POV-Ray : Newsgroups : povray.newusers : Complicated texturing problem Server Time
29 May 2024 04:52:55 EDT (-0400)
  Complicated texturing problem (Message 11 to 11 of 11)
Subject: Re: Complicated texturing problem
Date: 22 Jul 2014 08:40:01
Message: <web.53ce5b1bfdaafbaa5e7df57c0@news.povray.org>
> That depends: If you explicitly specify a texture for an object, and
> /then/ translate the object around, the texture travels around with the
> object.
Yes, excellent, I should have made that part clear.
With no texture as part of the object declaration, the object and the texture
can be moved independently.
Once the texture for the object is defined, then they both move as a unit.
But for my purposes, when I move one independently, the texturing of the object
will change because they will "intersect" in different regions relative to each
other.  Similarly, translating and rotating multiple objects in unison would
change where a discontinuity or transition of a texture appears on the surface
of the objects in that union.
