POV-Ray : Newsgroups : povray.newusers : Height_field clipped_by a box Server Time
18 Nov 2025 17:01:31 EST (-0500)
  Height_field clipped_by a box (Message 1 to 10 of 11)
Subject: Height_field clipped_by a box
Date: 29 Aug 2012 04:35:00
Message: <web.503dd37771e7393e270882f00@news.povray.org>
Me again..
Sorry if I post a lot..
I wanted to clip a height_field by a box using clipped_by but it doesn't work
height_field {
        png
        "IN\dem.png"
        smooth
        texture{
        White
        finish {
        ambient 0.1
        diffuse 0.55
        clipped_by { box { <0,0,0>,<10,10,10 > }}
        translate <-0.5,0,-0.48>
        scale <14,4,14>
However, intersection works. Intersection isn't the best, I think, for that
purpose? clipped_by or bounding-by seems more convenient.
Mat
Subject: Re: Height_field clipped_by a box
Date: 29 Aug 2012 06:20:22
Message: <503dece6$1@news.povray.org>
Am 29.08.2012 10:31, schrieb mathieu_r:
> Hi,
> Me again..
That's what the newsgroups are there for :-)
Can you be more specific about the "doesn't work" part?
The difference between intersection and clipped_by is that an
intersection will generate new surfaces where the original object is cut
apart, while clipped_by will let you look inside the object as if it was
just a hollow shell.
> purpose?
If it works, it works.
Do /not/ use bounded_by for such purposes. It is intended solely as a
hint for the renderer about how big (and where) a complicated object
actually is, to speed up finding the object's surface. Any attempt to
use it for shaping your object /will/ lead to unexpected results.
Date: 29 Aug 2012 09:10:01
Message: <web.503e1476c872e122270882f00@news.povray.org>
Ok, so Intersection seems the right way to do it.
I have another question:
I've intersected my height_field with my box. Ok but between my height_field and
the bottom of my box there is an empty gap. How to fill it? You know, like city
models
If possible with the same texture as the height_field object.
> > Hi,
> > Me again..
> > purpose?
Date: 29 Aug 2012 11:28:53
Message: <503e3535$1@news.povray.org>
Am 29.08.2012 15:09, schrieb mathieu_r:
> models
Intersect the height field with a slightly smaller box; i.e, instead of:
   height_field {
     texture { ... }
     translate ... scale ... rotate ...
use the following:
   intersection {
     height_field { ... }
     box { <0.0001, 0.0001, 0.0001>, <0.9999, 1.0001, 0.9999> }
     texture { ... }
This works due to some inconsistency of the height_field object:
Although it lacks a visible bottom and sides, it is nonetheless
considered to be filling the entire space below the surface; so if you
cut off its "non-sides" and "non-bottom", you'll get visible surfaces at
the cuts.
Date: 30 Aug 2012 05:35:01
Message: <web.503f32c8c872e1222ebecedb0@news.povray.org>
Nice! Thanks. It works!
> > models
>    height_field {
>      texture { ... }
> use the following:
>    intersection {
>      texture { ... }
> the cuts.
Date: 31 Aug 2012 07:20:01
Message: <web.50409d54c872e122a7fd5a260@news.povray.org>
Sorry, I come back..
Actually, filling my object is easier than making it empty..
To make it empty, I tried to clip my height_object with a sphere with a value of
transmit equal to 1.
But I can still see the sphere contours even if they're smoothened.
Maybe I didn't use the transmit keyword the right way?
Here is the code:
intersection {
height_field {
        png
        "IN\PNG\dem.png"
        smooth
        texture{
        White
        finish {
        ambient 0.1
        diffuse 0.55
        scale <14,4,14>
sphere {
  <0, 1, 0>
  5
  White
  transmit 1
  hollow on
> > > models
> >    height_field {
> >      texture { ... }
> > use the following:
> >    intersection {
> >      texture { ... }
> > the cuts.
Date: 31 Aug 2012 16:18:10
Message: <50411c02$1@news.povray.org>
Am 31.08.2012 13:17, schrieb mathieu_r:
Why not simply use clipped_by for that purpose?
Try explicitly specifying the sphere's finish as "ambient 0 diffuse 0
specular 0 phong 0 emission 0 reflection 0"; maybe some earlier
"default" statement is setting one of these values to non-zero by default.
Date: 2 Sep 2012 14:23:09
Message: <5043a40d$1@news.povray.org>
> Hi,
> Me again..
> height_field {
>          png
>          "IN\dem.png"
>          smooth
>          texture{
>          pigment {
>          White
>          finish {
>          ambient 0.1
>          diffuse 0.55
>          scale <14,4,14>
> Mat
You clip your hight_field by a box that is 10 times to big.
You need to:
1 - make the box buch smaller.
OR
2 - Use your actual box AFTER you scale the hight_field, but before you
move it. Also, adjust the translate by your scale.
scale <14,4,14>
translate <-0.5,0,-0.48>*14
Date: 3 Sep 2012 03:20:06
Message: <50445a26@news.povray.org>
> You need to:
> OR
> scale <14,4,14>
Expanding a bit on this (see also the corresponding Docs paragraphs):
- A height_field starts as a 1x1x1 object. If you use clipped_by
/before/ scaling the height_field it should be smaller than the unit object.
- The order in which you perform the transformations is crucial and you
should always think about them as operating from the origin. The basic
order is /scale/ then /rotate/ then /translate/. Any other order will
lead to (possibly) unexpected results. Example:
box {-1, 1 rotate 45*y translate 10*x} will show a box rotated 45
degrees around the vertical axis and translated 10 units along the x-axis.
box {-1, 1 translate 10*x rotate 45*y} will rotate a box placed at 10
units on the +x-axis, 45 degrees towards the -z-axis.
Date: 3 Sep 2012 12:55:01
Message: <web.5044e0d3c872e12255f6125a0@news.povray.org>
I didn't know all of these prerequisites, in particular the scale / transmate
order.
I think that clipka's right. I'll try his solution, that is setting ambient,
diffuse, specular, phong,... to 0
I'll try this out and let you know.
Thanks for all your advice!
Mat
> > You need to:
> > OR
> > scale <14,4,14>
> Thomas
