POV-Ray : Newsgroups : povray.newusers : Parse warning on refraction Server Time
16 Dec 2025 16:26:40 EST (-0500)
  Parse warning on refraction (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Parse warning on refraction
Date: 17 Jun 2013 18:05:00
Message: <web.51bf86d6201eece978641e0c0@news.povray.org>
"gharryh" <h.a### [at] harry-arendsnl> wrote:
> I have some texture defs that are using refraction.
> How should i rewrite these defs to please the render machine.
> [code]
> #declare acrylic =
> texture {
>     pigment { White filter .9}
>     finish {
>         specular 1
>         roughness .005
>         reflection .1
>         ambient 0
>         diffuse 0
>         refraction 1
>         ior 1.4
> [/code]
This is very, very old syntax.  I don't even know what the refraction statement
means in this context, but this old post by C. Lipka suggests that nowadays it's
just dead code:
> - "refraction" is actually not necessary; it's just a relic from old times (I
> wonder where you got that from; it's not even mentioned in the online help
> anymore as far as I can tell). The amount of refracted light is nowadays
> controlled by the transmit & filter components of the pigment.
http://news.povray.org/povray.general/message/%3Cweb.49b8626c69fc1a9c801985dd0%40news.povray.org%3E/
The ior should be removed completely from the finish AND the texture, and put
inside an interior.  A texture and an interior may be combined in a material:
[code]
#declare Acrylic = material
{ texture {
      finish {
          specular 1
          roughness .005
          reflection .1
          ambient 0
          diffuse 0
       /* refraction 1  Remove these
          ior 1.4       two lines. */
  interior { ior 1.4 }
[/code]
To apply this to an object, use the material statement:
[code]
object { MyObject material { Acrylic } }
[/code]
Date: 18 Jun 2013 06:00:01
Message: <web.51c02ea0201eece9520168c30@news.povray.org>
> [code]
> [/code]
Just did that but got a error. I counted all the brackets but found no anomali.
{code]
union {  // Create a box with two rounded edges
    union {
        cylinder{<11,0,24><11,.1,24>1 }
        cylinder{<11,0,-24><11,.1,-24>1 }
        box{<11,0,25><-12,.1,-25> }
        box{<11,0,24><12,.1,-24> }
//    } texture { red_led }
      } material { red_led }
[/code]
with this as the material def:
[code]
#declare red_led = material {
        pigment {Red filter .6}
        finish {
            specular .7
            roughness .02
//            refraction 1
//            ior 1.5
    interior{ior 1.5}
[/code]
The rror is this:
"L:\POV-Ray\Aandrijving\TextLabel.inc" line 23: Parse Error: No matching } in
'material', texture identifier found instead
Date: 18 Jun 2013 06:00:02
Message: <web.51c02f33201eece9520168c30@news.povray.org>
> just dead code:
I just started again using POV-Ray as i am a retaired engineer.
I had to update from version 3.1
Date: 18 Jun 2013 06:36:19
Message: <51c03823$1@news.povray.org>
On 18/06/2013 10:55 AM, gharryh wrote:
> The rror is this:
Have you defined red_led as a texture, previously in your code?
Regards
Date: 18 Jun 2013 16:00:01
Message: <web.51c0bb11201eece9520168c30@news.povray.org>
> > The rror is this:
> Regards
>      Stephen
No it even goes wrong on a simple object in a clean scene
Date: 18 Jun 2013 17:31:22
Message: <51c0d1aa$1@news.povray.org>
>>> The rror is this:
>> Regards
>>       Stephen
well you're not giving us much context here! If TextLabel.inc is NOT
huge perhaps you could post that rather than the snipets you've posted
previously.
Date: 18 Jun 2013 17:41:10
Message: <51c0d3f6$1@news.povray.org>
Oh dear! That is a shame.
Because I just rendered your code in a scene and it was fine.
Regards
Date: 18 Jun 2013 22:24:08
Message: <51c11648$1@news.povray.org>
>> just dead code:
That explain the outdated code.
Some hints of things that worked but may yeld unexpected results now:
clipped_by must NEVER be used in place of intersection or difference. It
will cause some unexpected shadows abnomalies and some other problems.
Most of the time, you don't need any manual bounding. The exeption been
of some intersections when the end shape is small compared to the
component shapes.
The gradient pattern was on the absolute value, reversed on the negative
side, now the ramp is always in the same direction.
If you used radiosity, maximum_distance no longer exist and will cause
an error if present.
The old dual entries in color_map, texture_map,... is deprecated. It's
still suported without problem.
Date: 19 Jun 2013 03:09:11
Message: <51c15917@news.povray.org>
Which makes me guess - like Jim - that the problem resides within the
TextLabel.inc file itself. Gharryh, I suppose you include this file into
your main scene? In any case, examine the code around line 23 in the
include file. Big chance that the missing } is found there. If not,
experiment by adding  } successively at the end of each material block
and render, starting with the end of the file and gradually shift it
higher if the render works well. As soon as the render fails, you have
found the area to examine closely. I often do it that way when in
serious doubt.
Succes!
Date: 19 Jun 2013 12:45:01
Message: <web.51c1df4d201eece9520168c30@news.povray.org>
> serious doubt.
> Succes!
> Thomas
Solved the problem by removing all the old textures from the origional file and
creating a new one and that solved the problem. This is the content of that
file:
[code]
//    POV-Ray version 3.7 Include File
//    File: MyMaterials.inc
//    Last updated: June 2013
//    Description: This file contains my material defenitions.
#ifndef(MyMaterials_Temp)
#declare MyMaterials_Temp = version;
#version 3.5;
#ifndef(__colors_inc)
#declare MyRedLed = material {
        finish {
            specular .7
            roughness .02
    interior{ior 1.5}
#declare MyGreenLed = material {
        pigment {Green filter .6}
        finish {
            specular .7
            roughness .02
    interior{ior 1.5}
#declare MyAcrylic = material {
        pigment {Green filter .9}
        finish {
            specular 1
            roughness .005
            reflection .1
            ambient 0
            diffuse 0
    interior{ior 1.4}
#declare MyRedClearPlastic = material {
        pigment {Red filter .8}
        finish {
            specular 1
            roughness .001
            reflection .1
    interior{ior 1.4}
#declare MyGreenClearPlastic = material {
        pigment {Green filter .8}
        finish {
            specular 1
            roughness .001
            reflection .1
    interior{ior 1.4}
#version MyMaterials_Temp
[/code]
