POV-Ray : Newsgroups : povray.newusers : Intersection of Mesh and Box Server Time
28 Sep 2024 18:57:11 EDT (-0400)
  Intersection of Mesh and Box (Message 1 to 6 of 6)
Subject: Intersection of Mesh and Box
Date: 8 Sep 2012 10:00:00
Message: <web.504b4e1d416e823cffb9b00a0@news.povray.org>
Hello,
I'd like to get an intersection of a cube and an octahedron (mesh).
I use this code:
  intersection {
    mesh2 { //Oktaeder
      vertex_vectors {
        6,
        <0,-1,0>,
        <-1,0,0>,
        <0,0,-1>,
        <1,0,0>,
        <0,0,1>,
        <0,1,0>
      face_indices {
        8,
        <0,1,2>,
        <0,2,3>,
        <0,3,4>,
        <0,4,1>,
        <5,1,2>,
        <5,2,3>,
        <5,3,4>,
        <5,4,1>,
    box {
      <-1,-1,-1>*0.7, <1,1,1>*0.7
    pigment { Red }
    rotate y*20     // Equivalent to "rotate <0,20,0>"
The problem is, that some of the faces (the faces of the cube) are transparent,
although they should have a red surface.
Any help will be appreciated. (I'm not a native speaker)
Johannes
Subject: Re: Intersection of Mesh and Box
Date: 8 Sep 2012 10:17:43
Message: <504b5387$1@news.povray.org>
In order for a mesh to be treated as a solid (not a surface),
you need to add an inside_vector statment, e.g. inside_vector y
Date: 8 Sep 2012 15:15:01
Message: <web.504b9824b262974a51b128b30@news.povray.org>
Thank you very much!
It worked :D
Date: 9 Sep 2012 13:56:53
Message: <504cd865$1@news.povray.org>
> It worked :D
You need to make sure that the inside_vercor is not parallel to any
face. If that's the case, change it's value slightly,like: <0.01,1,0>
Date: 25 Sep 2012 12:30:00
Message: <web.5061db4db262974a85de7b680@news.povray.org>
Is this documented anywhere? It is good to know. (It makes sense, now that I
think about it.)
Date: 26 Sep 2012 21:51:24
Message: <5063b11c$1@news.povray.org>
> think about it.)
I think so.
Also, ther is a mention that if there are artefacts or apparent holes,
that changing the inside_vector direction by a tiny amount will normaly
resolve the isue. In some cases, it will switch to another face, but,
with some luck and findling, it will happen in some area where it don't
mather: Back side, outside the intersection/difference area, hiden by
another object,...
