POV-Ray : Newsgroups : povray.newusers : Mobius and image_map Server Time
20 Sep 2024 18:58:41 EDT (-0400)
  Mobius and image_map (Message 1 to 2 of 2)
Subject: Mobius and image_map
Date: 1 Feb 2012 20:45:01
Message: <web.4f29e9a0bb41d3278c0eec1e0@news.povray.org>
I want to render a mobius in Povray that has a surface texture that is a "decal"
of an image (the image is a long strip and should appear in the rendered output
as if the strip had been pressed onto the mobius).
I tried all of the map_type's defined in the documentation, but in all cases the
projection is highly distorted.
If you create an 800x100 pixel white image with a blue circle in the middle for
"surface.png", you'll see what I mean.
How can I correct the projection?
Here's the .pov file:
    #declare P_R=0.2; #declare P_H=0.75;
    #declare Profile =
    union{
     sphere  {<0, P_H,0>,P_R}
     cylinder{<0,-P_H,0>,<0,P_H,0>,P_R}
     sphere  {<0,-P_H,0>,P_R }
    texture
            pigment
                image_map
                    png "surface.png"
                    map_type 0
                    interpolate 2
                scale <0.20,0.2,0.2>
            finish {ambient 0.85
                 diffuse 0.55
                 phong 1}
    #declare Radius_major = 3.00;
    #declare N_major =  0.5;
    #declare N_minor = 2000;
    #declare Nr =0;              //start
    #declare EndNr=N_major*N_minor;//end
    #while (Nr< EndNr)
    object{Profile
           rotate<0,0,Nr * 360/N_minor>
           translate<Radius_major,0,0>
           rotate<0,Nr * 360/EndNr,0>}
     #declare Nr = Nr+1;// next Nr_minor
    #end // ------------ end of loop --
       location <-5, 10, -15>
       direction <0, 0,  2.25>
       right x*1.33
       look_at <0,0,0>
Subject: Re: Mobius and image_map
Date: 2 Feb 2012 03:06:03
Message: <4f2a43eb@news.povray.org>
You are using a projection with an object (y along cylinder with
spherical caps) that goes through the origin.
As the projection is centred at the origin, it is normal that you get a
distortion. (excepted for type 0: planar projection)
Move your projection (translate the pigment, or translate the object,
apply pigment, and translate back the whole thing) and may be also check
the projection direction: map_type 0 is a plane in x-y, does it match
your expectation ?
Also, you repeat your textured object to generate your strip, which
might have a side effect on final aspect.
You should try to tune with a "once" in the mapping.
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
