I want to show a scene in which part is in an underground cavity, as in the
scene below.
The cavity is to be lit from local lights and light coming down the two holes in
the y plane but no light should come through the cross-section z plane. How do I
block this off?
// Persistence of Vision Ray Tracer Scene Description File
// File: Cavity_below_ground.pov
// Vers: 3.7
#include "stones1.inc"
location <3, 10, -40>
look_at <0,3 , 0>
angle 20
background { color rgb<0.2, 0.4, 0.8> }
light_source { <100, 100, -100> color rgb 1 }
global_settings {assumed_gamma 1.0 }
difference {
#intersection {
plane {y,6 texture { T_Grnt1}}
plane {z,-4 inverse texture {T_Stone14}}
#union {
box {<-20,2,.9>,<20,0,-1> }
box {<-6,10,1>,<-2,1,-1> }
box {<6,10,1>,<2,1,-1> }
box {<-5.5,5,-.5>,<5.5,.1,-100> }
texture {T_Stone15} } }
Subject: Re: Block light from entering cavity
Date: 19 Feb 2014 10:25:12
Message: <5304ccd8@news.povray.org>
> scene below.
> block this off?
> // Vers: 3.7
> camera {
> look_at <0,3 , 0>
> angle 20
> difference {
> #intersection {
> #union {
add at the end of the code the following line:
box {<-10, -10, -5>,<10, 6, -4> no_image}
This closes the front of the cavity, and no_image enables the viewer to
look inside.
> > scene below.
> > block this off?
> > // Vers: 3.7
> > camera {
> > look_at <0,3 , 0>
> > angle 20
> > difference {
> > #intersection {
> > #union {
> look inside.
> Thomas
That does the trick!
Thanks
John
