POV-Ray : Newsgroups : povray.newusers : Can't find bad scale values. Server Time
27 Jul 2024 18:21:07 EDT (-0400)
  Can't find bad scale values. (Message 1 to 2 of 2)
Subject: Can't find bad scale values.
Date: 29 Jul 2014 19:45:00
Message: <web.53d8316aea0cbcc5e7df57c0@news.povray.org>
I get a lot of parse warnings about scaling by 0.
I've searched for "scale" through the entire file and all the includes, and
can't find any "bad" scalings.  Does this behaviour happen when a single scale
value like scale 5 is automagically promoted by POV-Ray to scale <5, 5, 5> ?
I'm just trying to clean up the code so that I have a "clean" message window and
therefore an easier time debugging ongoing scene development.
It would be helpful to quote the offending line's text, or line number (harder
to do with includes?).
I could also use a hand figuring out exactly what the camera error means.
Parse Warning: Illegal Value: Scale Z by 0.0. Changed to 1.0.
Parse Warning: Illegal Value: Scale X by 0.0. Changed to 1.0.
Parse Warning: Illegal Value: Scale Y by 0.0. Changed to 1.0.
Parse Warning: Should have at least 2 objects in csg.
Parse Warning: Camera location to look_at direction and sky direction should be
different. Using default/supplied right vector
instead.
Subject: Re: Can't find bad scale values.
Date: 29 Jul 2014 21:23:26
Message: <53d8490e$1@news.povray.org>
Am 30.07.2014 01:42, schrieb Bald Eagle:
No, it happens when you try to scale along a particular axis using:
     scale y*N
because from POV-Ray's syntax this is equivalent to
     scale <0,N,0>
which would make the thing a flat pancake, so POV-Ray presumes that what
you actually meant was
     scale <1,N,1>
