.25,0,-1> scale <1.5,1>]
            finish {shader_MaterialTex1}
The shader should have other brackets? I can't seem to move the scale closer to
the texture.
Date: 24 Jan 2015 09:30:59
Message: <54c3aca3$1@news.povray.org>
Am 24.01.2015 um 11:29 schrieb Mr:
> texture{
>      pigment_pattern {
>      texture_map {
>          [0
>              pigment {
>                  pigment_pattern {
>                  pigment_map {
Beware - you're moving the texture here, not just scaling it!
Note again that scaling /always/ has its origin at <0,0,0>; if you do
this /after/ translation, it's no longer the <0,0> of the image, but
rather its <-0.25,0>. To scale from the /image's/ <0,0>, you need to
scale first, and only then translate; you'll probably need to fix the
translation vector though:
     scale <1.5,1,1> translate <1.5,1,1>*<0.25,0,-1>
Date: 24 Jan 2015 15:05:01
Message: <web.54c3f9bf1bfbdbf6c31ce6010@news.povray.org>
> > texture{
> >      pigment_pattern {
> >      texture_map {
> >          [0
> >              pigment {
> >                  pigment_pattern {
> >                  pigment_map {
This looks almost ok, thank you, but not yet :
Here is the Blender result
http://www.pasteall.org/pic/show.php?id=82782
it uses repeat factor of 0.75
And here is POV
http://www.pasteall.org/pic/show.php?id=82783
It uses scale factor of 1/0.75 = 1.33
and the method you advised for translation
the translate I have to add to get closer to the original is of <-0.175,0,0> but
this is not constant: with a slightly higher tiling number still under 1 it
reduces slightly closer to <0,0,0>
I'm at a loss. what's happening here?
Date: 24 Jan 2015 15:15:58
Message: <54c3fd7e$1@news.povray.org>
Am 24.01.2015 um 21:02 schrieb Mr:
> And here is POV
Can you post the generated POV-Ray code for this particular case?
My best bet is that you still have some translate lurking before the
scaling.
Date: 24 Jan 2015 15:19:31
Message: <54c3fe53$1@news.povray.org>
Am 24.01.2015 um 15:30 schrieb clipka:
I think I wrote nonsense here: Translating after scaling, but with the
scaling factor applied to the translation, has /exactly/ the same effect
as your translating before scaling.
The proper question here would be, why is there a translate in there at
all, and exactly what effect is it supposed to have?
Date: 24 Jan 2015 15:35:00
Message: <web.54c401291bfbdbf6c31ce6010@news.povray.org>
The translate is there in many 3d editors. it's a bad legacy, but it alows to
offset a texture in the UV space if it's a tiled texture and yu don't want to
change the uv unwraping,  you can offset the texture itself. itc can be used as
a quick hack to hide some visible seam or pattern in textures not repeating too
much. For textures repeating a lot, some people use it to tweak the exact phase
regarding geometry of some tiled patterns (like pavement over some steps,
etc...)
Here is the complete scene for this particular case:
//--Exported with POV-Ray exporter for Blender--
#version 3.7;
//--Global settings--
global_settings {
    assumed_gamma 1.0
    max_trace_level 5
    ambient_light rgb<0, 0, 0>
//--Custom Code--
#declare CURFRAMENUM = 1;
//#include "/home/user/directory/animation_include_file.inc"
//--Patterns Definitions--
 #declare PAT_Alpha =
#declare fPAT_Alpha=
function{pigment{PAT_Alpha}}
 #declare PAT_Bump =
#declare fPAT_Bump=
function{pigment{PAT_Bump}}
 #declare PAT_Diffuse =
#declare fPAT_Diffuse=
function{pigment{PAT_Diffuse}}
 #declare PAT_Specular =
#declare fPAT_Specular=
function{pigment{PAT_Specular}}
//--Background--
background {rgbt<0.0509, 0.0509, 0.0509, 0>}
//--Cameras--
#declare camLocation  = <7.481132, 5.343666, 6.507640>;
#declare camLookAt = <-27.098163, 46.688390, -0.903519>;
    location  <0, 0, 0>
    look_at  <0, 0, -1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  49.134343
    rotate  <-27.098163, 46.688390, -0.903519>
    translate <7.481132, 5.343666, 6.507640>
//--Lamps--
light_source {
    < 0,0,0 >
    color rgb<1, 1, 1>
    fade_distance 14.999991
    fade_power 2
    matrix <-0.290865, -0.055189, -0.955171,  -0.771101, 0.604525, 0.199883,
0.566393, 0.794672, -0.218391,  -0.547114, 2.224058, -1.255785>
#declare lampTarget1= vrotate(<0.5471,-1.256,-2.224>,<0.6503,0.05522,1.866>);
//--Material Definitions--
#default{ pigment{ color rgb 0.8 }}
#declare shader_ = finish {  //translation of spec and mir levels for when no
map influences them
    diffuse 0.8
    phong 70.0
#declare shader_MaterialBlack = finish {  //translation of spec and mir levels
for when no map influences them
    brilliance 1.8
    phong 0.5
    phong_size 25.2
    diffuse 0.8 0
    ambient 1
    emission 0
    conserve_energy
#declare shader_MaterialTex = finish {  //translation of spec and mir levels for
    brilliance 1.8
    phong 0.5
    phong_size 25.2
    diffuse 0.2 0
    ambient 1
    emission 0
    conserve_energy
#declare shader_MaterialTex0 = finish {  //No specular nor Mirror reflection
    brilliance 1.8
    specular 0
    diffuse 0.2 0
    ambient 1
    emission 0
    conserve_energy
#declare shader_MaterialTex1 = finish {  //Maximum Spec and Mirror
    specular 1
    diffuse 0.2 0
    ambient 1
    emission 0
    conserve_energy
//--Mesh objects--
#declare DATACube =
mesh2 {
    vertex_vectors {
        8,
        <1.000000, 1.000000, -1.000000>,
        <1.000000, -1.000000, -1.000000>,
        <-1.000000, -1.000000, -1.000000>,
        <-1.000000, 1.000000, -1.000000>,
        <1.000000, 0.999999, 1.000000>,
        <0.999999, -1.000001, 1.000000>,
        <-1.000000, -1.000000, 1.000000>,
        <-1.000000, 1.000000, 1.000000>
    normal_vectors {
        6,
        <0.000000, 0.000000, -1.000000>,
        <-0.000000, -1.000000, -0.000000>,
        <1.000000, -0.000000, 0.000000>,
        <-1.000000, 0.000000, -0.000000>,
        <0.000000, 1.000000, 0.000000>,
        <0.000000, -0.000000, 1.000000>
    uv_vectors {
        14,
        <0.000000, 1.000000>,
        <1.000000, 2.000000>,
        <-1.000000, 1.000000>,
        <0.000000, 0.000000>,
        <-1.000000, 0.000000>,
        <1.000000, -2.000000>,
        <2.000000, 1.000000>,
        <0.000000, 2.000000>,
        <2.000000, 0.000000>,
        <0.000000, -1.000000>,
        <0.000000, -2.000000>,
        <1.000000, 0.000000>,
        <1.000000, -1.000000>,
        <1.000000, 1.000000>
texture{
    pigment_pattern {
    texture_map {
        [0
                pigment_pattern {
                pigment_map {
map_type 0  interpolate 2 } scale <1.333,1,1> translate <1.333,1,1>*<0,0,0>]
        [1
                pigment_map {
 #declare MAT_MaterialBlack =
texture{
pigment {rgbft<0, 0, 0, 0, 0>}
finish {shader_MaterialBlack}
texture{
pigment_pattern {
texture_map {
    [0
            pigment_pattern {
            pigment_map {
    [1
            pigment_map {
texture_list {
        2
 texture{MAT_MaterialBlack}
 texture{MAT_MaterialTex}
face_indices {
    12,
    <0,1,2>, 0,0,0,
    <0,2,3>, 0,0,0,
    <4,7,6>, 1,1,1,
    <4,6,5>, 1,1,1,
    <0,4,5>, 0,0,0,
    <0,5,1>, 0,0,0,
    <1,5,6>, 0,0,0,
    <1,6,2>, 0,0,0,
    <2,6,7>, 0,0,0,
    <2,7,3>, 0,0,0,
    <4,0,3>, 0,0,0,
    <4,3,7>, 0,0,0
normal_indices {
    12,
    <0,0,0>,
    <0,0,0>,
    <5,5,5>,
    <5,5,5>,
    <2,2,2>,
    <2,2,2>,
    <1,1,1>,
    <1,1,1>,
    <3,3,3>,
    <3,3,3>,
    <4,4,4>,
    <4,4,4>
uv_indices {
    12,
    <3,11,13>,
    <3,13,0>,
    <9,10,5>,
    <9,5,12>,
    <3,9,12>,
    <3,12,11>,
    <11,8,6>,
    <11,6,13>,
    <13,1,7>,
    <13,7,0>,
    <4,3,0>,
    <4,0,2>
interior {
    ior 1.000000
    caustics 0.5
radiosity {
    importance 0.5
//----Blender Object Name:OBCube----
object {
    DATACube
    matrix <-1.000000, -0.000000, -0.000000,  -0.000000, 0.000000, 1.000000,
0.000000, 1.000000, -0.000000,  0.000000, 0.000000, 0.000000>
Date: 24 Jan 2015 15:56:59
Message: <54c4071b@news.povray.org>
I'm wondering right now, could it be that blender scales textures (at
least when UV-mapped) from their center (i.e. <0.5,0.5>) rather than the
corner (<0,0>)?
In that case you'd need to use:
     translate <-0.5,-0.5,0>
     scale <1/REPEAT_X,1/REPEAT_Y,1>
     translate <0.5,0.5,0>
or, to save one translate:
     translate <0.5-0.5/REPEAT_X,0.5-0.5/REPEAT_Y,0>
or:
     translate <0.5*REPEAT_X-0.5,0.5*REPEAT_Y-0.5,0>
     scale <1/REPEAT_X,1/REPEAT_X,1>
