Hello! Sorry!
I on the former don't speak in English :)
//----Blender Object Name:Plane----
object {
Plane
matrix <4.580214, 0.000000, 0.000000, 0.000000, -0.000000, -4.580214,
0.000000, 4.580214, -0.000000, 0.000000, 0.000000, 0.000000>
light_source {
< 0,0,0 >
color rgb<0.6, 0.6, 0.6>
spotlight
falloff 37.50
radius 31.874999
tightness 0
point_at <?????????????????????????>
fade_distance 14.999991
fade_power 2
matrix <-0.942444, 0.000000, 0.334364, 0.268584, 0.595619, 0.757034,
-0.199154, 0.803267, -0.561337, 3.196899, 5.407235, -3.778671>
How to send light to object center?
Help me! Please!
On 29/05/2013 6:12 PM, LanuHum wrote:
> Hello! Sorry!
> object {
> Plane
> light_source {
> < 0,0,0 >
> spotlight
> falloff 37.50
> radius 31.874999
> tightness 0
> fade_power 2
> Help me! Please!
Hi and welcome.
There is an international news group where you can ask in languages
other than English.
You can find the co-ordinates of the bounding box of your object using,
the functions min_extent and max_extent. Search for them in PovRay help.
The centre of your object should be at the centre of the bounding box.
(Roughly speaking)
But since you are using Blender can you not point it at your object in
Blender?
Regards
> > Hello! Sorry!
> > object {
> > Plane
> > light_source {
> > < 0,0,0 >
> > spotlight
> > falloff 37.50
> > radius 31.874999
> > tightness 0
> > fade_power 2
> > Help me! Please!
> Hi and welcome.
> other than English.
> (Roughly speaking)
> Blender?
> Regards
> Stephen
in official povray addons:
elif lamp.type == 'SPOT':
tabWrite("spotlight\n")
# Falloff is the main radius from the centre line
tabWrite("falloff %.2f\n" % (degrees(lamp.spot_size) / 2.0)) #
1 TO 179 FOR BOTH
tabWrite("radius %.6f\n" % \
((degrees(lamp.spot_size) / 2.0) * (1.0 -
lamp.spot_blend)))
# Blender does not have a tightness equivilent, 0 is most like
blender default.
tabWrite("tightness 0\n") # 0:10f
tabWrite("point_at <0, 0, -1>\n")
I rewrite:
tabWrite("point_at <%.3g, %.3g, %.3g>\n"%ob.constraints["Track
To"].target.location[:])
It doesn't yield the necessary result as it is necessary to consider a matrix
> Hello! Sorry!
> object {
> Plane
> light_source {
> < 0,0,0 >
> spotlight
> falloff 37.50
> radius 31.874999
> tightness 0
> fade_power 2
> Help me! Please!
Use #declare to define your object.
#declare Object_name= ...
Replace "..." by the definition of your object.
Now, you can use
#declare Center=(min_extent(Object_name)+max_extent(Object_name))/2;
to get the center point of it's bounding box.
Use that value as your point_at location: point_at Center
Alternatively, if you create your object around the origin and translate
it into location, use the same coordinates for the translate and
point_at location.
> Now, you can use
> point_at location.
> Alain
object {
Sphere_001
matrix <1.000000, 0.000000, 0.000000, 0.000000, -0.000000, -1.000000,
0.000000, 1.000000, -0.000000, 3.060443, 0.988657, -0.000000>
#declare Center=(min_extent(Sphere_001)+max_extent(Sphere_001))/2;
//--Lamps--
light_source {
< 0,0,0 >
spotlight
falloff 37.50
radius 31.874999
tightness 0
point_at Center
fade_power 2
Doesn't work. All black. Light doesn't fall on the Sphere_001
>> Now, you can use
>> point_at location.
>> Alain
> object {
> Sphere_001
> //--Lamps--
> light_source {
> < 0,0,0 >
> spotlight
> falloff 37.50
> radius 31.874999
> tightness 0
> point_at Center
> fade_power 2
I think that what is going wrong is that you are creating the spotlight
at the origin, pointing it at the sphere then transposing it with your
matrix function. So the spotlight ends up not pointing at the sphere.
Try this:
object {
Sphere_001
//--Lamps--
light_source {
0.757034,
spotlight
falloff 37.50
radius 31.874999
tightness 0
point_at Center
fade_power 2
Regards
>> Now, you can use
>> point_at location.
>> Alain
> object {
> Sphere_001
> //--Lamps--
> light_source {
> < 0,0,0 >
> spotlight
> falloff 37.50
> radius 31.874999
> tightness 0
> point_at Center
> fade_power 2
Your matrix transform is applied to both the origin of your light and to
the point_at coordinate.
You need to transform the location of your light BEFORE you set the
point_at location.
> point_at location.
> Alain
Alain, Thanks, but I don't understand your idea
Each object has own matrix. If I transform one, it will be necessary to
transform all remaining
The response is found in Povray documentation: matrix
Users of Blender prompted that my problem was that axes of coordinates are
various in Blender and in Povray
// location 3.0604 0.0000 0.9887
// x=1.000000*3.060443+0.000000*0.988657+0.000000*0.000000+3.060443=6.12
// y=0.000000*3.060443+0.000000*0.988657+0.000000*0.000000+0.988657=1.96
// z=0.000000*3.060443+1.000000*0.988657+0.000000*0.000000+0.000000=0.99
point_at <-0.99,-1.96,-6.12> (-z, -y, -x) :)
Another way of saying what Alain said in non technical terms.
When you set the location of the spotlight (you set it to < 0,0,0 >)
then set the point_at. PovRay will calculate the angles. If you then
transpose the spotlight the point_at will still keep these angles and
the light beam will miss your sphere.
An alternative method would be to take the spotlight coordinates from
your Blender light and use them as the location in the PovRay Spotlight.
Then the point_at will work as you want it to if you do not add any more
translations or rotations.
Be aware if you do this then the centre of rotation of the spotlight
will be at the origin.
Example:
#declare Sphere_001 =
sphere {
0.0, 0.500000
texture{ Non_Patterned_Texture }
rotate <0.000000,0.000000,0.000000>
translate <3.000000,1.000000,0.000000>
#declare Light_Source1 =
light_source {
< 3.196899, 5.407235, -3.876671 >, colour rgb <0.600,0.600,0.600>
spotlight
point_at < 3.000000, 1.000000, 0.000000 >
radius 32.549
falloff 37.500
tightness 0
fade_power 2.000
fade_distance 14.900
media_attenuation off
media_interaction on
Regards
>> point_at location.
>> Alain
Yes, a given object only have one matrix... BUT...
The final matrix never need to be applied at once and, when applied in
several steps, the part that are applied AFTER any transformation is
never affected by any previous manipulation.
You can apply a matrix transformation, then scale, rotate or translate
your object, add some elements like a point_at (for a light) or a
texture (for an object), then apply another matrix transformation.
For a light source, I prefer to define it directly at it's intended
location, not translating in any way unless it's part of some complexe
object in an union.
Any and all transformation always apply to all elements that are defined
previous to it's application, mever to those that follow.
Do this test:
Create a scene consisting only of a white plane and several spot lights
like this:
#declare Middle=0;
//ground plane
plane{y,0 pigment{rgb 1/8}}
//a back plane to keep rays finite
plane{-z,-30 pigment{rgb 0}}
//the camera
camera{location<0,10,-30> look_at 0}
// setting the creation of 5 lights in a loop
#declare L_Num=5;
#while(L_Num>0)
light_source{<-25,90,0> rgb 8
spot_light radius 1 falloff 2
#if(Middle=1)translate 10*x #end
// this translate ONLY the light and NOT the point_at
point_at 0
#if(Middle=0)translate 10*x #end
// This translate BOTH the light and the point_at
#declare L_Num=L_Num-1;
#end // of the loop
media{scattering{1 rgb 0.1}}
This will create 5 tight spot lights.
If you render with Middle=0, you'll get 5 bright spots with beams that
are parallel.
If you render with Middle=1, you'll get only 1 brighter spot with
converging beams.
The media make the beams visible.
