POV-Ray : Newsgroups : povray.newusers : Transparent body creates "hole" in my picture Server Time
21 Feb 2025 13:03:22 EST (-0500)
  Transparent body creates "hole" in my picture (Message 1 to 4 of 4)
Subject: Transparent body creates "hole" in my picture
Date: 8 Sep 2012 16:30:00
Message: <web.504ba9f656a1714d5adc078b0@news.povray.org>
Hello everyone!
I'm trying to build two cylinders a bit transparent on top of each other (one
blue and the other red). Inside theses cylinders, there is a circular arrow
(again one blue and the other red). I want the red one to be fully transparent
(at the beginning, because the final goal is to make an animation, in which this
red arrow will become not transparent).
On the rendered picture, we can see a kind of "hole" in the red cylinder that is
unwanted. It's like if a part of the red arrow make trouble while rendering and
the transparency of the red cylinder is not uniform.
Here is the code:
#include "glass.inc"
#include "textures.inc"
#declare epaisseurBL = 6;
#declare epaisseurIL = 6;
#declare epaisseurTL = 16;
#declare linethk =0.1;
#declare camy=145;
#declare camz=170;
#declare offsettxt=50;
#declare vuex= atan2(camy,camz)*180/pi;
#declare vuey= atan2(camz,offsettxt)*180/pi;
  location<0,0,0>
  look_at <0,0,-1>
  rotate<-2,0,0>
  translate <-18,(epaisseurBL+epaisseurIL+epaisseurTL)/2, 200>
  rotate <-vuex,0,0>
  angle 30
global_settings
  max_trace_level 9
background { color White}
light_source {
    <0, 10, 30>
    color White
    fade_distance 60
    fade_power 2
shadowless
  light_source {
    <0, 10, 30>
    color White
    fade_distance 60
    fade_power 2
shadowless
light_source {
    <20, 10, 0>
    color White
    fade_distance 60
    fade_power 2
shadowless
  light_source {
    <20, 10, 0>
    color White
    fade_distance 60
    fade_power 2
shadowless
light_source {
    <0, 50, 0>
    color White
    fade_distance 60
    fade_power 2
shadowless
  // vert <0.2,1,0>
#declare couleur1 = Blue;
#declare amb = 0.4;
#declare couleur2 = Red;
#declare transmission = 0;
#declare trans1 = 0;
#declare trans2 = 0;
#declare dif = 0.3;
#declare ref = 0;
#declare ang = 70;
#declare refcyl = 0;
#declare epaisseurBL = 10;
#declare epaisseurIL = 4;
#declare epaisseurTL = 10;
#declare FlecheCirculaire = merge{
  difference{
  cylinder {
    <0, -1, 0>,     // Center of one end
    <0, 1, 0>,     // Center of other end
    25            // Radius
  merge{
    cylinder {
      <0, -3, 0>,     // Center of one end
      <0, 3, 0>,     // Center of other end
      20            // Radius
    prism {
      linear_spline
      -2, // sweep the following shape from here ...
      2, // ... up through here
      3, // the number of points making up the shape ...
      < 0, 0>, // point#1 (control point... not on curve)
      <  tan(ang/2*pi/180)*50,50>, // point#2  ... THIS POINT ...
      < - tan(ang/2*pi/180)*50, 50> // point#3
prism {
    linear_spline
    -1, // sweep the following shape from here ...
    1, // ... up through here
    < -4, 0>, // point#1 (control point... not on curve)
    < 4,0>, // point#2  ... THIS POINT ...
    < 0,7> // point#3
    rotate<0,90-ang/2,0>
    translate<-sin(ang/2*pi/180)*22.5,0,cos(ang/2*pi/180)*22.5>
cylinder {
      2            // Radius
#declare MTJ =
    merge {
      object { FlecheCirculaire
        scale <0.8,0.65,0.8>
        pigment{color couleur1 transmit transmission}
        finish { ambient amb diffuse dif reflection ref }
        translate <trans1,0,0>
        translate <0,epaisseurBL/2,0>
        pigment{color couleur2 transmit transmission+1}
        translate <trans2,0,0>
        translate <0,epaisseurBL+epaisseurIL+epaisseurTL/2,0>
object { MTJ scale <1,1,1>}
//Blue layer
#declare layer1=
cylinder {
      <0, 0, 0>,     // Center of one end
      <0,epaisseurBL, 0>,     // Center of other end
      30            // Radius
        pigment{color couleur1 transmit 0.7}
//Insulator layer
#declare layer2=
cylinder {
      <0, epaisseurBL, 0>,     // Center of one end
      <0, epaisseurBL+epaisseurIL, 0>,     // Center of other end
      30            // Radius
        pigment{color White transmit 1}
//Red layer
#declare layer3=
cylinder {
      <0, epaisseurBL+epaisseurIL, 0>,     // Center of one end
      <0, epaisseurBL+epaisseurIL+epaisseurTL, 0>,     // Center of other end
      30            // Radius
        pigment{color couleur2 transmit 0.7}
object{layer1}
object{layer2}
object{layer3}
If you want to see the red arrow, change the transmit parameter line 159.
I use those rendering parameter in my .ini file:
Width=1024
Height=768
Antialias=On
Sampling_Method=2
Antialias_Threshold=0.01
Antialias_Depth=4
I tried to change the max_trace_level up to 50, increase the Antialias Depth
until 7 and Antialias_Threshold down to 0.001 without success.
I use the 3.6 version of POV-ray.
If you have any idea to solve this problem tell me!
JO
Subject: Re: Transparent body creates "hole" in my picture
Date: 9 Sep 2012 14:41:21
Message: <504ce2d1$1@news.povray.org>
> unwanted.
If you are referring to the black bar, it goes away when increasing
max_trace_level to 11. Also note that your stacked cylinders have
coincident surfaces which causes some graininess, add 0.001 to the
y value of the first point in cylinders layer2 and layer3.
Date: 9 Sep 2012 14:56:30
Message: <504ce65e$1@news.povray.org>
> Hello everyone!
> Here is the code:
Don't include those as you don't use the textures they define.
> //#include "glass.inc"
> //#include "textures.inc"
> #declare camy=145;
> #declare camz=170;
> camera {
>    location<0,0,0>
>    look_at <0,0,-1>
>    rotate<-2,0,0>
>    rotate <-vuex,0,0>
>    angle 30
> global_settings
>    max_trace_level 9
> light_source {
>      <0, 10, 30>
>      color White
>      fade_distance 60
>      fade_power 2
> shadowless
>    light_source {
>      <0, 10, 30>
>      color White
>      fade_distance 60
>      fade_power 2
> shadowless
> light_source {
>      <20, 10, 0>
>      color White
>      fade_distance 60
>      fade_power 2
> shadowless
>    light_source {
>      <20, 10, 0>
>      color White
>      fade_distance 60
>      fade_power 2
> shadowless
> light_source {
>      <0, 50, 0>
>      color White
>      fade_distance 60
>      fade_power 2
> shadowless
>    // vert <0.2,1,0>
> #declare amb = 0.4;
> #declare dif = 0.3;
> #declare ref = 0;
> #declare ang = 70;
>    difference{
>    cylinder {
>      25            // Radius
Useless merge
>    //merge{
>      cylinder {
>        20            // Radius
>      prism {
>        linear_spline
>        < 0, 0>, // point#1
> prism {
>      linear_spline
>      < 4,0>, // point#2
>      < 0,7> // point#3
> cylinder {
>        2            // Radius
> #declare MTJ =
>      merge {
>          texture {
>          texture {
Change this line like this:
pigment{color couleur2 transmit 1 -transmission}
Otherwise, you get a transmission value larger than 1 whitch gives
strange results.
> //Blue layer
> #declare layer1=
> cylinder {
>        30            // Radius
>        texture {
> //Insulator layer
> #declare layer2=
Changes to prevent coincident surfaces...
> cylinder {
<0, epaisseurBL+0.00001, 0>,
<0, epaisseurBL+epaisseurIL-0.00001, 0>,
>        30            // Radius
>        texture {
> //Red layer
> #declare layer3=
> cylinder {
>        30            // Radius
>        texture {
Your problem is here.
> object{layer1}
> object{layer2}
> object{layer3}
You have coincident surfaces.
Redefine your layer objects so that they never overlap and have a very
small gap between them.
Another solution would be to translate layer 1 slightly up and layer3
slightly down.
> Width=1024
> Height=768
> Antialias=On
> Sampling_Method=2
> Antialias_Depth=4
> JO
Date: 11 Sep 2012 07:30:00
Message: <web.504f200259d73b265adc078b0@news.povray.org>
> > Hello everyone!
> > Here is the code:
> > #declare camy=145;
> > #declare camz=170;
> > camera {
> >    location<0,0,0>
> >    look_at <0,0,-1>
> >    rotate<-2,0,0>
> >    rotate <-vuex,0,0>
> >    angle 30
> > global_settings
> >    max_trace_level 9
> > light_source {
> >      <0, 10, 30>
> >      color White
> >      fade_distance 60
> >      fade_power 2
> > shadowless
> >    light_source {
> >      <0, 10, 30>
> >      color White
> >      fade_distance 60
> >      fade_power 2
> > shadowless
> > light_source {
> >      <20, 10, 0>
> >      color White
> >      fade_distance 60
> >      fade_power 2
> > shadowless
> >    light_source {
> >      <20, 10, 0>
> >      color White
> >      fade_distance 60
> >      fade_power 2
> > shadowless
> > light_source {
> >      <0, 50, 0>
> >      color White
> >      fade_distance 60
> >      fade_power 2
> > shadowless
> >    // vert <0.2,1,0>
> > #declare amb = 0.4;
> > #declare dif = 0.3;
> > #declare ref = 0;
> > #declare ang = 70;
> >    difference{
> >    cylinder {
> >      25            // Radius
> Useless merge
> >    //merge{
> >      cylinder {
> >        20            // Radius
> >      prism {
> >        linear_spline
> >        < 0, 0>, // point#1
> > prism {
> >      linear_spline
> >      < 4,0>, // point#2
> >      < 0,7> // point#3
> > cylinder {
> >        2            // Radius
> > #declare MTJ =
> >      merge {
> >          texture {
> >          texture {
> strange results.
> > //Blue layer
> > #declare layer1=
> > cylinder {
> >        30            // Radius
> >        texture {
> > //Insulator layer
> > #declare layer2=
> > cylinder {
> >        30            // Radius
> >        texture {
> > //Red layer
> > #declare layer3=
> > cylinder {
> >        30            // Radius
> >        texture {
> > object{layer1}
> > object{layer2}
> > object{layer3}
> slightly down.
> > Width=1024
> > Height=768
> > Antialias=On
> > Sampling_Method=2
> > Antialias_Depth=4
> > JO
Hello,
thanks for your reply. I've corrected my code with your advices and it works
well! I already know a bit about this coincident surface problem but I forgot to
check it on my code, and that was the problem! Thanks a lot!
Yvan
