POV-Ray : Newsgroups : povray.newusers : Isosurface blemished Server Time
27 Jul 2024 18:30:49 EDT (-0400)
  Isosurface blemished (Message 1 to 4 of 4)
Subject: Isosurface blemished
Date: 27 Jan 2014 14:20:00
Message: <web.52e6b14fc312947ea7cafab50@news.povray.org>
I tried to use an isosurface with a moderately complex formula but got very
weird results, so I started with a working example with the object of adding the
complexity bit by bit.
I started with the code below and found I was getting black features on the
surface. There are five versions of the function line, the first renders ok but
the rest give increasingly worse results.
#version 3.7;
global_settings { assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#include "functions.inc"
#declare CamLoc = < 0, 0,-10>;
 location CamLoc
 look_at < 0, 0, 0>
 angle 42
light_source {CamLoc color White*0.35}
light_source {<-50, 150,-75> color White}
background { color rgb<1,1,1>*0.35 }
box {<-4,-3, 1>, < 4, 3, 2>
  pigment {checker color rgb < 0.05, 0, 0.35>, color White}
  finish {ambient 0 diffuse 1}
#local Yo = 0.08;
#local Zo = .635;
#local Xa = 0.75;
#local Yb = 1.6;
#local Rr = 2.560;
#local Ko = 0.23;
#declare IsoFinish =
finish {
 ambient 0 diffuse 1
 specular 1 roughness 0.02
 brilliance 2
#declare  Shape =
isosurface {
// function {sqrt(x*x + y*y + z*z) - 1}
// function {sqrt(pow((x/Xa),2) + pow((y),2) + z*z) - 1}
// function {sqrt(pow((x/Xa),2) + pow((y/Yb),2) + z*z) - 1}
// function {sqrt(pow((x/Xa),2) + pow((y/Yb),2) + pow((z/Zo),2)) - 1}
  function {sqrt(pow((x/Xa),2) + pow((y/Yb),2) + (z/Zo)*(z/Zo)) - 1}
 threshold 0
 contained_by {box {<-1,-1,-1>, < 1, 1, 1>}}
  pigment {color  rgb<0.8,0,0>}
  finish {IsoFinish}
 object {Shape rotate <0, 0, 45> translate <-2, 2, 0>}
 object {Shape rotate <0, 45, 0> translate <-2, 0, 0>}
 object {Shape rotate <0, 45, 45> translate <-2, -2, 0>}
 object {Shape rotate <-45, 0, 0> translate <0, 2, 0>}
 object {Shape rotate <0, 0, 0> translate <0, 0, 0>}
 object {Shape rotate <45, 0, 0> translate <0, -2, 0>}
 object {Shape rotate <45, 45, 45> translate <2, 2, 0>}
 object {Shape rotate <0, -45, 0> translate <2, 0, 0>}
 object {Shape rotate <45, 45, 0> translate <2, -2, 0>}
Subject: Re: Isosurface blemished
Date: 27 Jan 2014 14:30:27
Message: <52e6b3d3$1@news.povray.org>
> #version 3.7;
> camera {
>  location CamLoc
>  look_at < 0, 0, 0>
>  angle 42
>  texture {
> #local Yo = 0.08;
> #local Zo = .635;
> #local Xa = 0.75;
> #local Yb = 1.6;
> #local Rr = 2.560;
> #local Ko = 0.23;
> finish {
>  ambient 0 diffuse 1
>  brilliance 2
> #declare  Shape =
> isosurface {
>  threshold 0
>  texture {
>   finish {IsoFinish}
You've forgotten to specify max_gradient for your isosurface. Try a
value of around 1.6
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 28 Jan 2014 00:07:23
Message: <52e73b0b$1@news.povray.org>
> #version 3.7;
> camera {
>   location CamLoc
>   look_at < 0, 0, 0>
>   angle 42
>   texture {
> #local Yo = 0.08;
> #local Zo = .635;
> #local Xa = 0.75;
> #local Yb = 1.6;
> #local Rr = 2.560;
> #local Ko = 0.23;
> finish {
>   ambient 0 diffuse 1
>   brilliance 2
> #declare  Shape =
> isosurface {
>   threshold 0
>   texture {
>    finish {IsoFinish}
Check your max_gradient.
For the basic shape, the default of 1.2 seems to be enough.
For the others, it's obviously to low. Take a look at the post render
messages. If the max_gradient is to low, there will be a message
informing you about the fact. It looks like:
Max_gradient found was 50.24888, but max_gradient was set to 1.2. Your
isosurface may contain holes. Adjust max_gradient ....
In the isosurface definition, add:
max_gradient <Value>
where value is a little smaller than the reported max_gradient.
Date: 28 Jan 2014 05:30:00
Message: <web.52e785ac5239c061a7cafab50@news.povray.org>
> > #version 3.7;
> > camera {
> >   location CamLoc
> >   look_at < 0, 0, 0>
> >   angle 42
> >   texture {
> > #local Yo = 0.08;
> > #local Zo = .635;
> > #local Xa = 0.75;
> > #local Yb = 1.6;
> > #local Rr = 2.560;
> > #local Ko = 0.23;
> > finish {
> >   ambient 0 diffuse 1
> >   brilliance 2
> > #declare  Shape =
> > isosurface {
> >   threshold 0
> >   texture {
> >    finish {IsoFinish}
> Alain
That has fixed it.
Thanks
John
