POV-Ray : Newsgroups : povray.newusers : Media scattering and photons doesn't work! Server Time
16 Dec 2025 16:04:18 EST (-0500)
  Media scattering and photons doesn't work! (Message 11 to 16 of 16)
Subject: Re: Media scattering and photons doesn't work!
Date: 27 Jul 2013 02:38:42
Message: <51f36af2@news.povray.org>
Am 27.07.2013 08:16, schrieb LanuHum:
> Hi.
> Problem:
> http://yadi.sk/d/NZMlm3V67GSZa
> 1. if scattering box == false and global setting photons == true:
> good image with photons
> 2. if scattering box == true and global setting photons == false:
> good image with scattering
> 3. if scattering box == true and global setting photons == true:
> bad image with scattering and photons!
> in scattering box:    photons { pass_through }
> but scattering box is visible :(
> why scattering box is visible?
> //--Scattering media box--
> box {
>      <-12.06,43.79,-27.81>,
>      <-0.03095,-11.48,17.8>
>      pigment { rgbt 1 } hollow
>      interior {
>           media {
>                scattering { 1,
>                    <0.06998, 0.06998, 0.06998>
>                 extinction 0.01 }
>                samples 100
Be aware that to get a really invisible box, setting the pigment to full
transparency is not enough. You also need to make sure that you disable
highlights.
By default, specular highlights are added to any material that does not
have an explicit "specular" statement. You will need to add:
     finish { specular 0 }
You might also want to explicitly turn off diffuse and ambient:
     finish { ambeint 0 diffuse 0 specular 0 }
I think it shouldn't make a difference for fully transparent surfaces,
but I might be mistaken there.
Date: 27 Jul 2013 03:25:35
Message: <51f375ef$1@news.povray.org>
Huh? I didn't know that! I thought that by default, and in the absence
of a specular statement, specular was 0.
Date: 27 Jul 2013 03:53:58
Message: <51f37c96$1@news.povray.org>
Am 27.07.2013 09:25, schrieb Thomas de Groot:
You are indeed right, just checked the code. I probably messed it up
with the defaults typically set by most of the scene templates from the
insert menu.
Date: 27 Jul 2013 07:01:46
Message: <51f3a89a@news.povray.org>
> insert menu.
Pheeww.... my world almost toppled over ;-)
Date: 27 Jul 2013 08:00:01
Message: <web.51f3b574f0c558ea7a3e03fe0@news.povray.org>
Didn't help. Changes not found.
Date: 29 Jul 2013 12:25:01
Message: <web.51f6971af0c558ea7a3e03fe0@news.povray.org>
Yes!!!
{ scattering { 1, 0.07 extinction 0.01 } - bad way in my scene.
Good way - type 5 and eccentricity:
{ scattering { 5, 0.07 extinction 0.01 eccentricity 0.6 }
