POV-Ray : Newsgroups : povray.newusers : Mirroring coordinates Server Time
15 Apr 2025 23:31:47 EDT (-0400)
  Mirroring coordinates (Message 1 to 5 of 5)
Subject: Mirroring coordinates
Date: 31 Jul 2013 16:35:00
Message: <web.51f973f9cc1592c73fc9ebb0@news.povray.org>
Is there a simple straightforward way to "mirror" objects in a plane?
For example, convert <-1, 0, 0,> to <1, 0, 0>?
I'm not yet familiar enough with the voluminous documentation to know what to
look for, or of there's vector function that handles this.
Subject: Re: Mirroring coordinates
Date: 31 Jul 2013 16:51:53
Message: <51f978e9$1@news.povray.org>
Have you tried <-1, 0, 0,> * -1 ?
or <-1, 0, 0,> *<-1, 0, 0> ?
Regards
Date: 31 Jul 2013 17:50:00
Message: <web.51f9867881587f8d73fc9ebb0@news.povray.org>
Indeed, that would be trivial for a point or dozen.
I guess my actual question is:
(a) can this be done to objects, unions, etc.
for example: [fake illustrative code]
object(My_Object) * -1
InvVector (My_Object), Mirror (My_Object) ... you get the idea.
and/or
(b) is there a way process an SDL file to switch from left handed to right
handed world coordinates?
Sorry for the confusion.
Date: 31 Jul 2013 19:05:18
Message: <51f9982e$1@news.povray.org>
Very easy, just use a scale with a negative value along one of the axis.
scale<-1,1,1> will mirror any object left to right. If the object is
some distance from the origin, it will also move to the oposite side.
box{<10,1,1><12,3,3> scale <-1,1,1>}
will now reside from -12 to -10 along the x axis.
scale<1,-1,1> will mirror verticaly and scale<1,1,-1> will mirror front
to back.
scale -1 will inverse your object in all direction.
It's possible to mirror relative to an non-orthogonal plane, but it's
somewhat more complexe. It can involve some rotation, inverting scalling
and a reversed rotation to undo the original one. An advanced option
will use a matrix transform.
box{<1,1,1><2,2,2> rotate 30*z scale<-1,1,1> rotate -30*z}
It's beter to create your object around the origin, apply any scalling
and rotation, THEN translate it to the desired location.
Otherwise, the scalling and rotation will cause the object to move around.
Date: 1 Aug 2013 02:24:38
Message: <51f9ff26@news.povray.org>
Am 31.07.2013 23:49, schrieb Bald Eagle:
Alain already mentioned the use of the scale keyword for that purpose.
> and/or
Yes: By defining all three of the "up", "right" and "direction" vectors
in the camera block you get full control over the coordinate system. The
following will give you a right-handed one:
     right      x*image_width/image_height
     up         y
     direction -z
or:
     right      x
     up         y*image_height/image_width
     direction -z
or:
     right      x*image_width
     up         y*image_height
     direction -z
but also (e.g.):
     right      x*image_width
     up         z*image_height
     direction  y
Note that besides specifying the handedness of the coordinate system
this also sets the camera's aspect ratio, hence the image_width and
image_height factors; it also initializes the camera orientation and
field of view, but you can override those using the look_at and angle
keywords.
