POV-Ray : Newsgroups : povray.newusers : Mirror Reflection Server Time
26 Mar 2026 06:13:14 EDT (-0400)
  Mirror Reflection (Message 1 to 6 of 6)
Subject: Mirror Reflection
Date: 6 Jun 2012 06:40:00
Message: <web.4fcf323e3c804514295860870@news.povray.org>
Hello I know this must sound an obvious question but i have taken the optics
demo apart to ray trace a scene which reflects a directional photon beam with a
mirror. The problem is that the beam stops at the mirror. I have tried to set
the max_trace_level to higher numbers and still can't figure out why this
doesn't work.
If somebody can give me a hand i would be grateful. Thanks in advance
Paulo Neves
#version 3.7;
global_settings {
    max_trace_level 5
    photons {
        count 150000
        max_trace_level 9
        media 500, 2
#declare CamPos = < 0, 18, 0>;
    location CamPos
    look_at < 0, 0, 0>
    angle 35
light_source {CamPos, color Gray25
    photons {refraction off reflection off}
    media_interaction on
light_source {<-150, 0.5, 0>, color rgb < 1.2, 1, 1.5>
    spotlight radius 0.3 falloff 0.35 point_at < 0, 0.5, 0>
    photons {refraction on reflection on}
#macro Block(From, To)
    union {
        cylinder {From, To*(x+z), 0.1 scale < 1, 10*To.y, 1>
                pigment {checker color Gray90, color Gray70
                    scale 0.1
                finish {brilliance 0.5}
        cylinder {From, To*(x+z), 0.025
            translate y*To
                pigment {color rgb < 1, 0.7, 0.2>}
                finish {ambient 0.8}
box {<-100,-1,-100>, < 100, 0, 100>
        pigment {checker color Gray90, color rgb < 0.2, 0, 0.4>}
        finish {brilliance 0.25}
box {<-7,-0.1,-3>, < 6, 1, 4> hollow
    texture {pigment {color rgbf 1}}
    interior {
        media {
            scattering {0.5, color White extinction 0}
//            emission color White*0.2
            method 3
            intervals 1 samples 4
    photons {target}
union {
    difference {
        object {Block(<-4, 0,-3>, <-4, 1.5, 3>)}
        box {<-5, 0.25,-0.5>, < -3, 0.75, 0.5>}
    cylinder {<-4, 0, 0>, <-4, 1.5, 0>, 0.1 translate z*0.15}
    cylinder {<-4, 0, 0>, <-4, 1.5, 0>, 0.1 translate -z*0.15}
    texture {pigment {color rgb 1}}
#declare MirrorTex1 =
    pigment {color White}
    finish {ambient 0 diffuse 0 reflection 1 ambient 1}
#macro PhotonTarget(Reflect, Refract, IgnorePhotons)
 photons {
  target
  reflection Reflect
  refraction Refract
  collect off
#macro Mirror(Pos, Ang, Width, Height, Tex)
 box {<-0.1,-0.1,-Width/2>, < 0, Height, Width/2>
     texture {Tex}
     PhotonTarget(yes, yes, yes)
     rotate -y*Ang
     translate Pos
object {Mirror(<-3, 0, 0>, 3*45, 2, 1, MirrorTex1)}
Subject: Re: Mirror Reflection
Date: 6 Jun 2012 09:19:13
Message: <4fcf58d0@news.povray.org>
> doesn't work.
  I think that you have to specify "photons { pass_through }" in your
media container box, or else they won't show up in the media.
  (Yes, this is highly unintuitive, and I don't know why it works like
that. It's probably a quirk that ought to be fixed.)
  See also
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.7#Media_and_photons
Date: 6 Jun 2012 10:57:29
Message: <4fcf6fd9@news.povray.org>
>    See also
I think that Clipka mentioned that there is a bug in RC4 & RC5 that
breaks it.
Ver 3.6 works though.
Regards
Date: 6 Jun 2012 11:19:13
Message: <4fcf74f1$1@news.povray.org>
Am 06.06.2012 12:34, schrieb ptsneves:
> doesn't work.
As Stephen already mentioned, this is a known bug in 3.7 RC5; the next
release will fix it.
Date: 6 Jun 2012 16:50:00
Message: <web.4fcfc1ebfeb1e11a295860870@news.povray.org>
> > doesn't work.
Yep it seems that the original code i pasted works under 3.6 and not on 3.7. Is
there a patch i can apply instead of waiting. The difference in render time is
quite obvious
Date: 6 Jun 2012 20:59:38
Message: <4fcffcfa@news.povray.org>
Am 06.06.2012 22:47, schrieb ptsneves:
>>> doesn't work.
> quite obvious
If you're using Linux, or have a way to build 3.7 RC5 for your system,
then it should be quite simple. Change the backend/render/trace.cpp file
as follows:
At the end of the function Trace::ComputeReflection() (somewhere near
line 1290), replace the lines
   Colour tmpCol;
   TraceRay(nray, tmpCol, weight, ticket, false);
   RGBColour tmpCol2(tmpCol);
   if (finish->Irid > 0.0)
     ComputeIridColour(finish, Vector3d(nray.Direction),
                       Vector3d(ray.Direction), normal, ipoint, tmpCol2);
   colour += Colour(tmpCol2);
with
   if (!ray.IsPhotonRay() && (finish->Irid > 0.0))
     Colour tmpCol;
   else
     TraceRay(nray, colour, weight, ticket, false);
Then rebuild. That'll fix it.
If you can't build a modified 3.7 RC5 for your system, I'm afraid you'll
have to wait for RC6.
