![](/i/fill.gif) |
I need to have a disc with some part deleted.
Written these two scenes it should work IHO
[code]
#declare outer_ring =
union {
difference {
cylinder{<0.00,3.00,0.00><0.00,6.50,0.00>20.00 }
cylinder{<0.00,2.95,0.00><0.00,6.55,0.00>18.60 }
box{<0,0,0><-20.00,6.55,20.00> rotate<0.00, 10.00,0.00>}
box{<0,0,0>< 20.00,6.55,20.00> rotate<0.00,-10.00,0.00>}
#declare disq_slid =
union {
difference {
cylinder{<-20.00,2.95,0.00><-20.00,6.55,0.00>1.40 rotate<0.00,
10.00,0.00> }
cylinder{< 20.00,2.95,0.00>< 20.00,6.55,0.00>1.40
rotate<0.00,-10.00,0.00> }
object{ outer_ring }
} texture{red_plastic}
[/code]
The object{outer_ring} doesnt do anything.
I am cloeless why and how to solve it.
![](/i/fill.gif) |
![](/i/fill.gif) |
> [code]
> union {
> difference {
> union {
> difference {
> 10.00,0.00> }
> [/code]
outer_ring have an outside radius of 20, the same as the base object.
It's top is at 6.5, whitch is the same as the base object.
It's inner radius is 18.6 while the base object only have 2 small holes
located in the openings of outer_ring.
The end result is that outer_ring is totaly contained within a larger
object. As they share the same texture, the coincident surface have no
effect on the final aspect.
If you give it another texture, like texture{pigment{rgb
1}finish{reflection{0.5 metallic}}}
You'll get some coincident surface artefacts that would have given you
the hint.
Try making outer_ring very slightly larger with a different texture. You
can try this:
difference {
cylinder{<0.00,3.00,0.00><0.00,6.53,0.00>20.10 }
cylinder{<0.00,2.99,0.00><0.00,6.54,0.00>18.60 }
box{<0,2.99,0><-20.11,6.54,20.11> rotate<0.00, 10.00,0.00>}
box{<0,2.99,0>< 20.11,6.54,20.11> rotate<0.00,-10.00,0.00>}
texture{pigment{rgb 0.7}finish{specular 1 roughness 0.0001 metallic
reflection{0.7 metallic}} }
![](/i/fill.gif) |
