POV-Ray : Newsgroups : povray.newusers : Display 3df data though a colormap on a isosurface from 3df Server Time
26 Mar 2026 02:52:17 EDT (-0400)
  Display 3df data though a colormap on a isosurface from 3df (Message 1 to 6 of 6)
Subject: Display 3df data though a colormap on a isosurface from 3df
Date: 14 Jan 2014 15:10:01
Message: <web.52d598e63148d87660cff8e80@news.povray.org>
Hello!
In short, I would like to visualize the electrostatic potential on an density
isosurface. Thus I have two 3df files, one for potential and one for density.
Similarly than in the figure in bottom of this page, except much more
beautifully.
http://www.cup.uni-muenchen.de/ch/compchem/pop/mep1.html
I know how to do the isosurface, but I can't figure out how to set a 'volumetric
texture' to it.
Best regards,
Mikael
Subject: Re: Display 3df data though a colormap on a isosurface from 3df
Date: 14 Jan 2014 21:19:40
Message: <52d5f03c@news.povray.org>
> Hello!
> beautifully.
> texture' to it.
> Best regards,
> Mikael
A "volumetric" anything occupy a volume, not a surface.
A solution would be to make the isosurface transparent, add "hollow",
and, finaly, add some media in the isosurface using your volumetric data
from the dencity DF3.
Date: 15 Jan 2014 07:57:55
Message: <52d685d3$1@news.povray.org>
Am 14.01.2014 21:07, schrieb mikaelk:
> Hello!
> beautifully.
> texture' to it.
I guess you mean df3?
If we're talking about texturing the actual surface of the isosurface
object, it should be as simple as:
isosurface {
       density_file df3 "filename.df3" interpolate 1
       pigment_map {
Date: 17 Jan 2014 08:35:00
Message: <web.52d930852df04bed271407fc0@news.povray.org>
> > Hello!
> > beautifully.
> > texture' to it.
> isosurface {
>    texture {
>      pigment {
>        pigment_map {
Thanks. That worked out of the box. So with volumetric texture, I meant that the
mapping is from x,y,z to u,v,w texture coordinates like that. Maybe a wrong
term.
It's still extremely slow though (several hours on quadcore i7) and looks
absolutely terrible materialwise. I need to reduce specular reflection at least.
I'm not sure why the step structure. I think it maybe related to my quantization
of data, which doesn't have enough bits.
http://imageshack.com/a/img35/7173/6j0u.png
The system is periodic in few directions. I think I could make it periodic in
povray using function statement for isosurface with some use of modulo function.
Date: 17 Jan 2014 11:07:17
Message: <52d95535@news.povray.org>
Am 17.01.2014 14:34, schrieb mikaelk:
Maybe try "interpolate 2" on the df3 you're using for the isosurface.
Date: 17 Jan 2014 19:29:53
Message: <52d9cb01@news.povray.org>
>> quantization
Using interpolate 2, or even interpolate 1, should reduce the stepping.
As a side effect, it will reduce the max_gradient allowing you to use a
smaller value, probably resulting in a somewhat faster rendering.
