POV-Ray : Newsgroups : povray.newusers : Error in the picture? Server Time
22 Feb 2025 11:51:56 EST (-0500)
  Error in the picture? (Message 1 to 5 of 5)
Subject: Error in the picture?
Date: 21 Oct 2011 08:10:01
Message: <web.4ea1605aaa97727eb4c6b88a0@news.povray.org>
Hello,
i am a new POVRay-User with ab Question.
I Rendering this Picture and i see little "Black-Points/Pixel", max_trace_level
is up to 256. In other Picture are the Shadows not smooth but consist of
points...
Anyone ideas?
Picture with Black-Points:
http://s1.directupload.net/file/d/2684/5426qjr5_png.htm
AA ist +a0.1
Thanks
Subject: Re: Error in the picture?
Date: 21 Oct 2011 08:36:31
Message: <4ea1674f$1@news.povray.org>
Le 21/10/2011 14:06, cartun nous fit lire :
> Hello,
> points...
> Anyone ideas?
> AA ist +a0.1
which version of povray ? 3.6 or less, or 3.7RC3 ?
Also, focal blur seems in use...
If you want soft shadow, you need some area light of relevant dimension,
and that's slowing down the rendering.
Date: 21 Oct 2011 10:45:01
Message: <web.4ea18446270e54df50a419320@news.povray.org>
Hello,
tanks for your Message.
My Version is:  Version 3.6.1 (Debian  (x86_64-linux-gnu-g+
+ 4.4.5 @ x86_64-pc-linux-gnu))
And yes, i used the area_light:
[code]
#include "textures.inc"
#include "metals.inc"
#global_settings{max_trace_level 256}
camera{
 location<4,3,-12>
 look_at<0,0,0>
 //focal_point<0,0,0>
 //aperture 0.9
 //blur_samples 100
 //confidence 1
 //variance 1/128
light_source{
 <0,0,0> White
 area_light
 <0,0,0> <3,0,3>
 5,5
 adaptive 0
 jitter
 translate<-10,11,-4>
[/code]
The Shadows from the boxes.. :
http://s1.directupload.net/file/d/2684/b6n884qk_png.htm
Thanks for Ideas!
Date: 21 Oct 2011 11:38:06
Message: <4ea191de$1@news.povray.org>
Am 21.10.2011 16:40, schrieb cartun:
You can't use both focal blur and anti-aliasing at the same time with
version 3.6.1; with focal blur activated, that version of POV-Ray will
automatically ignore any anti-aliasing settings, and rely solely on
focal blur to do that job.
I suggest using the latest 3.7.0 release candidate; it has some
improvements to focal blur (including, but not limited to, the ability
to use anti-aliasing at the same time), which might already help with
your spotty artifacts.
The "cut-outs" at the near corner of the shadows indicate that "adaptive
0" isn't enough, and you should use "adaptive 1" instead.
As for the graininess: You can probably improve that by using a higher
resolution of the area light, e.g. "9,9" instead of "5,5"; using even
more aggressive anti-aliasing might help as well.
I also notice that your area light is not square; is that intentional,
or did you mean to use "area_light <0,0,3> <3,0,0>"?
(You might also want to try "circular orient", unless you're
specifically aiming for a square light source.)
Date: 22 Oct 2011 13:00:01
Message: <web.4ea2f612270e54df7b4f2d8a0@news.povray.org>
Hello,
thank you for all the Informations!
A Light-Area with 9,9 make it better, thank you very mutch!
I am happy.. i love POVRay :)
bye bye and greets from Germany!
