POV-Ray : Newsgroups : povray.newusers : Only render intersections from list of objects Server Time
31 May 2024 19:17:31 EDT (-0400)
  Only render intersections from list of objects (Message 1 to 8 of 8)
Subject: Only render intersections from list of objects
Date: 16 Apr 2014 11:45:00
Message: <web.534ea46d8ab2cb8c24f12bd0@news.povray.org>
I can't think of a way to achieve this.
All my objects (let's say spheres) are in a file, that I can render with
union
   #include OBJECTS_FILE
But I'd like to render only intersections between 2 (or more) spheres.
intersection
wouldn't work since it renders the intersection bewteen ALL objects.
Can povray do that ?
Thanks for your help
Subject: Re: Only render intersections from list of objects
Date: 16 Apr 2014 14:15:34
Message: <534ec8c6$1@news.povray.org>
Le 16/04/2014 17:40, qox nous fit lire :
> union
> intersection
No. But I have a patch that can.
It would be a interunion (or intermerge). Yet to be documented, but
functional.
interunion {
  range{ <2,-1> }
Date: 16 Apr 2014 14:39:38
Message: <534ece6a$1@news.povray.org>
> functional.
Want a job at a famous printer company, with me?
You would fit right in. :-P
Regards
I solemnly promise to kick the next angle, I see.
Date: 16 Apr 2014 14:55:10
Message: <534ed20e@news.povray.org>
Le 16/04/2014 20:39, Stephen nous fit lire :
>> functional.
Alas, too late.
See it at >
http://wiki.povray.org/content/User:Le_Forgeron#GSD_:_Generalised_Symetric_Difference
Source code as usual in repository:
Git: https://github.com/LeForgeron/Hgpovray
Mercurial: https://bitbucket.org/LeForgeron/hgpovray
Date: 16 Apr 2014 15:05:08
Message: <534ed464@news.povray.org>
> > union
> > intersection
> functional.
> interunion {
>   range{ <2,-1> }
For some reason I can't make heads or tails of either the question or
the answer. (Also, I haven't the slightest clue what the "<2,-1>" above
is supposed to signify.)
Date: 16 Apr 2014 15:14:23
Message: <534ed68f$1@news.povray.org>
Le 16/04/2014 21:05, Warp nous fit lire :
>> interunion {
>>   range{ <2,-1> }
the question, if I got it right, was: assume a set of objects that might
intersect (by pair, not with every other...), can we display not the
objects but only their overlapping volumes, even the ones which are only
from two objects of the set.
the range <2,-1> is the specification for the answer: keep all
intersection points that are inside 2 or more objects.
( -1 is a way to specify all objects, without having to counting them).
(<1,-1> is a classical union, but union would then be faster)
Date: 16 Apr 2014 16:11:23
Message: <534ee3eb$1@news.povray.org>
On 16/04/2014 7:55 PM, Le_Forgeron wrote:
> Alas, too late.
Everyone needs a nudge, now and again. :-)
The results look interesting. :-D
Regards
Date: 17 Apr 2014 04:50:01
Message: <web.534f951150dd051624f12bd0@news.povray.org>
Thanks, this is exactly what I asked for, only better phrased...
Sadly, I have no idea how to apply a patch, so I can't test it.
some code (c++) that fails to do so. I'm better off looking into povray's
source..
