POV-Ray : Newsgroups : povray.newusers : DPI Server Time
18 Nov 2025 11:31:27 EST (-0500)
  DPI (Message 1 to 5 of 5)
Subject: DPI
Date: 11 Dec 2014 12:05:01
Message: <web.5489ce493d69586ecdec06170@news.povray.org>
Hi all,
Is it 96 DPI that the highest image resolution obtained from POV Ray? I was
wondering how to get an image with 300 DPI  which is normally required for
journal paper printing. Thanks for any help.
Best regards
Jingming
Subject: Re: DPI
Date: 11 Dec 2014 13:10:00
Message: <web.5489dcf2f894376cd19b0ec40@news.povray.org>
"Jingming" <lon### [at] ymailcom> wrote:
> Hi all,
> Best regards
> Jingming
Just render at a higher resolution. That's pretty much all it really means.
eg. if you have an 11" screen at 1366x768, that screen has a lower DPI than if
the screen had a resolution of 1920x1080 (ok, technically it's pixels per inch
on a monitor).
Subject: Re: DPI
Date: 11 Dec 2014 15:29:18
Message: <5489fe9e$1@news.povray.org>
>> Hi all,
>> Best regards
>> Jingming
> on a monitor).
In other words, at 300dpi a 4inx6in image would be 1200x1800, the actual
DPI setting would need to be set in another program like GIMP or
Photoshop, if the publisher requires the DPI to be set in the image for
proper scaling.
Subject: Re: DPI
Date: 11 Dec 2014 20:17:33
Message: <548a422d$1@news.povray.org>
> Hi all,
> Best regards
> Jingming
POV-Ray have no "knowlege" of DPI value, it only deal in units and
pixels. The DPI value contained in any image is realy meaningless.
If you want an image of, say, 6" whide by 3" high, to be printed at 300
DPI, you take the size and multiply it by 300.
In this case, it gives a 1800 by 900 pixels image.
When printing, you can very easily get away with a much lower
resolution. There is a thing called interpolation, and another called
dithering with an option called error diffusion that was available for
consumer grade printers back in the 90's that can take a 100 DPI image
and print it at 1400 DPI with NO visible noise, no pixelisation and no
discernebale image degradation... Professional printers and softwares
have much more advanced and robust similar features.
I remember a time when photos in news papers where about 10 to 12 DPI...
If the image is about 1m on a side, typical for a poster, then, about
100 DPI is about "retina" resolution.
Subject: Re: DPI
Date: 15 Dec 2014 04:45:06
Message: <web.548eac85f894376ccdec06170@news.povray.org>
> Hi all,
> Best regards
> Jingming
Thanks a lot for help!
