POV-Ray : Newsgroups : povray.newusers : Show result in default image editor after rendering Server Time
14 Apr 2025 11:45:43 EDT (-0400)
  Show result in default image editor after rendering (Message 1 to 2 of 2)
Subject: Show result in default image editor after rendering
Date: 11 Dec 2014 08:05:01
Message: <web.548996148b9f8db3cb72b3c0@news.povray.org>
Hi all,
I'm wondering how I can do that.
I use the /EXIT parameter in the command line, so I probably need to shell to
Windows as soon as the render is done.
How I do that exactly I don't know. I tried to put
Post_Scene_Command = explore %o
in the INI file, but that does not seem to work.
Any help is appreciated.
Dick
Subject: Re: Show result in default image editor after rendering
Date: 11 Dec 2014 09:58:10
Message: <5489b102$1@news.povray.org>
On 12/11/2014 7:03 AM, Dicko wrote:
> Hi all,
> Regards,
> Dick
A couple things will need to happen:
1) In the options menu under script I/O restrictions uncheck the
"Disable starting other prorgams" item, if it is checked.
2) You'll need to do this in a batch file:
--- batch file content ---
start %1
-- end batch file content
Place the batch file in a known location, then alter your post-scene
command to the following:
Post_Scene_Command = [path where you dropped the batch
file]\openimage.bat %o
Explore isn't a command I know of, but start will open the file in the
default editor.
Have fun!
~Mike
