POV-Ray : Newsgroups : povray.newusers : Isosurface problem Server Time
17 Jun 2024 09:44:56 EDT (-0400)
  Isosurface problem (Message 1 to 8 of 8)
Subject: Isosurface problem
Date: 29 Jan 2014 05:35:00
Message: <web.52e8d82bcfb9f6d0a7cafab50@news.povray.org>
I have created an isosurface with _exactly_ the shape I want, but there is one
region where generation breaks down, I think because of surfaces coinciding.
Any suggestions?
#version 3.7;
global_settings { assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#include "functions.inc"
#declare CamLoc = < 0, 0,-20>;
 location CamLoc
 look_at < 0, 0, 0>
 angle 30
light_source {CamLoc color White*0.35}
light_source {<-50, 150,-75> color White}
background { color rgb<1,1,1>*0.35 }
box {<-4,-3, 1>, < 4, 3, 2>
  pigment {checker color rgb < 0.05, 0, 0.35>, color White}
  finish {ambient 0 diffuse 1}
#local Yo = 0.08;
#local Zo = .635;
#local Xa = 0.75;
#local Yb = 1.6;
#local Rr = 2.560;
#local Ko = 0.23;
#declare IsoFinish =
finish {
 ambient 0 diffuse 1
 specular 1 roughness 0.02
 brilliance 2
#declare  Shape =
intersection   {
isosurface {
// I think the isosurface function does not like sqrt with negative roots.
// This gives a very strange result
//    function {-sqrt((1-pow(z/Zo,2))*pow((y-Rr+sqrt(pow(Rr,2)-pow(z,2))),2))
+pow(x,2)}
// This works except fo the "Ears" where the parabola reflects
    function {-((1-pow(z/Zo,2))*pow((y-Rr+sqrt(pow(Rr,2)-pow(z,2))),2))
+pow(x,4)}
    max_gradient 200
    accuracy     0.001
    threshold 0
    contained_by {box {<0,0,-1>,<2,2,1>}}
// This is the shape I want; But....
// This chops off the ears but the surfaces coincide at the corners and we get a
hole
     cylinder {<-1,Rr,0>,<2,Rr,0>,Rr}
  pigment {color  rgb<0.8,0,0>}
  finish {IsoFinish}}
        rotate <180, 90, 0>     }
#declare Spread = 3;
 object {Shape rotate <-90, 45, -90> translate <-Spread, Spread, 0>}
 object {Shape rotate <0, 90, 0> translate <-Spread, 0, 0>}
 object {Shape rotate <0, 45, 45> translate <-Spread, -Spread, 0>}
 object {Shape rotate <-120, 0, 0> translate <0, Spread, 0>}
 object {Shape rotate <0, 0, 0> translate <0, 0, 0>}
 object {Shape rotate <45, 0, 0> translate <0, -Spread, 0>}
 object {Shape rotate <45, 45, 45> translate <Spread, Spread, 0>}
 object {Shape rotate <0, -45, 0> translate <Spread, 0, 0>}
 object {Shape rotate <-100, 45, 0> translate <Spread, -Spread, 0>}
Subject: Re: Isosurface problem
Date: 29 Jan 2014 07:17:20
Message: <52e8f150$1@news.povray.org>
> Any suggestions?
>     function {-((1-pow(z/Zo,2))*pow((y-Rr+sqrt(pow(Rr,2)-pow(z,2))),2))+pow(x,4)}
>     max_gradient 200
>     accuracy     0.001
>     threshold 0
You need the keyword 'all_intersections' thus:
function
    max_gradient 32
    accuracy     0.001
    threshold 0
    all_intersections
You will also notice that I have reduced your max_gradient to 32 thus
gaining an ~40% increase in speed.
See: http://www.povray.org/documentation/view/3.7.0/300/ At the bottom
of the page there is a short paragraph about max_trace and
all_intersections.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 29 Jan 2014 13:46:01
Message: <52e94c69@news.povray.org>
> Any suggestions?
> #version 3.7;
> camera {
>   location CamLoc
>   look_at < 0, 0, 0>
>   angle 30
>   texture {
> #local Yo = 0.08;
> #local Zo = .635;
> #local Xa = 0.75;
> #local Yb = 1.6;
> #local Rr = 2.560;
> #local Ko = 0.23;
> finish {
>   ambient 0 diffuse 1
>   brilliance 2
> #declare  Shape =
> intersection   {
> isosurface {
> +pow(x,2)}
This negate the function. It effectively make the outside part the
"inside" of your shape. If the function don't require been negated,
you'll only see the contained_by object.
You may also need to negate the thresshold value.
Date: 30 Jan 2014 07:04:19
Message: <52ea3fc3$1@news.povray.org>
> Any suggestions?
John, I've realised why you are having a bit of difficulty with getting
the max_gradient right for your isosurfaces.
In v3.6, a warning was issued if you had set max_gradient too high or
too low. In v3.7, that behaviour became broken (something to do with
thread safety). In
http://news.povray.org/povray.beta-test/thread/%3C51c55b9f%241%40news.povray.org%3E/?mtop=384497
some work-rounds are suggested but I can't get them to work.
If you want to get the old behaviour you will have install v3.6 in
parallel with v3.7. You then get warnings such as:
> Shutdown Warning: The maximum gradient found was 29.821, but max_gradient of the
>  isosurface was set to 10.000. The isosurface may contain holes! Adjust
>  max_gradient to get a proper rendering of the isosurface.
If you're running Windows, I can't help with installing 3.6 along with
3.7; if, however, you're running Linux it's easy:
1. Download v3.6 source
2. ./configure, make but don't make install.
3. cd /usr/local/bin; sudo mv povray povray37
4. Return to your 3.6 source directory
5. sudo make install
6. cd /usr/local/bin; sudo mv povray povray36
You now have povray36 and povray37 as commands. Simples!
John
Protect the Earth
Date: 30 Jan 2014 07:20:57
Message: <52ea43a9$1@news.povray.org>
> thread safety). In
> John
John & John,
I believe we found previously that if you render the isosurface NOT
wrapped in an object, the maximum gradient warning is issued in 3.7. I
thought the idea was to document this issue, but I admit I lost track.
When you get warnings it was the case in 3.7, unless running one thread,
the value might not be the absolute maximum seen because values are
getting overwritten by differing threads.
Bill P.
Date: 30 Jan 2014 07:45:12
Message: <52ea4958@news.povray.org>
On 30/01/14 12:20, William F Pokorny wrote:
> John & John,
> Bill P.
Thanks for that, Bill.
So, John, the thing is to do a test run on your (naked) isosurface
without any CSG operations then, when you've got max_gradient right,
proceed to your full CSG modified scene.
BTW Christoph Hormann has some good information regarding isosurface CSG
in http://www.imagico.de/pov/ic/index.php
John
Protect the Earth
Date: 30 Jan 2014 08:35:01
Message: <web.52ea543a28c3ea73a7cafab50@news.povray.org>
> > John & John,
> > Bill P.
> John
> Protect the Earth
Thanks for all the above. I will try and digest it in the next week.
John Greenwood
Date: 30 Jan 2014 16:43:27
Message: <52eac77f$1@news.povray.org>
>>> John & John,
>>> Bill P.
>> John
>> Protect the Earth
> John Greenwood
To help speed up the rendering of isosurfaces, you can use the evaluate
option instead of using max_gradient.
You do this as follow:
#declare min_factor=0.6; // good general satrting value
In the isosurface, where max_gradient is located, replace max_gradient
with the following:
evaluate Found_Max_Gradient*min_factor sqrt(1/min_factor) 0.7
This will usualy make the isosurface render faster. It's very usefull if
you #declare an isosurface and use several instances of it with slight
variations.
Something like this (actual working code):
#declare Num=8;
#declare P=Num;
#declare Stp=360/Num;
union{
#while(P>0)
		#declare Ofx=rand(R)*100;
		#declare Ofy=rand(R)*100;
		#declare Ofz=rand(R)*100;
// this shift the denting in a random fashion
isosurface{function{-f_superellipsoid(x,y,z,0.11,0.11)+f_dents(x+Ofz,y+Ofy,z+Ofz)*0.0219}
	evaluate 1*min_factor sqrt(1/min_factor) 0.7
	contained_by{box{-1 1}}
	rotate<rand(R) rand(R) rand(R)>*360
	pigment{rgb <0.51, 0.45, 0.56>}
	scale 0.47
	translate<10,2.032,0> rotate ((Stp)*P+rand(R)*Stp/4)*y
// Add some jitter to the objects position
			photons{target reflection on}
finish{
	reflection{0.6 metallic}
	specular albedo 1 metallic
	roughness 0.001
	diffuse albedo 0.17
	brilliance 1.97
	irid{0.18 thickness 0.1}
Here, the f_dents function is randomly shifted for each iterations
making all objects different.
