POV-Ray : Newsgroups : povray.newusers : Rotation then Translation inside an animation Server Time
27 Jul 2024 18:42:34 EDT (-0400)
  Rotation then Translation inside an animation (Message 1 to 6 of 6)
Subject: Rotation then Translation inside an animation
Date: 1 Apr 2014 05:20:01
Message: <web.533a82fdeb8b8f69281b7210@news.povray.org>
Hello everyone,
I started to use POV-Ray to create some mesh animation. I'd like to make an
animation like this:
 - During the first 15 frames, make a rotation on Y-axis.
 - During the last 15 frames, make a translation on X-axis.
I did something like this:
mesh {
 .... //My triangles
#if (frame_number < 15)
   rotate < 0, clock*360, 0 >
#else
   translate < clock*5, 0, 0 >
The problem with this, is that I don't save the state of the rotation so my
translation is done on the wrong state.
I tried to declare some variables (in .ini or .pov) but, like I though, their
values are resetting for each frames.
Can we save the previous transformation applied on one object?
Thank you.
Romain
Subject: Re: Rotation then Translation inside an animation
Date: 1 Apr 2014 06:26:45
Message: <533a9465$1@news.povray.org>
On 01/04/2014 10:15, Romain wrote:
> Hello everyone,
> mesh {
>   .... //My triangles
> #else
> #end
If I understand correctly what you want to do, then you can just add an
additional rotate line into the #else block to do the same rotation as
in frame 14:
  #else
      rotate <0,clockAtFrame14*360,0>
BTW, is it wise to mix frame_number and clock? I would stick to using
just one or the other, as at some point you might want to change the
frames per second the animation is rendered at. Do you really want the
rotation to last 15 frames regardless of the frame rate, or a fixed
amount of time?
Date: 1 Apr 2014 09:45:00
Message: <web.533ac1f4e4fdc502281b7210@news.povray.org>
> > Hello everyone,
> > mesh {
> >   .... //My triangles
> > #else
> > #end
> in frame 14:
>   #else
>   #end
> amount of time?
Thanks you for your very quick answer.
I'd like to have a rotation in a fixed amount of time. But I'm not sure how to
do this without the fps.
Is it possible?
For now, I did something like that:
in .pov:
#declare MyClock=Start + (End-Start)*clock;
#if (MyClock < 2.5)
 rotate< 0, clock*360, 0 >
#else
 #declare previousClock = 2.5 * fps / final_frame;
 rotate < 0, previousClock*360, 0 >
in .ini:
Initial_Frame=1
Final_Frame=150
Initial_Clock=0
Final_Clock=1
Declare=fps=30
Declare=Start=0;
Declare=End=5;
This script works but I don't know if it's the best solution.
Date: 1 Apr 2014 10:28:14
Message: <533accfe@news.povray.org>
> Is it possible?
I always use "clock" to be the number of seconds in the animation, so in
your example I would put:
Initial_Clock=0
Final_Clock=5
Initial_Frame=1
Final_Frame=150
If you then decide you want to render at 60fps you only need to change
Final_Frame. I try to avoid using anything based on the frame_number or
fps unless really needed.
In your scene you can then write:
  #if (clock < 2.5)
  #else
    #declare previousClock = 2.5;
    translate < (clock-2.5)*5, 0, 0 >
I also changed the translate distance to (clock-2.5)*5, otherwise you'll
get a jump at 2.5 seconds.
Date: 1 Apr 2014 11:10:00
Message: <web.533ad609e4fdc502281b7210@news.povray.org>
> Initial_Clock=0
> Final_Clock=5
> Initial_Frame=1
> Final_Frame=150
>   #if (clock < 2.5)
>   #else
>   #end
Thank you.
I'm going to use you're method which is easier than mine :)
I start (finally) to understand how POV-Ray animation works.
Thanks so much again!
Date: 1 Apr 2014 11:58:33
Message: <533ae228@news.povray.org>
If you need to "collect" lots of transformations like that, rather than
having to repeat all previous transformations in increasingly-nested
#else blocks, you can literally collect them into one single transform
variable, which you can then apply to your object.
Also, you may want to use the min() function instead of #if blocks,
as it makes it much simpler.
For example like this:
#declare Tr = transform { rotate <0, min(clock, 2.5)*360, 0> };
#declare Tr = transform { Tr translate <min(clock-2.5, 2.5)*5, 0, 0> };
#declare Tr = transform { rotate <0, min(clock-5.0, 2.5)*360, 0> };
  object
    YourObject
    transform { Tr }
