POV-Ray : Newsgroups : povray.newusers : How to print a color generated by a macro? Server Time
31 May 2024 22:26:33 EDT (-0400)
  How to print a color generated by a macro? (Message 1 to 3 of 3)
Subject: How to print a color generated by a macro?
Date: 25 Aug 2014 22:35:02
Message: <web.53fbf1308ac336b8784e7dc60@news.povray.org>
Hi, I have the following macro (simplified for brevity).
#macro ColorFromBurgers(burgers)
/* good 11-color map from http://colorbrewer2.org
  #warning concat("Got burgers value: ",str(burgers,0,0),"\n")
  #switch(burgers)
 #range (-5,-1)
   rgb <141,211,199>/255.0
 #break
 #case (0)
   rgb <255,255,179>/255.0
 #break
 #case (10)
   rgb <190,186,218>/255.0
 #break
I want to print out the color my macro is returning somehow.
I've tried the following with no success:
First I tried:
#warning concat("The color is ",ColorFromBurgers(burger),"\n")
but I get an error about not having three arguments.
File Context (5 lines):
          rgb <251,128,114>/255.0
        #break
        #case (12)
          rgb <128,177,211>/255.0
Parse Error: Expected 3 parameters but only 1 found.
Strange that none of the lines seems to be anything that needs 3 parameters.
Tried a couple other things, but nothing seems to work.
The last thing i just tried before giving up was this:
   #declare c = color ColorFromBurgers(burger);
   #declare s = CRGBStr(color c ,0,0);
   #warning concat("The color is ",s,"\n")
I get
Parse Error: All #declares of float, vector, and color require semi-colon ';' at
 end if the language version is set to 3.5 or higher. Either add the semi-colon
 or set the language version to 3.1 or lower.
Help!  Thanks
Subject: Re: How to print a color generated by a macro?
Date: 25 Aug 2014 23:41:41
Message: <53fc01f5@news.povray.org>
Am 26.08.2014 04:30, schrieb wealthychef:
>    #switch(burgers)
>   #range (-5,-1)
>   #break
>   #case (0)
>   #break
>   #case (10)
>   #break
> #end
> #end
> First I tried:
>          #break
>          #case (12)
"Returning" values from within control structures in a macro can be
troublesome; try something like this:
     #switch(burgers)
       #range(-5,-1)
         #local Result = rgb <141,211,199>/255.0;
       #break
       #case (0)
         #local Result = rgb <255,255,179>/255.0;
       #break
       #case (10)
         #local Result = rgb <190,186,218>/255.0;
       #break
     Result
As for printing the result, remember that colours are vector-like
beasts, so vstr() should do the job.
Date: 26 Aug 2014 18:35:01
Message: <web.53fd0a77246d976e784e7dc60@news.povray.org>
> > I've tried blah blah blah... FAIL
>      #switch(burgers)
>        #range(-5,-1)
>        #break
>        #case (0)
>        #break
>        #case (10)
>        #break
>      #end
>      Result
>    #end
Thank you so much for the help!  Cheers.  That worked great.
