POV-Ray : Newsgroups : povray.newusers : mesh2: vertex_vectors and normal_vectors Server Time
26 Jun 2024 04:12:58 EDT (-0400)
  mesh2: vertex_vectors and normal_vectors (Message 1 to 9 of 9)
Subject: mesh2: vertex_vectors and normal_vectors
Date: 16 Jul 2012 04:15:00
Message: <web.5003cc13bfc2ad88940d19d60@news.povray.org>
Hi there.
I have several mesh2 objects (generated from 3ds files with Rheingold3D) which
work just fine when I use them in Povray scenes.
However, I'd also like to import them into a realtime 3D engine (Irrlicht) to do
a kind of preview.
I'm currently writing a parser to do just that.
Now the problem: I noticed that several of the meshes have fewer normal_vectors
than vertex_vectors. How is the assignment done in these cases, meaning, how do
I know which normal vectors belong to which vertex vectors?
Subject: Re: mesh2: vertex_vectors and normal_vectors
Date: 16 Jul 2012 07:22:39
Message: <5003f97f$1@news.povray.org>
Le 16/07/2012 10:12, Ansgar a écrit :
> Hi there.
> a kind of preview.
Greetings,
Mesh2 is a syntax which delights in using indexes.
vertex_vectors are/is the raw set of vertex's/vertices' position.
normal_vectors are/is the raw set of normal's vector.
Usually, there is no duplicate entry in a set: let's take a mesh2 of a
torus. Every vertex is different. Yet, some vertices have exactly the
same normal (e.g. on the top circle, every point has a normal pointing up).
*answer to question*:
The real description of the association between vertices (to form
triangle or smooth_triangle) themselves and between vertices and
normales happens in face_indices{} and normal_indices{}
face_indices can become more complex with textures (including the
capability that each vertex of a triangle get its own texture, and that
the texture associated with a vertex might change along with each
triangle it is part of).
See >
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.1#Mesh2_Object
Date: 16 Jul 2012 07:47:05
Message: <5003ff39$1@news.povray.org>
Am 16.07.2012 10:12, schrieb Ansgar:
> Hi there.
> a kind of preview.
Are you sure you want to go though all that pain, and not use some
existing tool? PoseRay comes to my mind (AFAIK it can convert between
.obj and POV-Ray mesh2 both ways.)
Date: 17 Jul 2012 02:20:01
Message: <web.5005038b1e53fec44f1bb22c0@news.povray.org>
> See >
Well thanks for the answer, but I'm not sure what to make of this. Does it mean
that I scan the entire list of normal_indices, and when a particular index of a
vertex_vector never appears in it, it means that this particular vertex_vector
has no normal_vector?
Well currently my program is using .3ds files for the preview and POV mesh2
files for the final raytracing in POV. Works, sure thing. It would just be more
elegant if the preview renderer could read the pov files as well, then I
wouldn't have to deliver the geometry files twice in two different formats. :)
Clearer now? :)
Btw, thanks for your replies so far. :)
Date: 17 Jul 2012 02:36:54
Message: <50050806$1@news.povray.org>
>> > See >
Nop.
face_indices{} lists, with order, all the triangles (true or smooth) of
the mesh.
normal_indices{} uses the same order as face_indices{} to described the
faked normal attached at a vertex for a triangle. When the number of
entries in normal_indices{} is smaller than the number of entries in
face_indices{}, the end of the list are just flat triangles without
faked normales.
face_indices{} references the vertex_vector{}
normal_indices{} reference the normal_vector{}
Triangle#23 in face_indices{} has the same position in normal_indices{}.
Date: 17 Jul 2012 03:00:00
Message: <web.50050d1b1e53fec44f1bb22c0@news.povray.org>
Blargh. Got it. Thanks a lot for your help! :)
Date: 17 Jul 2012 03:04:21
Message: <50050e75@news.povray.org>
> Clearer now? :)
Poseray can read (and preview) mesh2 files, in addition to .obj, .3ds,
.lwo, .dxf, .raw, .wrl, .gz
Date: 17 Jul 2012 03:25:00
Message: <web.500512771e53fec44f1bb22c0@news.povray.org>
> Thomas
Thanks for the info, but I kinda need my own program to do it. :)
It's a uniform creator for an online gaming club, it gathers all the rank/award
info and compiles it to a uniform. You can preview it in OpenGL or Direct3D and
raytrace it with POV.
So I'm not trying to build another Poseray but something entirely different.
Date: 17 Jul 2012 03:28:05
Message: <50051405$1@news.povray.org>
You are welcome. Just in case you were not trying to reinvent the wheel
so to speak ;-) Personally, I sure would hate to do that.
