No matter what I do, when I begin a render, in render options it says my
antialiasing is turned off.
For example, I began a render with
+A0.3 +AM2 +R3 +Q11
and render options are as follows:
Render Options
Quality: 9
Bounding boxes.......On Bounding threshold: 3
Antialiasing.........Off
Am I doing something wrong?
Am 03.06.2012 20:55, schrieb taftj:
> +A0.3 +AM2 +R3 +Q11
> Render Options
> Quality: 9
Apparently. Are you starting the render via an .ini file? If so, maybe
that .ini file turns off anti-aliasing.
Which version of POV-Ray are you using?
> > +A0.3 +AM2 +R3 +Q11
> > Render Options
> > Quality: 9
It's version 3.7 RC5. I'm starting it from command line.
Am 03.06.2012 22:29, schrieb taftj:
>>> +A0.3 +AM2 +R3 +Q11
>>> Render Options
>>> Quality: 9
Quite odd. What operating system?
Can you post the complete message output?
What happens if you /do/ use an .ini file?
> >>> +A0.3 +AM2 +R3 +Q11
> >>> Render Options
> >>> Quality: 9
my OS is LinuxMint 64-bit. Here is the entire output. I'll try with an .ini
file after the current render has finished.
$ povray +H2000 +W3200+A0.3 +AM2 +R3 +Q11 helices.pov
povray: This is a RELEASE CANDIDATE version of POV-Ray. General distribution is
discouraged.
Persistence of Vision(tm) Ray Tracer Version 3.7.0.RC5 (g++ 4.6 @
x86_64-unknown-linux-gnu)
This is a release candidate of POV-Ray version 3.7.0.
General distribution is strongly discouraged.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2011 Persistence of Vision Raytracer Pty. Ltd.
Primary POV-Ray 3.7 Architects/Developers: (Alphabetically)
Chris Cason Thorsten Froehlich Christoph Lipka
With Assistance From: (Alphabetically)
Nicolas Calimet James Holsenback Christoph Hormann Nathan Kopp
Juha Nieminen
Past Contributors: (Alphabetically)
Steve Anger Eric Barish Dieter Bayer David K. Buck
Nicolas Calimet Chris Cason Aaron A. Collins Chris Dailey
Steve Demlow Andreas Dilger Alexander Enzmann Dan Farmer
Thorsten Froehlich Mark Gordon James Holsenback Christoph Hormann
Mike Hough Chris Huff Kari Kivisalo Nathan Kopp
Lutz Kretzschmar Christoph Lipka Jochen Lippert Pascal Massimino
Jim McElhiney Douglas Muir Juha Nieminen Ron Parker
Bill Pulver Eduard Schwan Wlodzimierz Skiba Robert Skinner
Yvo Smellenbergh Zsolt Szalavari Scott Taylor Massimo Valentini
Timothy Wegner Drew Wells Chris Young
Other contributors are listed in the documentation.
Support libraries used by POV-Ray:
ZLib 1.2.3.4, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
LibPNG 1.2.46, Copyright 1998-2002 Glenn Randers-Pehrson
LibJPEG 80, Copyright 1998 Thomas G. Lane
LibTIFF 3.9.5, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Boost 1.46, http://www.boost.org/
Parser Options
Input file: helices.pov
Remove bounds........On
Split unions.........Off
Library paths:
/usr/local/share/povray-3.7
/usr/local/share/povray-3.7/ini
/usr/local/share/povray-3.7/include
Clock value: 0.000 (Animation off)
Image Output Options
Image resolution.....3200 by 2000 (rows 1 to 2000, columns 1 to 3200).
Output file..........helices.png, 24 bpp PNG
Dithering............Off
Graphic display......On (gamma: sRGB)
Mosaic preview.......Off
Continued trace......Off
Information Output Options
All Streams to console..........On
Debug Stream to console.........On
Fatal Stream to console.........On
Render Stream to console........On
Statistics Stream to console....On
Warning Stream to console.......On
==== [Parsing...] ==========================================================
Possible Parse Error: assumed_gamma not specified in this POV-Ray 3.7 or later
scene. Future versions of POV-Ray may consider this a fatal error. To avoid
this warning, explicitly specify 'assumed_gamma 1.0' in the global_settings
section. See the documentation for more details.
Parser Statistics
Finite Objects: 104
Infinite Objects: 1
Light Sources: 1
Total: 106
Parser Time
Parse Time: 0 hours 0 minutes 0 seconds (0.036 seconds)
using 1 thread(s) with 0.029 CPU-seconds total
Bounding Time: 0 hours 0 minutes 0 seconds (0.001 seconds)
using 1 thread(s) with 0.000 CPU-seconds total
Render Options
Quality: 9
==== [Rendering...] ========================================================
grrrr... I'm an idiot. It was the lack of space before +A.
sorry to have wasted your time.
