POV-Ray : Newsgroups : povray.newusers : white noise pattern Server Time
15 Apr 2025 23:43:36 EDT (-0400)
  white noise pattern (Message 1 to 4 of 4)
Subject: white noise pattern
Date: 8 Jan 2014 06:10:01
Message: <web.52cd3105f4dd1c4fed29e82f0@news.povray.org>
I am searching for the povray pattern that is most suited to creating visual
black and white noise similar to what old television screens could display
without a signal. what are your advices?
Subject: Re: white noise pattern
Date: 8 Jan 2014 09:15:28
Message: <52cd5d80$1@news.povray.org>
> Hi,
   The pattern doesn't matter: just use a B&W color map and turbulence
with a high omega (>=2 will do).
jaime
Date: 8 Jan 2014 18:54:45
Message: <52cde545@news.povray.org>
> Hi,
The granite, agate or bumps patterns, properly scalled should gives good
results. For the agate pattern, you'll need to provide a black to white
color_map.
As those noise seems to tend to have few grays, I'd suggest a color_map
similat to this:
color_map{[0.4 rgb 0][0.6 rgb 1]}
Change the transition range up or down to get darker or brighter patterns.
Broaden the transition range to reduce contrast, tighten it to increase it.
Date: 8 Jan 2014 21:25:00
Message: <web.52ce0800bbe5940119dc916f0@news.povray.org>
> > Hi,
> color_map.
> similat to this:
> Alain
Indeed, It works pretty well, I used a cell pattern to avoid getting curves in
case of big scaling
