POV-Ray : Newsgroups : povray.newusers : Pattern repeat: help me please! Server Time
17 Jun 2024 10:31:32 EDT (-0400)
  Pattern repeat: help me please! (Message 1 to 4 of 4)
Subject: Pattern repeat: help me please!
Date: 7 Jan 2014 09:20:00
Message: <web.52cc0b11ba2ceee37a3e03fe0@news.povray.org>
Hi!
I want to create wall-paper in the room, using a pattern agate
I broke the head
I created an example in gimp:
http://yadi.sk/d/ui0h9kFCFbDb6
Subject: Re: Pattern repeat: help me please!
Date: 7 Jan 2014 09:36:00
Message: <52cc10d0$1@news.povray.org>
Am 07.01.2014 15:11, schrieb LanuHum:
> Hi!
> I broke the head
If I understand you correctly, you want to achieve the same effect, but
without resorting to gimp, and instead you want to let POV-Ray do the
job, right?
The so-called "repeat warp" is probably what you want.
Date: 7 Jan 2014 12:20:00
Message: <web.52cc3656d45350cd7a3e03fe0@news.povray.org>
> > Hi!
> > I broke the head
> job, right?
Yes! Thanks!
    #declare Texture_003 = pigment{
        agate
        agate_turb 2
        color_map {
            [0 color rgbf<0,0,0,1>]
            [1 color rgbf<1,1,1,0>]
        warp {repeat x*2}
        frequency 2
        scale <-1,0.02,1>
    #declare Texture_004 = pigment{
        agate
        agate_turb 2
        color_map {
        warp {repeat x*2}
        frequency 2
        scale <1,0.02,1>
    #declare Tex_back_wall = pigment{
        checker
        pigment{Texture_003}
        pigment{Texture_004}
        rotate <0,90,0>
        translate <0,0.2,0>
        scale <1,20,0.5>
I solved this problem without uv, but uv-mapping doesn't work with warp repeat
Date: 7 Jan 2014 14:09:33
Message: <52cc50ed@news.povray.org>
Am 07.01.2014 18:16, schrieb LanuHum:
>>> Hi!
>>> I broke the head
>> job, right?
> Yes! Thanks!
>          agate
>          agate_turb 2
>          color_map {
>          warp {repeat x*2}
>          frequency 2
>          scale <-1,0.02,1>
>          agate
>          agate_turb 2
>          color_map {
>          warp {repeat x*2}
>          frequency 2
>          scale <1,0.02,1>
>          checker
>          rotate <0,90,0>
>          translate <0,0.2,0>
>          scale <1,20,0.5>
Using the "flip" parameter makes it a lot easier:
          agate
          agate_turb 2
          color_map {
          warp {repeat x*2 flip x}
          frequency 2
It doesn't? That's strange; it /should/ work.
