POV-Ray : Newsgroups : povray.newusers : HDR test with sky_sphere and regular sphere Server Time
26 Jun 2024 04:15:38 EDT (-0400)
  HDR test with sky_sphere and regular sphere (Message 1 to 4 of 4)
Subject: HDR test with sky_sphere and regular sphere
Date: 21 Dec 2011 11:20:01
Message: <web.4ef20639a52269b117bdd960@news.povray.org>
Hello everybody
I'm trying some test with HDR lighting, using the example shown in this thread:
http://news.povray.org/povray.general/thread/%3Cweb.4e316b7b630a1fa94c0a951f0%40news.povray.org%3E
I have commented the following sky_sphere block:
sky_sphere {
  pigment {image_map {hdr "*HDR_FILE_PATH.hdr*" map_type 1 interpolate 2}}
  rotate y*-120
and added this instead:
sphere {
  <0,0,0>, 10000
  rotate y*-120
  hollow
(this is as suggested in another thread, to be able to maintain the lighting of
the chosen hdr file while showing some other image mapped on the sky_sphere).
I expected to obtain the same result at this point, on the contrary I get a much
darker image (so lighting must be substantially different) and also an array" of
evenly spaced irregularly-shaped "blots" over the image.
Could someone please explain what is happening?
I've read docs about sky_sphere, but I did not understand why it should give
such different lighting results... To my understanding it should just be
enclosing anything else in the scene...
Thanks in advance,
Alessandro
Subject: Re: HDR test with sky_sphere and regular sphere
Date: 21 Dec 2011 13:00:33
Message: <4ef21ec1$1@news.povray.org>
Le 21/12/2011 17:17, acasta nous fit lire :
> Hello everybody
> sky_sphere {
>   rotate y*-120
> sphere {
>   <0,0,0>, 10000
>   rotate y*-120
>   hollow
what is your finish on the sphere ? (hint: unless you use something
along "ambient 1.0 diffuse 0.0 ... ", the aspect of the texture/pigment
on a point of the sphere is subject to reachability by a light source,
and the relevant light that it gets.)
Date: 22 Dec 2011 01:17:51
Message: <4ef2cb8f@news.povray.org>
Am 21.12.2011 17:17, schrieb acasta:
Yup: Sky spheres can be thought of as having an "emission 1 ambient 0
diffuse 0 specular 0 reflection 0" finish; note that this differs from
the default finish for normal objects, which is primarily diffuse, so
you'll have to specify these finish properties explicitly on your pseudo
sky sphere.
As for the blots, they're most likely radiosity artifacts and will
disappear once you set diffuse to 0.
Date: 22 Dec 2011 02:55:00
Message: <web.4ef2e11b654cffdb117bdd960@news.povray.org>
Thanks for your suggestions.
The finish block with settings described by clipka did the job.
I didn't know about the "hidden" properties of sky_sphere...
Great!
Alessandro
