![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi!
Sorry!
Again it is impossible to me :(
It is necessary to create object from the array
File 'HairSystem.inc' line 54: Parse error:
Expected 'numeric expression', array identifier found instead
Fatal error in parser: Cannot parse input
Render failed
#declare ArrayHairSystem = array[4] {
spline { cubic_spline
0/9 <1.104,-0.535,-0.7421>
1/9 <1.358,-0.4768,-0.8438>
2/9 <1.626,-0.3345,-0.922>
3/9 <1.939,-0.1466,-0.9378>
4/9 <2.328,0.04195,-0.8999>
5/9 <2.732,0.1853,-0.8488>
6/9 <3.079,0.2744,-0.8224>
7/9 <3.371,0.3472,-0.8292>
8/9 <3.616,0.4306,-0.8473>
0/9 <1.281,-0.6221,-0.5943>
1/9 <1.531,-0.6057,-0.8389>
2/9 <1.761,-0.4055,-1.027>
3/9 <2.022,-0.1217,-1.065>
4/9 <2.371,0.1307,-0.9738>
5/9 <2.757,0.2744,-0.8509>
6/9 <3.1,0.3207,-0.7875>
7/9 <3.387,0.3535,-0.8038>
0/9 <1.091,-0.6223,-0.6592>
1/9 <1.357,-0.5827,-0.841>
2/9 <1.618,-0.4031,-0.9808>
3/9 <1.915,-0.1566,-1.009>
4/9 <2.296,0.07255,-0.9414>
5/9 <2.704,0.2209,-0.85>
6/9 <3.062,0.2908,-0.8028>
7/9 <3.366,0.346,-0.815>
0/9 <1.107,-0.5015,-0.7747>
1/9 <1.356,-0.4359,-0.8449>
2/9 <1.627,-0.3081,-0.8988>
3/9 <1.946,-0.1432,-0.9097>
4/9 <2.339,0.02948,-0.8836>
5/9 <2.742,0.171,-0.8484>
6/9 <3.084,0.2678,-0.8302>
7/9 <3.372,0.3476,-0.8348>
#declare HairSegment =
sphere {0,0.1 translate z*0.125}
#declare HairStep = 1;
#declare Hair =
union {
#declare I = 0;
#while (I < ArrayHairSystem)
union {
#declare ctr = 0;
#while (ctr < 1)
object { HairSegment texture{pigment{rgb 1}}rotate z*0
translate ArrayHairSystem[I] (ctr)}
#declare ctr = ctr + 0.00025;
#local I = I + HairStep
Thanks!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"LanuHum" <Lan### [at] yandex ru> wrote:
> Hi!
> Sorry!
> Render failed
> #declare Hair =
> union {
> #declare I = 0;
> union {
> #declare ctr = 0;
> #while (ctr < 1)
> #end
> #end
> Thanks!
ArrayHairSystem is your array not the size of your array. In your while loop you
need to step through your array one spline at a time.
Try This
sphere {0,0.01 }
#declare Hair =
union {
#declare I = 0;
#while (I < 4) //!!!!!!!!/4 splines in your array!!!!!!!!!!
union {
#declare ctr = 0;
#while (ctr < 1)
translate ArrayHairSystem[I](ctr)}
#declare ctr = ctr + 0.0025;
#end }
#local I = I + HairStep ;
#end }
object{Hair}
camera{ location -z*2 look_at x*3}
light_source{-z*99 rgb 1}
background{rgb z}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> sphere {0,0.01 }
> #declare Hair =
> union {
> #declare I = 0;
> union {
> #declare ctr = 0;
> #while (ctr < 1)
> #end }
> #end }
Thanks! Thank you!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > sphere {0,0.01 }
> > #declare Hair =
> > union {
> > #declare I = 0;
> > union {
> > #declare ctr = 0;
> > #while (ctr < 1)
> > #end }
> > #end }
> Thanks! Thank you!
Sorry!
Now I need to paint a hair.
1/3 lengths the black
1/3 lengths smooth transition to the white
1/3 lengths the white
That is, it is necessary to include conditions "if"
Help me, please, once again!
Thanks!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > > sphere {0,0.01 }
> > > #declare Hair =
> > > union {
> > > #declare I = 0;
> > > union {
> > > #declare ctr = 0;
> > > #while (ctr < 1)
> > > #end }
> > > #end }
> > Thanks! Thank you!
> Sorry!
> Thanks!
Try something like this:
pigment{rgb min(1,1.33-ctr*3.7)} finish{diffuse 1 }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks.
But, I solved the problem in such a way:
#declare TableLeg =
#declare ctr = 0;
#declare col = 0;
union {
#while (ctr < 1)
object { TableLegSegment texture{pigment{rgb col}}rotate z*0
translate TableLegShape (ctr)
#if (ctr > 0.5)
#declare col = col + 0.0025;
#if (ctr > 0.6)
#declare col = 1;
object {
TableLeg
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
