POV-Ray : Newsgroups : povray.newusers : How bright can i make objects? Server Time
28 Jul 2024 00:28:38 EDT (-0400)
  How bright can i make objects? (Message 1 to 2 of 2)
Subject: How bright can i make objects?
Date: 14 Oct 2011 18:30:00
Message: <web.4e98b7919dc977f712255f680@news.povray.org>
when using radiosity is it possible to set the emittance of objects to values of
greater than 1 and still get reliable results?
In my scene a get RGB levels lower than saturation when I set the emittance of a
particular object to 50 (this object is not visible directly by the camera, it
is seen by a diffuse reflection off of a rectangle). What I dont know is if
setting the emittance so high may cause errors in the radiosity calculations.
Any advice on this area will be much appreciated!
Thank you
Stuart
Subject: Re: How bright can i make objects?
Date: 17 Oct 2011 20:42:11
Message: <4e9ccb63$1@news.povray.org>
Am 15.10.2011 00:28, schrieb Crippso:
Yes, absolutely.
