POV-Ray : Newsgroups : povray.newusers : GIF: how to define color number in linux? Server Time
27 Jul 2024 20:38:10 EDT (-0400)
  GIF: how to define color number in linux? (Message 1 to 9 of 9)
Subject: GIF: how to define color number in linux?
Date: 2 Dec 2013 12:10:00
Message: <web.529cbda88880fddf7a3e03fe0@news.povray.org>
Hi!
Sorry!
In doc:
image_map {
  gif "mypic.gif"
  filter   0, 0.5 // Make color 0 50% filtered transparent
  filter   5, 1.0 // Make color 5 100% filtered transparent
  transmit 8, 0.3 // Make color 8 30% non-filtered transparent
How to define, what indexes in my picture? 0, 5, 8 or 7, 256, 119, 17...
Don't advise to me to buy Photoshop and Windows-8 :)
Me means of programming in linux interest.
Subject: Re: GIF: how to define color number in linux?
Date: 2 Dec 2013 12:30:18
Message: <529cc3aa$1@news.povray.org>
Le 02/12/2013 18:05, LanuHum nous fit lire :
> Hi!
> Sorry!
> In doc:
> image_map {
>   gif "mypic.gif"
To find the index of color map on linux, I recommend using Gimp.
Load your gif in the program, then if the colormap is not displayed
automatically, go to Windows->Dockable Dialogs->Colormap
You can even reorder the color map with Rearrange Colormap (rightclick
menu of the colormap, when selecting a color from the
colormap)(rearranging does not change the display of the picture, only
the order in the color map)
Date: 2 Dec 2013 13:55:00
Message: <web.529cd6f4f74b61377a3e03fe0@news.povray.org>
Thanks!
But, if I create GIF in GIMP-2.8:
Povray wrote:
Possible Parse Error:
Interlacing in GIF image unsupported
Fatal error in parser: Cannot access data in file.
Render failed
But, I convert GIF(create with GIMP) to PNG in konqueror, than PNG to GIF in
konqueror:
Render good, no error.
As it is correct to create GIF in GIMP for Povray?
Date: 2 Dec 2013 15:40:31
Message: <529cf03f@news.povray.org>
Le 02/12/2013 19:52, LanuHum nous fit lire :
> Thanks!
> Render failed
Holy cow!
You have found the deepest bug of Povray: it read 9 bytes of image block
in buffer[] from 0 to 8, and test buffer[9] instead of buffer[8] for
interlacing.
(in file gif.cpp for Povray 3.7, circa line 158)
The bug was not in 3.1g; and not yet in 3.6.1;
Congratulations.
I now have to report that bug.
> konqueror:
If the code was correct, it would be fine with Gimp. So far the issue is
that Gimp put the comment block before the image block, and if the Ninth
bytes of the comment has the bit 0x40 set, you're dead.
So: "Created with GIMP" being the default comment, you are killed by the
w of with. (0x77). (if there is no comment, or a shorter one, it might
still be amusing for that buffer overrun from previous read...)
The convertion between gif-gimp to png to gif again might move the
blocks, or drop some.
Date: 2 Dec 2013 15:41:33
Message: <529cf07d$1@news.povray.org>
> Thanks!
> Render failed
> konqueror:
Interlacing mean that the lines are not consecutives. First, you have
the even lines, then the odd ones.
Check your options for saving as GIF. UNCHECK "Save as interlaced".
Do that for all format that offer that option.
Also, uncheck any "progressive" option.
Date: 2 Dec 2013 15:58:36
Message: <529cf47c$1@news.povray.org>
Le 02/12/2013 21:40, Le_Forgeron nous fit lire :
Correction, it's the "i" of with that's blocking. But that's only a details.
Date: 2 Dec 2013 16:00:20
Message: <529cf4e4@news.povray.org>
Am 02.12.2013 21:58, schrieb Le_Forgeron:
Are you already working on the fix?
Date: 2 Dec 2013 16:17:47
Message: <529cf8fb@news.povray.org>
Le 02/12/2013 22:00, clipka nous fit lire :
>> details.
I'm working on the report (FS#314), but a second pair of eyes is
welcome, and I'm not trying to fix it tonight, so feel free to take the
hand on it and push a correction.
Date: 3 Dec 2013 13:20:00
Message: <web.529e20abf74b61377a3e03fe0@news.povray.org>
> Holy cow!
Thanks! No comment - very good! :)
