POV-Ray : Newsgroups : povray.newusers : declared patterns without pigments ( rvalue ) Server Time
6 Aug 2025 22:10:41 EDT (-0400)
  declared patterns without pigments ( rvalue ) (Message 1 to 6 of 6)
Subject: declared patterns without pigments ( rvalue )
Date: 1 Jan 2014 14:35:00
Message: <web.52c46d118bb7cd1d56a4f3390@news.povray.org>
Hi, is there anyway to predeclare a pattern (preferably with its
transformations) so that it can later be used equally within various normals or
pigments?
Up to now I only managed to declare it as the one or the other.
or maybe there is a way to fit a declared pigment inside a normal{} block?
Subject: Re: declared patterns without pigments ( rvalue )
Date: 1 Jan 2014 15:58:19
Message: <52c4816b@news.povray.org>
Am 01.01.2014 20:32, schrieb Mr:
> pigments?
You can use a so-called "pigment function" (a function that gets its
values from a pigment), and then use this function in a so-called
"function pattern".
Date: 4 Jan 2014 16:05:00
Message: <web.52c8769f84c18776a63b69b00@news.povray.org>
> > pigments?
> "function pattern".
excuse me, but would you mind to post an example?  Didn't you rather mean use a
pattern function inside a pigment instead of the opposite?
the tricky thing is that a colormap is currently defined along with the pigment,
I expected it to just get ignored if it's irrelevent to the normal statement or
automatically converted to a grey scale.
Date: 4 Jan 2014 16:17:47
Message: <52c87a7b$1@news.povray.org>
Am 04.01.2014 22:01, schrieb Mr:
>>> pigments?
>> "function pattern".
You'll have to define the pigment with a linear greyscale color map, i.e.:
   #declare MyPigment = pigment {
     colour_map {
       [0 rgb 0]
       [1 rgb 1]
You then need to define a function based on that pigment (a so-called
"pigment function"):
   #declare MyFn = function { pigment { MyPigment } }
Finally, you need to define a normal statement using this function as
the pattern (a so-called "function pattern"):
   #declare MyNormal = normal {
     function { MyFn(x,y,z).gray }
(Note that pigment functions are special in that they return a colour
rather than a scalar value.)
Date: 4 Jan 2014 16:45:01
Message: <web.52c8807784c187767f6553270@news.povray.org>
> pigments?
You can use a pattern function, i.e.:
#declare foo = function {
   pattern {
     checker
     function { foo(x,y,z) }
You find it at the end of section "2.2.1.6.3 Declaring User-Defined Float
Functions" in http://www.povray.org/documentation/view/3.6.1/231/ .
Date: 5 Jan 2014 16:20:01
Message: <web.52c9cc4584c18776416484130@news.povray.org>
> > pigments?
>    pattern {
>      checker
Thanks to both of you. it works.
