POV-Ray : Newsgroups : povray.newusers : Profile along curve. Yes? Server Time
10 Oct 2025 22:27:05 EDT (-0400)
  Profile along curve. Yes? (Message 1 to 8 of 8)
Subject: Profile along curve. Yes?
Date: 6 Sep 2013 14:30:00
Message: <web.522a1df14a0a92a17a3e03fe0@news.povray.org>
Sphere_sweep: sphere along b-spline?
If yes: how make box_sweep or prism_sweep, or other profile?
For example:
http://yadi.sk/d/eJafyasE8qMeT
Subject: Re: Profile along curve. Yes?
Date: 6 Sep 2013 14:51:11
Message: <522a241f$1@news.povray.org>
> For example:
// define the points
#declare Pt1 = <1.5,1,0>;
#declare Pt2 = <1,1,0>;
#declare Pt3 = <1,0.5,0>;
#declare Pt4 = <2,0.5,0>;
#declare Pt5 = <2,2,0>;
#declare Pt6 = <0,2,0>;
#declare Pt7 = <0,0,0>;
#declare Pt8 = <3,0,0>;
#declare Pt9 = <1,6,0>;
#declare PtA = <2.5,6.5,0>;
#declare PtB = <6,4.87,0>;
// create the shape (profile)
#declare TableLegShape =
spline {
natural_spline
	0/10 Pt1
	1/10 Pt2
	2/10 Pt3
	3/10 Pt4
	4/10 Pt5
	5/10 Pt6
	6/10 Pt7
	7/10 Pt8
	8/10 Pt9
	9/10 PtA
	10/10 PtB
// the shape that will follow the profile
#declare TableLegSegment =
union {
	sphere {0,0.1 translate z*0.125}
	cylinder {<0,0,-0.125>, <0,0,0.125>, 0.1}
	sphere {0,0.1 translate -z*0.125}
// the final shape
#declare TableLeg =
#declare ctr = 0;
union {
	#while (ctr < 1)
		object { TableLegSegment rotate z*0
			translate TableLegShape (ctr)
		#declare ctr = ctr + 0.00025;
Date: 7 Sep 2013 01:50:01
Message: <web.522abda7b097185d7a3e03fe0@news.povray.org>
> spline {
> natural_spline
>  0/10 Pt1
>  1/10 Pt2
>  2/10 Pt3
>  3/10 Pt4
>  4/10 Pt5
>  5/10 Pt6
>  6/10 Pt7
>  7/10 Pt8
>  8/10 Pt9
>  9/10 PtA
>  10/10 PtB
> // the final shape
> #declare TableLeg =
> #declare ctr = 0;
> union {
>  #while (ctr < 1)
>  #end
Thank you, very good! :)
But, 2 more question:
sphere_sweep use spline point radius. This is transform scale from a point to a
point.
Example:
 sphere_sweep {
    linear_spline // spline type
    4, /7 number of <x,y,z> points, radius
    <-1.50, 1.00,-0.5>, 0.25
    <-1.50, 0.00, 1>, 0.15
    < 0.50, 0.00, 0>, 0.35
    < 1.50, 0.50, 2>, 0.15
1.How it make in while?
2.What define numbers in spline 0/10, 1/10 and so on???
Date: 7 Sep 2013 08:08:47
Message: <522b174f$1@news.povray.org>
>> spline {
>> natural_spline
>>   0/10 Pt1
>>   1/10 Pt2
>>   2/10 Pt3
>>   3/10 Pt4
>>   4/10 Pt5
>>   5/10 Pt6
>>   6/10 Pt7
>>   7/10 Pt8
>>   8/10 Pt9
>>   9/10 PtA
>>   10/10 PtB
>> // the final shape
>> #declare TableLeg =
>> #declare ctr = 0;
>> union {
>>   #while (ctr < 1)
>>   #end
> point.
> Example:
>   sphere_sweep {
if i'm understanding correctly ... load the values into an array
trial and error ... i have home-made include file (splinelab) that helps
mark where the points are ... in this case the shape of a wrought iron
table leg
have a look at
http://wiki.povray.org/content/Documentation:Tutorial_Section_3#Spline_Based_Shapes
if you haven't already. that's were i got the idea for creating
splinelab to help with defining the curve. if by hand is too tedious for
you look at http://www.povray.org/ under POV-RAY related news ... i
posted a link there a while ago (lathe and prism utility)
Date: 10 Sep 2013 12:30:00
Message: <web.522f471eb097185d7a3e03fe0@news.povray.org>
> have a look at
My purpose - creation of asymmetrical objects for Boolean operations using the
Blender-3D tools
Sphere_sweep is available now. It can be used for Boolean operations now.
The while(cycle) also will be available.
But, it would be desirable to operate scale,
to manipulate scale along curve,
constraint scale to curve point radius
Blender have parameter: vertices radius.
I use it in sphere_sweep.
I want to learn: how to use it in a while(cycle)?
Probably, I will divide a cycle(while) into some parts...
Date: 5 Jan 2014 10:35:00
Message: <web.52c97a22b097185d7a3e03fe0@news.povray.org>
Hi.
Sorry!
I created the file in blender with object sphere_sweep:
global_settings {
    assumed_gamma 1
    max_trace_level 3
background {rgbt<0.0509, 0.0509, 0.0509, 0>}
#declare NurbsCurve =
sphere_sweep { cubic_spline 10,
    <-1.796,-0.2653,0.5108>,0.2,
    <-1.627,-0.8928,0.7868>,0.2,
    <0.01627,-1.644,-0.4275>,0.2,
    <1.422,-0.6246,-2.678>,0.2,
    <-0.6351,0.9274,-1.604>,0.2,
    <-1.659,0.5656,-0.2417>,0.2,
    <-1.5,0,0>,0.2,
    <-1,-4.371e-08,-1>,0.2,
    <1,-4.371e-08,-1>,0.2,
    <1.5,0,0>,0.2
    texture {pigment{rgb 0.8}}
    scale <1,1,1>
    rotate <-2.504e-06,-0,0>
    translate <0.000000, 0.000000, 0.000000>
object {NurbsCurve}
light_source {
    <4.08,5.9,-1.01>
    color rgb<1, 1, 1>
#declare Camera_Location = <7.481132, 5.343666, 6.507640>;
#declare Camera_Look_At = <0, 0, -1>;
#declare Camera_Angle = 49.134343;
#include "transforms.inc"
#declare Cam_V = Camera_Look_At - Camera_Location;
#declare Cam_Ho = sqrt(pow(Cam_V.x,2)+pow(Cam_V.z ,2));
#declare Cam_Y = Camera_Look_At.y - Camera_Location.y;
    angle  Camera_Angle
    right <-1.6077777759896383, 0, 0>
    location  <0,Camera_Look_At.y,-Cam_Ho>
    matrix<1,0,0, 0,1,0, 0,Cam_Y/Cam_Ho,1, 0,0,0>
    Reorient_Trans(z,<Cam_V.x,0,Cam_V.z>)
    translate<Camera_Look_At.x+2,1.25,Camera_Look_At.z+2>
Render good: object in scene
Now I want to use coordinates NurbsCurve for while
I use an example from James Holsenback in this topic:
global_settings {
    assumed_gamma 1
    max_trace_level 3
spline {
cubic_spline
 0/10 <-1.796,-0.2653,0.5108>
 1/10 <-1.627,-0.8928,0.7868>
 2/10 <0.01627,-1.644,-0.4275>
 3/10 <1.422,-0.6246,-2.678>
 4/10 <-0.6351,0.9274,-1.604>
 5/10 <-1.659,0.5656,-0.2417>
 6/10 <-1.5,0,0>
 7/10 <-1,-4.371e-08,-1>
 8/10 <1,-4.371e-08,-1>
 9/10 <1.5,0,0>
union {
// the final shape
#declare TableLeg =
#declare ctr = 0;
union {
 #while (ctr < 1)
light_source {
    <4.08,5.9,-1.01>
    color rgb<1, 1, 1>
    angle  Camera_Angle
Object NOT in scene!
Help me, please!
Thanks!
Date: 5 Jan 2014 14:35:01
Message: <web.52c9b2d0b097185d9d0caeb40@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> Hi.
> Sorry!
> global_settings {
>     assumed_gamma 1
>     max_trace_level 3
> spline {
> cubic_spline
>  6/10 <-1.5,0,0>
>  9/10 <1.5,0,0>
> union {
 Your final object is only here. You do add a line after the declaration.
> // the final shape
> #declare TableLeg =
> #declare ctr = 0;
> union {
>  #while (ctr < 1)
>  #end
ex here:
object {
     TableLeg
> light_source {
>     <4.08,5.9,-1.01>
>     color rgb<1, 1, 1>
> camera {
>     angle  Camera_Angle
Date: 6 Jan 2014 11:30:01
Message: <web.52cad9acb097185d7a3e03fe0@news.povray.org>
"Fractracer" <lg.### [at] gmailcom> wrote:
> ex here:
> object {
>      TableLeg
Oh!
Thanks!
My delusion:
#declare ctr = 0;
union {
I badly a sign with the sintaksy While
Sorry!
Thanks!
